EZMotion PIR detector - any success?
Tiptop
Post by Tiptop »
Hello there,
Quite a while ago I bough this PIR motion detector:
http://expresscontrols.com/pdf/EZMotion+OwnerManual.pdf
In an old version of the RaZberry/ZWay-Server, I had no problems using this detector.
I fact, in my eyes this is one of the best PIR detectors on the market, the sensitivity is configurable and really great, it has quite a few neat options, as well.
However, after some update to server version 1.7, things broke. I wasn't able to get this device stable, anymore.
First, the motion triggers stopped working. As the device didn't update its own commandClass value properties, anymore. Instead, the server property devices.1.instances.0.commandClasses.32.data.level is changed, therefore I created a fix by binding to this property and checking if devices.1.instances.0.commandClasses.32.data.srcNodeId is pointing to the EZMotion.
This worked, but soon I noticed that the device still fails after a while and drains its batteries tremendously... so I tried to remove and re-include the device...
The z-way server has MASSIVE problems (re-)including the device, it mostly fails to perform the full interview. I have to press the wakeup button like crazy to get the interview complete. This is completely reproducible!
To sum it up: This device was useless and I replaced it by an Everspring PIR detector.
Two days ago I upgraded to server version 2.0.0 and I tried it once again: Same behavior, same problems.
So here is my question: Is anyone out there who has a recent z-way server setup (2.0.0) and a flawlessly running EZMotion PIR detector?
If the detector wouldn't have failed directly after a z-way server update somewhen in the past, I would suspect that the device is broken... but I am quite sure that this is some interoperability problem...
Any hints are highly appreciated!
Many thanks in advance!
Re: EZMotion PIR detector - any success?
Start with correctly pressing the button: press for 5 seconds and release. This will allow to exclude/include the device.
Tiptop
Post by Tiptop »
@PoltoS: Thanks for your reply!
But I still do not have ANY luck with it: The device falls asleep during the inclusion process...
I have a secondary RaZberry system (using v2.0.0) for testing here and here is the full inclusion log:
[2014-12-16 21:21:35.689] [I] [zway] Adding job: Add/re-include node to network
[2014-12-16 21:21:35.692] [D] [zway] SENDING (cb 0x11): ( 01 05 00 4A C1 11 60 )
[2014-12-16 21:21:35.695] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:35.696] [D] [zway] RECEIVED: ( 01 07 00 4A 11 01 00 00 A2 )
[2014-12-16 21:21:35.698] [D] [zway] SENT ACK
[2014-12-16 21:21:35.699] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-16 21:21:35.701] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-16 21:21:35.702] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-12-16 21:21:35.704] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-12-16 21:21:38.582] [D] [zway] RECEIVED: ( 01 07 00 4A 11 02 00 00 A1 )
[2014-12-16 21:21:38.582] [D] [zway] SENT ACK
[2014-12-16 21:21:38.582] [I] [zway] Job 0x4a (Add/re-include node to network): Node found: #0
[2014-12-16 21:21:38.583] [D] [zway] SETDATA controller.data.controllerState = 2 (0x00000002)
[2014-12-16 21:21:41.392] [D] [zway] RECEIVED: ( 01 16 00 4A 11 03 12 0F 04 20 01 30 31 85 9B 70 84 80 72 86 EF 20 60 B9 )
[2014-12-16 21:21:41.416] [D] [zway] SENT ACK
[2014-12-16 21:21:41.417] [I] [zway] Job 0x4a (Add/re-include node to network): Adding slave: #18
[2014-12-16 21:21:41.417] [D] [zway] SETDATA controller.data.controllerState = 3 (0x00000003)
[2014-12-16 21:21:41.417] [D] [zway] SETDATA controller.data.lastIncludedDevice = 18 (0x00000012)
[2014-12-16 21:21:41.417] [D] [zway] SETDATA devices.18.data = Empty
[2014-12-16 21:21:41.417] [D] [zway] SETDATA devices.18.instances.0.data = Empty
[2014-12-16 21:21:41.418] [D] [zway] SETDATA devices.18.instances.0.data.dynamic = Empty
[2014-12-16 21:21:41.418] [D] [zway] SETDATA devices.18.instances.0.data.dynamic = False
[2014-12-16 21:21:41.418] [D] [zway] SETDATA devices.18.instances.0.data.genericType = Empty
[2014-12-16 21:21:41.418] [D] [zway] SETDATA devices.18.instances.0.data.genericType = 0 (0x00000000)
[2014-12-16 21:21:41.418] [D] [zway] SETDATA devices.18.instances.0.data.specificType = Empty
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.instances.0.data.specificType = 0 (0x00000000)
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.data.basicType = Empty
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.data.genericType = Empty
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.data.specificType = Empty
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.data.infoProtocolSpecific = Empty
[2014-12-16 21:21:41.419] [D] [zway] SETDATA devices.18.data.deviceTypeString = Empty
[2014-12-16 21:21:41.420] [D] [zway] SETDATA devices.18.data.isVirtual = Empty
[2014-12-16 21:21:41.423] [D] [zway] SETDATA devices.18.data.isListening = Empty
[2014-12-16 21:21:41.424] [D] [zway] SETDATA devices.18.data.isRouting = Empty
[2014-12-16 21:21:41.425] [D] [zway] SETDATA devices.18.data.isAwake = Empty
[2014-12-16 21:21:41.427] [D] [zway] SETDATA devices.18.data.optional = Empty
[2014-12-16 21:21:41.428] [D] [zway] SETDATA devices.18.data.isFailed = Empty
[2014-12-16 21:21:41.429] [D] [zway] SETDATA devices.18.data.beam = Empty
[2014-12-16 21:21:41.430] [D] [zway] SETDATA devices.18.data.sensor250 = Empty
[2014-12-16 21:21:41.432] [D] [zway] SETDATA devices.18.data.sensor1000 = Empty
[2014-12-16 21:21:41.433] [D] [zway] SETDATA devices.18.data.neighbours = Empty
[2014-12-16 21:21:41.434] [D] [zway] SETDATA devices.18.data.manufacturerId = Empty
[2014-12-16 21:21:41.434] [D] [zway] SETDATA devices.18.data.vendorString = Empty
[2014-12-16 21:21:41.435] [D] [zway] SETDATA devices.18.data.manufacturerProductType = Empty
