2.0.0 - a couple of issues
SolarFlor
Post by SolarFlor »
Hi all,
need your help for a couple of issues related to version 2.0.0
1)
I used the following command to turn off a device.
http://192.168.1.22:8083/ZAutomation/Op ... aryOff/5/0
Now I see the following error: Invalid ZAutomation request
2) In Z-Way Home Automation UI how we can hide Warning message? the Hide button doesn't exist any more
EDIT: forget question 2. I have seen PoltoS reply in another post
pz1
Re: 2.0.0 - a couple of issues
Post by pz1 »
You must leave the ZAutomation part out of your path. See recipes section for OpenRemoteHelpers
http://192.168.1.22:8083/OpenRemote/SwitchBinaryOff/5/0
billyboy
Post by billyboy »
The calling url is changed in v2.0.0
for me:
was: http://127.0.0.1:8083/ZAutomation/api/v ... Dev_3:1:37
now: http://127.0.0.1:8083/ZAutomation/api/v ... way_3-1-37
Hope this helps you.
pz1
Post by pz1 »
billyboy wrote:The calling url is changed in v2.0.0
for me:
There are several API's to RaZberry. Afaik the thing you are talking about is the vitual devices Apiary API
Solorflor is using the OpenRemote API, which uses the old zwave api inside. My answer was adressing that interface.
SolarFlor
Post by SolarFlor »
pz1 wrote:You must leave the ZAutomation part out of your path. See recipes section for OpenRemoteHelpers
Many Thanks. It works
SolarFlor
Post by SolarFlor »
for me:
Many thanks billiboy.
I'm using OpenRemote API and I have fixed the issues thanks to pz1
To be more specific, not API changed, but IDs changed. We replaced special character : by - in devices ID for extensions like iRidium mobile and added zway object name as you can have many dongles together.
