Razberry HA Module & WiringPi gpio
criminosis
Post by criminosis »
Hello all,
Has anyone tried calling WiringPi from inside a HA module?
I seem to be having some troubles. Empirically it's as if my calling of the gpio command just "doesn't happen."
Example:
var test = system("gpio readall");
	debugPrint("Test: "+test);
Returned this:
[2014-11-18 17:38:19.115] Test: 0,
I haven't been understanding for sure, but I'm guessing the "0," that is returned is some kind of wrapping by the system() call. Point being, nothing is actually being returned.
When it should be returning something like this (This is me running it manually):
pi@raspberrypi ~ $ gpio readall
 +-----+-----+---------+------+---+-Model B2-+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5V      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |  OUT | 1 | 11 || 12 | 1 | OUT  | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |  OUT | 1 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |  OUT | 1 | 15 || 16 | 1 | OUT  | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 1 | OUT  | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 1 | OUT  | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 0 | IN   | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 0 | IN   | CE1     | 11  | 7   |
 |  28 |  17 | GPIO.17 |   IN | 0 | 51 || 52 | 0 | IN   | GPIO.18 | 18  | 29  |
 |  30 |  19 | GPIO.19 |   IN | 0 | 53 || 54 | 0 | IN   | GPIO.20 | 20  | 31  |
pi@raspberrypi ~ $
I have similar results when I try reading individual pins or (most importantly) setting a pin's on/off state. The command is accepted (I have whitelisted gpio in the .syscommand file) but it just doesn't return anything. And when it is supposed to execute the commands to set pins on/off I will manually read the pin's state (after the set command "completes) but the state is unchanged.
There are no errors being reported in the /var/log/z-way-server.log nor in the system log.
Has anyone else experienced this?
Edit:
For what it's worth I am able to successfully execute other commands through system().
For example this command executes just fine even though it is piped through multiple commands. So I'm at a loss why gpio is being the exception.
var CLI_tempSensorCommand = "sed -n '2p' < "+"/sys/bus/w1/devices/"+tempSensorID+"/w1_slave"+" | awk '{print $10; }' | cut -c 3-";
system(CLI_tempSensorCommand);
pz1
Re: Razberry HA Module & WiringPi gpio
Post by pz1 »
I have done the on/off switcing successfully as described here
criminosis
So that script seems to be explicitly specifying the path to the binary instead of relying on the user's bash path. I assumed the system() wrapper would still be on the same path as root (which is the user account the z-way server is running under).
Eitherway, I'll change it to that and give it a shot.
criminosis
That made it work. Thanks for the help.