[2014-12-16 21:21:41.436] [D] [zway] SETDATA devices.18.data.manufacturerProductId = Empty
[2014-12-16 21:21:41.437] [D] [zway] SETDATA devices.18.data.ZWLib = Empty
[2014-12-16 21:21:41.438] [D] [zway] SETDATA devices.18.data.ZWProtocolMajor = Empty
[2014-12-16 21:21:41.438] [D] [zway] SETDATA devices.18.data.ZWProtocolMinor = Empty
[2014-12-16 21:21:41.439] [D] [zway] SETDATA devices.18.data.SDK = Empty
[2014-12-16 21:21:41.440] [D] [zway] SETDATA devices.18.data.applicationMajor = Empty
[2014-12-16 21:21:41.441] [D] [zway] SETDATA devices.18.data.applicationMinor = Empty
[2014-12-16 21:21:41.441] [D] [zway] SETDATA devices.18.data.nodeInfoFrame = Empty
[2014-12-16 21:21:41.442] [D] [zway] SETDATA devices.18.data.ZDDXMLFile = Empty
[2014-12-16 21:21:41.443] [D] [zway] SETDATA devices.18.data.lastSend = Empty
[2014-12-16 21:21:41.444] [D] [zway] SETDATA devices.18.data.lastNonceGet = Empty
[2014-12-16 21:21:41.445] [D] [zway] SETDATA devices.18.data.lastReceived = Empty
[2014-12-16 21:21:41.446] [D] [zway] SETDATA devices.18.data.failureCount = Empty
[2014-12-16 21:21:41.447] [D] [zway] SETDATA devices.18.data.keepAwake = Empty
[2014-12-16 21:21:41.448] [D] [zway] SETDATA devices.18.data.countSuccess = Empty
[2014-12-16 21:21:41.449] [D] [zway] SETDATA devices.18.data.countFailed = Empty
[2014-12-16 21:21:41.449] [D] [zway] SETDATA devices.18.data.queueLength = Empty
[2014-12-16 21:21:41.450] [D] [zway] SETDATA devices.18.data.givenName = Empty
[2014-12-16 21:21:41.451] [D] [zway] SETDATA devices.18.data.lastPacketInfo = Empty
[2014-12-16 21:21:41.452] [D] [zway] SETDATA devices.18.data.lastPacketInfo.deliveryTime = Empty
[2014-12-16 21:21:41.453] [D] [zway] SETDATA devices.18.data.lastPacketInfo.delivered = Empty
[2014-12-16 21:21:41.454] [D] [zway] SETDATA devices.18.data.lastPacketInfo.packetLength = Empty
[2014-12-16 21:21:41.455] [D] [zway] SETDATA devices.18.data.basicType = 0 (0x00000000)
[2014-12-16 21:21:41.456] [D] [zway] SETDATA devices.18.data.genericType = 0 (0x00000000)
[2014-12-16 21:21:41.457] [D] [zway] SETDATA devices.18.data.specificType = 0 (0x00000000)
[2014-12-16 21:21:41.457] [D] [zway] SETDATA devices.18.data.infoProtocolSpecific = 0 (0x00000000)
[2014-12-16 21:21:41.458] [D] [zway] SETDATA devices.18.data.deviceTypeString = ""
[2014-12-16 21:21:41.459] [D] [zway] SETDATA devices.18.data.isVirtual = False
[2014-12-16 21:21:41.459] [D] [zway] SETDATA devices.18.data.isListening = True
[2014-12-16 21:21:41.460] [D] [zway] SETDATA devices.18.data.isRouting = False
[2014-12-16 21:21:41.461] [D] [zway] SETDATA devices.18.data.isAwake = False
[2014-12-16 21:21:41.462] [D] [zway] SETDATA devices.18.data.optional = False
[2014-12-16 21:21:41.463] [D] [zway] SETDATA devices.18.data.isFailed = False
[2014-12-16 21:21:41.464] [D] [zway] SETDATA devices.18.data.beam = False
[2014-12-16 21:21:41.465] [D] [zway] SETDATA devices.18.data.sensor250 = False
[2014-12-16 21:21:41.466] [D] [zway] SETDATA devices.18.data.sensor1000 = False
[2014-12-16 21:21:41.467] [D] [zway] SETDATA devices.18.data.neighbours = Empty
[2014-12-16 21:21:41.468] [D] [zway] SETDATA devices.18.data.manufacturerId = 0 (0x00000000)
[2014-12-16 21:21:41.468] [D] [zway] SETDATA devices.18.data.manufacturerProductType = 0 (0x00000000)
[2014-12-16 21:21:41.469] [D] [zway] SETDATA devices.18.data.manufacturerProductId = 0 (0x00000000)
[2014-12-16 21:21:41.470] [D] [zway] SETDATA devices.18.data.applicationMajor = 0 (0x00000000)
[2014-12-16 21:21:41.471] [D] [zway] SETDATA devices.18.data.applicationMinor = 0 (0x00000000)
[2014-12-16 21:21:41.472] [D] [zway] SETDATA devices.18.data.ZWProtocolMajor = 0 (0x00000000)
[2014-12-16 21:21:41.472] [D] [zway] SETDATA devices.18.data.ZWProtocolMinor = 0 (0x00000000)
[2014-12-16 21:21:41.473] [D] [zway] SETDATA devices.18.data.ZWLib = 0 (0x00000000)
[2014-12-16 21:21:41.474] [D] [zway] SETDATA devices.18.data.SDK = ""
[2014-12-16 21:21:41.475] [D] [zway] SETDATA devices.18.data.vendorString = ""
[2014-12-16 21:21:41.476] [D] [zway] SETDATA devices.18.data.nodeInfoFrame = Empty
[2014-12-16 21:21:41.477] [D] [zway] SETDATA devices.18.data.ZDDXMLFile = ""
[2014-12-16 21:21:41.477] [D] [zway] SETDATA devices.18.data.keepAwake = False
[2014-12-16 21:21:41.479] [D] [zway] SETDATA devices.18.data.countSuccess = 0 (0x00000000)
[2014-12-16 21:21:41.479] [D] [zway] SETDATA devices.18.data.countFailed = 0 (0x00000000)
[2014-12-16 21:21:41.480] [D] [zway] SETDATA devices.18.data.queueLength = 0 (0x00000000)
[2014-12-16 21:21:41.481] [D] [zway] SETDATA devices.18.data.lastReceived = 0 (0x00000000)
[2014-12-16 21:21:41.482] [D] [zway] SETDATA devices.18.data.lastSend = 0 (0x00000000)
[2014-12-16 21:21:41.483] [D] [zway] SETDATA devices.18.data.failureCount = 0 (0x00000000)
[2014-12-16 21:21:41.483] [D] [zway] SETDATA devices.18.data.givenName = ""
[2014-12-16 21:21:41.484] [I] [zway] Adding job: Get node protocol information
[2014-12-16 21:21:41.485] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.486] [I] [zway] Adding job: Check if node is failed
[2014-12-16 21:21:41.487] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.488] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.489] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.490] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.491] [I] [zway] Adding job: Get routing table line
[2014-12-16 21:21:41.492] [D] [zway] Job 0x80 (Get routing table line): removing duplicate
[2014-12-16 21:21:41.493] [D] [zway] SETDATA devices.18.data.basicType = 4 (0x00000004)
[2014-12-16 21:21:41.493] [D] [zway] SETDATA devices.18.data.genericType = 32 (0x00000020)
[2014-12-16 21:21:41.494] [D] [zway] SETDATA devices.18.instances.0.data.genericType = 32 (0x00000020)
[2014-12-16 21:21:41.495] [D] [zway] SETDATA devices.18.data.specificType = 1 (0x00000001)
[2014-12-16 21:21:41.500] [D] [zway] SETDATA devices.18.instances.0.data.specificType = 1 (0x00000001)
