Question regarding config/Rules.xml
Shazard
Post by Shazard »
What is full structure of this file.
Currently I see it has encoding for device names and their coordinates on the map, as well as map itself with polygons.
My case is again... suppose I have multisensor, where one device have 3 sensors... And what if I want to rename each sensor... similar like it is done by Rules.xml assigning logical names to the device ids. Is there structural possibility.
And even if it is not, then do I understand correctly if I add something to the XML it will be overwritten on the next save anyway?
Is there another way to save some metadata on the system. Looking into code it seems that I can write any file using "PUT" request, but can I create new file with additional metadata?
Re: Question regarding config/Rules.xml
Forget about it - it is only for old blue UI and is not used by anything else.
Shazard
Post by Shazard »
So how then I can associate any metadata with devices?
in which UI?
Shazard
Post by Shazard »
Isn't this common?
What I wanted to do is that if I rename a device on my application or UI, this is reflected everywhere.
There are essencially two UIs: Expert UI, related to Z-Wave only and Z-Way Home Automation UI, which is more for everyday usage. The latter have it's own concept of widgets, modules and own config with names.
Shazard
Post by Shazard »
PoltoS, then it seems that you could improve design to move this metainformation storage closer to the Z-Wave.me itself, and decouple it from UI.
Could you explain your idea in more details please?
