http://www.amazon.fr/gp/product/B00M1MO ... ge_o00_s00
I installed it on a Raspberry Pi model B (all up to date) (192.168.0.11) : wget -q -O - razberry.z-wave.me/install | sudo bash
I have a smarplug Fibaro WallPlug :
http://www.amazon.fr/gp/product/B00D1RB ... ge_o01_s00
I have access to the ZBox
http://192.168.0.11:8084/cgi-bin/main.cgi
My Zbox ID is : ZBox ID: 16289
http://192.168.0.11:8083/blueui/ gives me :
http://192.168.0.11:8083/expert/#/Sorry, server has not completely started yet. Try realoding the interface later.
I'm not sure if the plug is associated. It should blink red but it didn't. I have set the dongle on association mode, insert the plug in the wall, and that sould be it !!Error handling data from server
I don't know what to do.
pi@rantraspi /opt/z-way-server $ sudo LD_LIBRARY_PATH=./libs ./z-way-server
Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
Module modws.so loaded
Module moddhs.so loaded
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modhttp.so loaded
Module modhomekit.so loaded
Module modzwave.so loaded
Module modenocean.so loaded
pi@rantraspi /opt/z-way-server $ tail /var/log/z-way-server.log
[2014-12-17 20:26:15.264] [I] [core] Executing script: /*** NotificationSMSru Z-Way HA module ******************************************* ...
[2014-12-17 20:26:15.266] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2014-12-17 20:26:15.333] [I] [core] Executing script: /*** CustomUserCode ZAutomation module **************************************** ...
[2014-12-17 20:26:15.335] [I] [core] Loading module ZWave from modules/ZWave
[2014-12-17 20:26:15.490] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2014-12-17 20:26:15.497] [I] [core] Loading module Camera from modules/Camera
[2014-12-17 20:26:15.663] [I] [core] Executing script: /*** Camera Z-Way HA module ******************************************* ...
[2014-12-17 20:26:15.745] [I] [core] Starting automation...
[2014-12-17 20:26:16.177] [I] [core] Starting storage...
[2014-12-17 20:26:16.211] [I] [core] ZWay Automation started
http://192.168.0.11:8083/expert/#/network/controller
job queue is empty
ps aux gives me that :
pi@rantraspi /opt/z-way-server $ ps aux | grep z
root 3105 3.2 2.7 66664 12128 ? Sl 20:25 0:18 z-way-server
root 3224 0.0 0.3 3220 1500 ? Ss 20:26 0:00 /bin/bash /etc/init.d/zbw_connect
root 3272 0.0 0.5 5808 2592 ? S 20:26 0:00 ssh -i /tmp/zbw_connect.priv -T -o StrictHostKeyChecking no -o UserKnownHostsFile /dev/null -o BatchMode yes -o SendEnv ZBW_* -o ExitOnForwardFailure yes -o ServerAliveInterval 30 -o ServerAliveCountMax 3 -R 0.0.0.0:10000:127.0.0.1:8083 -R 0.0.0.0:10001:127.0.0.1:22 remote@find.z-wave.me
Can somebody help me please ?