[2014-12-16 21:21:41.503] [D] [zway] SETDATA devices.18.data.deviceTypeString = "Routing Binary Sensor"
[2014-12-16 21:21:41.504] [D] [zway] SETDATA devices.18.data.nodeInfoFrame = byte[12]
[2014-12-16 21:21:41.505] [D] [zway]   ( 30 31 85 9B 70 84 80 72 86 EF 20 60 )
[2014-12-16 21:21:41.512] [D] [zway] SENDING: ( 01 04 00 62 12 8B )
[2014-12-16 21:21:41.517] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:41.518] [D] [zway] RECEIVED: ( 01 04 01 62 01 99 )
[2014-12-16 21:21:41.519] [D] [zway] SENT ACK
[2014-12-16 21:21:41.523] [D] [zway] SETDATA devices.18.data.isFailed = True
[2014-12-16 21:21:41.527] [I] [zway] Job 0x62 (Check if node is failed): Node 18 is failed
[2014-12-16 21:21:41.529] [D] [zway] Job 0x62 (Check if node is failed): success
[2014-12-16 21:21:41.535] [I] [zway] Removing job: Check if node is failed
[2014-12-16 21:21:41.987] [D] [zway] Job 0x4b: deleted from queue
[2014-12-16 21:21:49.579] [D] [zway] RECEIVED: ( 01 07 00 4A 11 05 12 00 B4 )
[2014-12-16 21:21:49.580] [D] [zway] SENT ACK
[2014-12-16 21:21:49.582] [D] [zway] SETDATA controller.data.controllerState = 4 (0x00000004)
[2014-12-16 21:21:49.583] [I] [zway] Job 0x4a (Add/re-include node to network): Protocol done
[2014-12-16 21:21:49.584] [I] [zway] Loading Command Classes for device 18
[2014-12-16 21:21:49.586] [I] [zway] Node 18:0 supports CC Basic
[2014-12-16 21:21:49.587] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data = Empty
[2014-12-16 21:21:49.588] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.supported = Empty
[2014-12-16 21:21:49.590] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.supported = True
[2014-12-16 21:21:49.591] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.version = Empty
[2014-12-16 21:21:49.592] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.593] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.security = Empty
[2014-12-16 21:21:49.594] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.security = False
[2014-12-16 21:21:49.595] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.interviewDone = Empty
[2014-12-16 21:21:49.596] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.interviewCounter = Empty
[2014-12-16 21:21:49.597] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.interviewDone = False
[2014-12-16 21:21:49.598] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.598] [D] [zway] SETDATA devices.18.instances.0.commandClasses.32.data.level = Empty
[2014-12-16 21:21:49.599] [I] [zway] Node 18:0 supports CC SensorBinary
[2014-12-16 21:21:49.600] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data = Empty
[2014-12-16 21:21:49.601] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.supported = Empty
[2014-12-16 21:21:49.602] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.supported = True
[2014-12-16 21:21:49.603] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.version = Empty
[2014-12-16 21:21:49.604] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.604] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.security = Empty
[2014-12-16 21:21:49.605] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.security = False
[2014-12-16 21:21:49.612] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.interviewDone = Empty
[2014-12-16 21:21:49.613] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.interviewCounter = Empty
[2014-12-16 21:21:49.615] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.interviewDone = False
[2014-12-16 21:21:49.616] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.617] [D] [zway] SETDATA devices.18.instances.0.commandClasses.48.data.typemask = Empty
[2014-12-16 21:21:49.620] [I] [zway] Node 18:0 supports CC SensorMultilevel
[2014-12-16 21:21:49.622] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data = Empty
[2014-12-16 21:21:49.623] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.supported = Empty
[2014-12-16 21:21:49.624] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.supported = True
[2014-12-16 21:21:49.626] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.version = Empty
[2014-12-16 21:21:49.627] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.628] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.security = Empty
[2014-12-16 21:21:49.629] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.security = False
[2014-12-16 21:21:49.630] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.interviewDone = Empty
[2014-12-16 21:21:49.632] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.interviewCounter = Empty
[2014-12-16 21:21:49.633] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.interviewDone = False
[2014-12-16 21:21:49.634] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.635] [D] [zway] SETDATA devices.18.instances.0.commandClasses.49.data.typemask = Empty
[2014-12-16 21:21:49.637] [I] [zway] Node 18:0 supports CC Configuration
[2014-12-16 21:21:49.638] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data = Empty
[2014-12-16 21:21:49.645] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.supported = Empty
[2014-12-16 21:21:49.646] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.supported = True
[2014-12-16 21:21:49.646] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.version = Empty
[2014-12-16 21:21:49.647] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.648] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.security = Empty
[2014-12-16 21:21:49.649] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.security = False
[2014-12-16 21:21:49.651] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.interviewDone = Empty
[2014-12-16 21:21:49.653] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.interviewCounter = Empty
[2014-12-16 21:21:49.655] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.interviewDone = False
[2014-12-16 21:21:49.656] [D] [zway] SETDATA devices.18.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.656] [I] [zway] Node 18:0 supports CC ManufacturerSpecific
[2014-12-16 21:21:49.658] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data = Empty
[2014-12-16 21:21:49.658] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.supported = Empty
[2014-12-16 21:21:49.660] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.supported = True
[2014-12-16 21:21:49.661] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.version = Empty
[2014-12-16 21:21:49.664] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.665] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.security = Empty
[2014-12-16 21:21:49.667] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.security = False
[2014-12-16 21:21:49.669] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.interviewDone = Empty
[2014-12-16 21:21:49.670] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.interviewCounter = Empty
[2014-12-16 21:21:49.672] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.interviewDone = False
[2014-12-16 21:21:49.674] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.675] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.vendorId = Empty
[2014-12-16 21:21:49.677] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.vendor = Empty
[2014-12-16 21:21:49.680] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.productId = Empty
[2014-12-16 21:21:49.680] [D] [zway] SETDATA devices.18.instances.0.commandClasses.114.data.productType = Empty
[2014-12-16 21:21:49.681] [I] [zway] Node 18:0 supports CC Battery
[2014-12-16 21:21:49.683] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data = Empty
[2014-12-16 21:21:49.684] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.supported = Empty
[2014-12-16 21:21:49.685] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.supported = True
[2014-12-16 21:21:49.687] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.version = Empty
[2014-12-16 21:21:49.688] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.691] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.security = Empty
[2014-12-16 21:21:49.692] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.security = False
[2014-12-16 21:21:49.696] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.interviewDone = Empty
[2014-12-16 21:21:49.697] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.interviewCounter = Empty
[2014-12-16 21:21:49.700] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.interviewDone = False
[2014-12-16 21:21:49.700] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.702] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.lastChange = Empty
[2014-12-16 21:21:49.703] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.history = Empty
[2014-12-16 21:21:49.704] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.last = Empty
[2014-12-16 21:21:49.705] [D] [zway] SETDATA devices.18.instances.0.commandClasses.128.data.last = 0 (0x00000000)
[2014-12-16 21:21:49.708] [I] [zway] Node 18:0 supports CC Wakeup
[2014-12-16 21:21:49.709] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data = Empty
[2014-12-16 21:21:49.710] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.supported = Empty
[2014-12-16 21:21:49.711] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.supported = True
[2014-12-16 21:21:49.711] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.version = Empty
[2014-12-16 21:21:49.712] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.713] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.security = Empty
[2014-12-16 21:21:49.714] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.security = False
[2014-12-16 21:21:49.715] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interviewDone = Empty
[2014-12-16 21:21:49.717] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interviewCounter = Empty
[2014-12-16 21:21:49.717] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interviewDone = False
[2014-12-16 21:21:49.718] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.719] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interval = Empty
[2014-12-16 21:21:49.720] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.nodeId = Empty
[2014-12-16 21:21:49.721] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.min = Empty
[2014-12-16 21:21:49.722] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.max = Empty
[2014-12-16 21:21:49.723] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.default = Empty
[2014-12-16 21:21:49.725] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.step = Empty
[2014-12-16 21:21:49.726] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.lastWakeup = Empty
[2014-12-16 21:21:49.726] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.lastSleep = Empty
[2014-12-16 21:21:49.727] [D] [zway] SETDATA devices.18.instances.0.commandClasses.132.data.interval = 0 (0x00000000)
[2014-12-16 21:21:49.729] [I] [zway] Node 18:0 supports CC Association
[2014-12-16 21:21:49.729] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data = Empty
[2014-12-16 21:21:49.730] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.supported = Empty
[2014-12-16 21:21:49.732] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.supported = True
[2014-12-16 21:21:49.733] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.version = Empty
[2014-12-16 21:21:49.734] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.735] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.security = Empty
[2014-12-16 21:21:49.735] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.security = False
[2014-12-16 21:21:49.737] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.interviewDone = Empty
[2014-12-16 21:21:49.737] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.interviewCounter = Empty
[2014-12-16 21:21:49.738] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.interviewDone = False
[2014-12-16 21:21:49.739] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.740] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.groups = Empty
[2014-12-16 21:21:49.741] [D] [zway] SETDATA devices.18.instances.0.commandClasses.133.data.specificGroup = Empty
[2014-12-16 21:21:49.742] [I] [zway] Node 18:0 supports CC Version
[2014-12-16 21:21:49.742] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data = Empty
[2014-12-16 21:21:49.743] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.supported = Empty
[2014-12-16 21:21:49.748] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.supported = True
[2014-12-16 21:21:49.750] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.version = Empty
[2014-12-16 21:21:49.750] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-12-16 21:21:49.751] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.security = Empty
[2014-12-16 21:21:49.752] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.security = False
[2014-12-16 21:21:49.753] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewDone = Empty
[2014-12-16 21:21:49.755] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewCounter = Empty
[2014-12-16 21:21:49.755] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewDone = False
[2014-12-16 21:21:49.757] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2014-12-16 21:21:49.757] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.ZWLib = Empty
[2014-12-16 21:21:49.759] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2014-12-16 21:21:49.759] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2014-12-16 21:21:49.760] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.SDK = Empty
[2014-12-16 21:21:49.760] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.applicationMajor = Empty
[2014-12-16 21:21:49.761] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.applicationMinor = Empty
[2014-12-16 21:21:49.763] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-12-16 21:21:49.764] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.firmwareCount = Empty
[2014-12-16 21:21:49.764] [D] [zway] Node 18:0 supports CC UNKNOWN 0x9b
[2014-12-16 21:21:49.765] [D] [zway] SETDATA devices.18.data.lastSend = 49207 (0x0000c037)
[2014-12-16 21:21:49.766] [D] [zway] SETDATA devices.18.data.isAwake = True
[2014-12-16 21:21:49.766] [D] [zway] SETDATA devices.18.data.lastSend = 49107 (0x0000bfd3)
[2014-12-16 21:21:49.767] [D] [zway] SETDATA devices.18.data.lastNonceGet = 48107 (0x0000bbeb)
[2014-12-16 21:21:49.768] [I] [zway] Interview step 1 skipped due to absence of Security CC
[2014-12-16 21:21:49.770] [I] [zway] Interview step 2
[2014-12-16 21:21:49.773] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewDone = False
[2014-12-16 21:21:49.774] [D] [zway] SETDATA devices.18.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
[2014-12-16 21:21:49.775] [I] [zway] Node 18:0 CC Version Interview started
[2014-12-16 21:21:49.776] [I] [zway] Adding job: Basic Version Get
[2014-12-16 21:21:49.777] [I] [zway] Adding job: SensorBinary Version Get
[2014-12-16 21:21:49.779] [I] [zway] Adding job: SensorMultilevel Version Get
[2014-12-16 21:21:49.780] [I] [zway] Adding job: Configuration Version Get
[2014-12-16 21:21:49.782] [I] [zway] Adding job: ManufacturerSpecific Version Get
[2014-12-16 21:21:49.783] [I] [zway] Adding job: Battery Version Get
[2014-12-16 21:21:49.784] [I] [zway] Adding job: Wakeup Version Get
[2014-12-16 21:21:49.786] [I] [zway] Adding job: Association Version Get
[2014-12-16 21:21:49.787] [I] [zway] Adding job: Version Version Get
[2014-12-16 21:21:49.789] [D] [zway] Running wakeup handler for node 18
[2014-12-16 21:21:49.790] [I] [zway] Adding job: Add/re-include node to network
[2014-12-16 21:21:49.797] [D] [zway] SENDING: ( 01 04 00 4A 05 B4 )
[2014-12-16 21:21:49.810] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.812] [I] [zway] Removing job: Add/re-include node to network
[2014-12-16 21:21:49.852] [D] [zway] RECEIVED: ( 01 07 00 4A 11 06 12 00 B7 )
[2014-12-16 21:21:49.854] [D] [zway] SENT ACK
[2014-12-16 21:21:49.855] [I] [zway] Job 0x4a (Add/re-include node to network): Done
[2014-12-16 21:21:49.857] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2014-12-16 21:21:49.858] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-16 21:21:49.859] [I] [zway] Removing job: Add/re-include node to network
[2014-12-16 21:21:49.871] [D] [zway] SENDING: ( 01 04 00 41 12 A8 )
[2014-12-16 21:21:49.874] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.876] [D] [zway] RECEIVED: ( 01 09 01 41 53 9C 00 04 20 01 5C )
[2014-12-16 21:21:49.877] [D] [zway] SENT ACK
[2014-12-16 21:21:49.878] [D] [zway] SETDATA devices.18.data.basicType = 4 (0x00000004)
[2014-12-16 21:21:49.882] [D] [zway] SETDATA devices.18.data.genericType = 32 (0x00000020)
[2014-12-16 21:21:49.883] [D] [zway] SETDATA devices.18.data.specificType = 1 (0x00000001)
[2014-12-16 21:21:49.889] [D] [zway] SETDATA devices.18.data.deviceTypeString = "Routing Binary Sensor"
[2014-12-16 21:21:49.890] [D] [zway] SETDATA devices.18.data.isRouting = True
[2014-12-16 21:21:49.891] [D] [zway] SETDATA devices.18.data.isListening = False
[2014-12-16 21:21:49.892] [D] [zway] SETDATA devices.18.data.optional = True
[2014-12-16 21:21:49.894] [D] [zway] SETDATA devices.18.data.sensor1000 = False
[2014-12-16 21:21:49.896] [D] [zway] SETDATA devices.18.data.sensor250 = False
[2014-12-16 21:21:49.897] [D] [zway] SETDATA devices.18.data.infoProtocolSpecific = 5479424 (0x00539c00)
[2014-12-16 21:21:49.899] [D] [zway] Job 0x41 (Get node protocol information): success
[2014-12-16 21:21:49.900] [I] [zway] Removing job: Get node protocol information
[2014-12-16 21:21:49.916] [D] [zway] SENDING: ( 01 06 00 80 01 00 00 78 )
[2014-12-16 21:21:49.918] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.922] [D] [zway] RECEIVED: ( 01 20 01 80 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4A )
[2014-12-16 21:21:49.923] [D] [zway] SENT ACK
[2014-12-16 21:21:49.925] [D] [zway] SETDATA devices.1.data.neighbours = byte[2]
[2014-12-16 21:21:49.926] [D] [zway]   ( 0B 0D )
[2014-12-16 21:21:49.927] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ 0b 0d ]
[2014-12-16 21:21:49.928] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:49.930] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:49.934] [D] [zway] SENDING: ( 01 06 00 80 0B 00 00 72 )
[2014-12-16 21:21:49.936] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.940] [D] [zway] RECEIVED: ( 01 20 01 80 01 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F )
[2014-12-16 21:21:49.942] [D] [zway] SENT ACK
[2014-12-16 21:21:49.943] [D] [zway] SETDATA devices.11.data.neighbours = byte[2]
[2014-12-16 21:21:49.944] [D] [zway]   ( 01 0D )
[2014-12-16 21:21:49.947] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 11: [ 01 0d ]
[2014-12-16 21:21:49.948] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:49.949] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:49.952] [D] [zway] SENDING: ( 01 06 00 80 0D 00 00 74 )
[2014-12-16 21:21:49.954] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.962] [D] [zway] RECEIVED: ( 01 20 01 80 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5B )
[2014-12-16 21:21:49.963] [D] [zway] SENT ACK
[2014-12-16 21:21:49.964] [D] [zway] SETDATA devices.13.data.neighbours = byte[2]
[2014-12-16 21:21:49.966] [D] [zway]   ( 01 0B )
[2014-12-16 21:21:49.967] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 13: [ 01 0b ]
[2014-12-16 21:21:49.968] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:49.970] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:49.982] [D] [zway] SENDING: ( 01 06 00 80 0F 00 00 76 )
[2014-12-16 21:21:49.985] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:49.988] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-16 21:21:49.990] [D] [zway] SENT ACK
[2014-12-16 21:21:49.992] [D] [zway] SETDATA devices.15.data.neighbours = byte[0]
[2014-12-16 21:21:49.993] [D] [zway]   ( zero-length buffer )
[2014-12-16 21:21:49.994] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 15: [ ]
[2014-12-16 21:21:49.995] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:49.998] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:49.999] [D] [zway] SENDING: ( 01 06 00 80 10 00 00 69 )
[2014-12-16 21:21:50.002] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:50.005] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-16 21:21:50.007] [D] [zway] SENT ACK
[2014-12-16 21:21:50.008] [D] [zway] SETDATA devices.16.data.neighbours = byte[0]
[2014-12-16 21:21:50.010] [D] [zway]   ( zero-length buffer )
[2014-12-16 21:21:50.011] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 16: [ ]
[2014-12-16 21:21:50.012] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:50.013] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:50.015] [D] [zway] SENDING: ( 01 06 00 80 11 00 00 68 )
[2014-12-16 21:21:50.017] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:50.021] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-16 21:21:50.023] [D] [zway] SENT ACK
[2014-12-16 21:21:50.024] [D] [zway] SETDATA devices.17.data.neighbours = byte[0]
[2014-12-16 21:21:50.025] [D] [zway]   ( zero-length buffer )
[2014-12-16 21:21:50.026] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 17: [ ]
[2014-12-16 21:21:50.028] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:50.028] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:50.030] [D] [zway] SENDING: ( 01 06 00 80 12 00 00 6B )
[2014-12-16 21:21:50.038] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:50.039] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-16 21:21:50.041] [D] [zway] SENT ACK
[2014-12-16 21:21:50.042] [D] [zway] SETDATA devices.18.data.neighbours = byte[0]
[2014-12-16 21:21:50.045] [D] [zway]   ( zero-length buffer )
[2014-12-16 21:21:50.046] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 18: [ ]
[2014-12-16 21:21:50.046] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-16 21:21:50.047] [I] [zway] Removing job: Get routing table line
[2014-12-16 21:21:50.060] [D] [zway] SENDING (cb 0x12): ( 01 0A 00 13 12 03 86 13 20 25 12 75 )
[2014-12-16 21:21:50.065] [D] [zway] RECEIVED ACK
[2014-12-16 21:21:50.069] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-16 21:21:50.069] [D] [zway] SENT ACK
[2014-12-16 21:21:50.069] [D] [zway] Delivered to Z-Wave stack
[2014-12-16 21:21:54.223] [D] [zway] RECEIVED: ( 01 05 00 13 12 01 FA )
[2014-12-16 21:21:54.224] [D] [zway] SENT ACK
[2014-12-16 21:21:54.224] [I] [zway] Job 0x13 (Basic Version Get): Not delivered to recipient
[2014-12-16 21:21:54.224] [D] [zway] SETDATA devices.18.data.lastPacketInfo.delivered = False
[2014-12-16 21:21:54.225] [D] [zway] SETDATA devices.18.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-16 21:21:54.225] [D] [zway] SETDATA devices.18.data.lastPacketInfo.deliveryTime = 4154 (0x0000103a)
[2014-12-16 21:21:54.225] [D] [zway] SETDATA devices.18.data.lastPacketInfo = **********
[2014-12-16 21:21:54.226] [D] [zway] SETDATA devices.18.data.isAwake = False
[2014-12-16 21:21:54.226] [D] [zway] Sending the queue for node 18 into sleep
[2014-12-16 21:22:01.789] [D] [zway] Job 0x62: deleted from queue
[2014-12-16 21:22:10.046] [D] [zway] Job 0x4a: deleted from queue
[2014-12-16 21:22:10.079] [D] [zway] Job 0x4a: deleted from queue
[2014-12-16 21:22:10.090] [D] [zway] Job 0x41: deleted from queue
[2014-12-16 21:22:10.101] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.112] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.122] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.133] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.155] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.166] [D] [zway] Job 0x80: deleted from queue
[2014-12-16 21:22:10.178] [D] [zway] Job 0x80: deleted from queue
Do you have a clue what is going on here or is this device broken?
Try ti exclude it first the same way
Tiptop
Post by Tiptop »
Hmmm... I still have serious trouble with this device.
To being 100% able to rule out the possibility that the batteries might cause the problems, I connected the device to a laboratory power supply with 4.5V (connected to the battery holder).
1. Exclusion worked normally:
[2014-12-22 16:00:30.960] [I] [zway] Adding job: Remove node from network
[2014-12-22 16:00:30.965] [D] [zway] SENDING (cb 0x0d): ( 01 05 00 4B C1 0D 7D )
[2014-12-22 16:00:30.968] [D] [zway] RECEIVED ACK
[2014-12-22 16:00:30.970] [D] [zway] RECEIVED: ( 01 07 00 4B 0D 01 00 00 BF )
[2014-12-22 16:00:30.971] [D] [zway] SENT ACK
[2014-12-22 16:00:30.972] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-22 16:00:30.974] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-22 16:00:30.979] [I] [zway] Job 0x4b (Remove node from network): Ready to remove - push button on the device to be removed
[2014-12-22 16:00:30.981] [D] [zway] SETDATA controller.data.controllerState = 5 (0x00000005)
[2014-12-22 16:00:33.800] [D] [zway] RECEIVED: ( 01 07 00 4B 0D 02 00 00 BC )
[2014-12-22 16:00:33.801] [D] [zway] SENT ACK
[2014-12-22 16:00:33.801] [I] [zway] Job 0x4b (Remove node from network): Node found: #0
[2014-12-22 16:00:33.801] [D] [zway] SETDATA controller.data.controllerState = 6 (0x00000006)
[2014-12-22 16:00:33.801] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2014-12-22 16:00:34.293] [D] [zway] RECEIVED: ( 01 16 00 4B 0D 03 00 0F 04 20 01 30 31 85 9B 70 84 80 72 86 EF 20 60 B6 )
[2014-12-22 16:00:34.294] [D] [zway] SENT ACK
[2014-12-22 16:00:34.295] [I] [zway] Job 0x4b (Remove node from network): Removing slave: #0
[2014-12-22 16:00:34.297] [D] [zway] SETDATA controller.data.controllerState = 7 (0x00000007)
[2014-12-22 16:00:34.300] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2014-12-22 16:00:34.302] [D] [zway] RECEIVED: ( 01 16 00 4B 0D 06 00 0F 04 20 01 30 31 85 9B 70 84 80 72 86 EF 20 60 B3 )
[2014-12-22 16:00:34.303] [D] [zway] SENT ACK
[2014-12-22 16:00:34.304] [I] [zway] Job 0x4b (Remove node from network): Done
[2014-12-22 16:00:34.307] [D] [zway] Job 0x4b (Remove node from network): success
[2014-12-22 16:00:34.308] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-22 16:00:34.309] [I] [zway] Removing job: Remove node from network
[2014-12-22 16:00:54.411] [D] [zway] Job 0x4b: deleted from queue
Tiptop
Post by Tiptop »
2. The inclusion stopped again after the interview was fully complete - the device fell asleep during the interview!
Here is part 1 of 2 of the inclusion:
[2014-12-22 16:05:16.916] [I] [zway] Adding job: Add/re-include node to network
[2014-12-22 16:05:16.918] [D] [zway] SENDING (cb 0x0f): ( 01 05 00 4A C1 0F 7E )
[2014-12-22 16:05:16.920] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:16.922] [D] [zway] RECEIVED: ( 01 07 00 4A 0F 01 00 00 BC )
[2014-12-22 16:05:16.924] [D] [zway] SENT ACK
[2014-12-22 16:05:16.925] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-22 16:05:16.927] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-22 16:05:16.928] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-12-22 16:05:16.930] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-12-22 16:05:19.741] [D] [zway] RECEIVED: ( 01 07 00 4A 0F 02 00 00 BF )
[2014-12-22 16:05:19.741] [D] [zway] SENT ACK
[2014-12-22 16:05:19.742] [I] [zway] Job 0x4a (Add/re-include node to network): Node found: #0
[2014-12-22 16:05:19.742] [D] [zway] SETDATA controller.data.controllerState = 2 (0x00000002)
[2014-12-22 16:05:19.845] [D] [zway] RECEIVED: ( 01 16 00 4A 0F 03 13 0F 04 20 01 30 31 85 9B 70 84 80 72 86 EF 20 60 A6 )
[2014-12-22 16:05:19.847] [D] [zway] SENT ACK
[2014-12-22 16:05:19.848] [I] [zway] Job 0x4a (Add/re-include node to network): Adding slave: #19
[2014-12-22 16:05:19.850] [D] [zway] SETDATA controller.data.controllerState = 3 (0x00000003)
[2014-12-22 16:05:19.851] [D] [zway] SETDATA controller.data.lastIncludedDevice = 19 (0x00000013)
[2014-12-22 16:05:19.852] [D] [zway] SETDATA devices.19.data = Empty
[2014-12-22 16:05:19.853] [D] [zway] SETDATA devices.19.instances.0.data = Empty
[2014-12-22 16:05:19.853] [D] [zway] SETDATA devices.19.instances.0.data.dynamic = Empty
[2014-12-22 16:05:19.854] [D] [zway] SETDATA devices.19.instances.0.data.dynamic = False
[2014-12-22 16:05:19.856] [D] [zway] SETDATA devices.19.instances.0.data.genericType = Empty
[2014-12-22 16:05:19.856] [D] [zway] SETDATA devices.19.instances.0.data.genericType = 0 (0x00000000)
[2014-12-22 16:05:19.858] [D] [zway] SETDATA devices.19.instances.0.data.specificType = Empty
[2014-12-22 16:05:19.858] [D] [zway] SETDATA devices.19.instances.0.data.specificType = 0 (0x00000000)
[2014-12-22 16:05:19.859] [D] [zway] SETDATA devices.19.data.basicType = Empty
[2014-12-22 16:05:19.860] [D] [zway] SETDATA devices.19.data.genericType = Empty
[2014-12-22 16:05:19.861] [D] [zway] SETDATA devices.19.data.specificType = Empty
[2014-12-22 16:05:19.864] [D] [zway] SETDATA devices.19.data.infoProtocolSpecific = Empty
[2014-12-22 16:05:19.865] [D] [zway] SETDATA devices.19.data.deviceTypeString = Empty
[2014-12-22 16:05:19.866] [D] [zway] SETDATA devices.19.data.isVirtual = Empty
[2014-12-22 16:05:19.867] [D] [zway] SETDATA devices.19.data.isListening = Empty
[2014-12-22 16:05:19.867] [D] [zway] SETDATA devices.19.data.isRouting = Empty
[2014-12-22 16:05:19.868] [D] [zway] SETDATA devices.19.data.isAwake = Empty
[2014-12-22 16:05:19.869] [D] [zway] SETDATA devices.19.data.optional = Empty
[2014-12-22 16:05:19.870] [D] [zway] SETDATA devices.19.data.isFailed = Empty
[2014-12-22 16:05:19.872] [D] [zway] SETDATA devices.19.data.beam = Empty
[2014-12-22 16:05:19.873] [D] [zway] SETDATA devices.19.data.sensor250 = Empty
[2014-12-22 16:05:19.873] [D] [zway] SETDATA devices.19.data.sensor1000 = Empty
[2014-12-22 16:05:19.874] [D] [zway] SETDATA devices.19.data.neighbours = Empty
[2014-12-22 16:05:19.875] [D] [zway] SETDATA devices.19.data.manufacturerId = Empty
[2014-12-22 16:05:19.876] [D] [zway] SETDATA devices.19.data.vendorString = Empty
[2014-12-22 16:05:19.878] [D] [zway] SETDATA devices.19.data.manufacturerProductType = Empty
[2014-12-22 16:05:19.878] [D] [zway] SETDATA devices.19.data.manufacturerProductId = Empty
[2014-12-22 16:05:19.879] [D] [zway] SETDATA devices.19.data.ZWLib = Empty
[2014-12-22 16:05:19.881] [D] [zway] SETDATA devices.19.data.ZWProtocolMajor = Empty
[2014-12-22 16:05:19.882] [D] [zway] SETDATA devices.19.data.ZWProtocolMinor = Empty
[2014-12-22 16:05:19.882] [D] [zway] SETDATA devices.19.data.SDK = Empty
[2014-12-22 16:05:19.883] [D] [zway] SETDATA devices.19.data.applicationMajor = Empty
[2014-12-22 16:05:19.885] [D] [zway] SETDATA devices.19.data.applicationMinor = Empty
[2014-12-22 16:05:19.886] [D] [zway] SETDATA devices.19.data.nodeInfoFrame = Empty
[2014-12-22 16:05:19.887] [D] [zway] SETDATA devices.19.data.ZDDXMLFile = Empty
[2014-12-22 16:05:19.888] [D] [zway] SETDATA devices.19.data.lastSend = Empty
[2014-12-22 16:05:19.890] [D] [zway] SETDATA devices.19.data.lastNonceGet = Empty
[2014-12-22 16:05:19.891] [D] [zway] SETDATA devices.19.data.lastReceived = Empty
[2014-12-22 16:05:19.893] [D] [zway] SETDATA devices.19.data.failureCount = Empty
[2014-12-22 16:05:19.894] [D] [zway] SETDATA devices.19.data.keepAwake = Empty
[2014-12-22 16:05:19.895] [D] [zway] SETDATA devices.19.data.countSuccess = Empty
[2014-12-22 16:05:19.896] [D] [zway] SETDATA devices.19.data.countFailed = Empty
[2014-12-22 16:05:19.896] [D] [zway] SETDATA devices.19.data.queueLength = Empty
[2014-12-22 16:05:19.898] [D] [zway] SETDATA devices.19.data.givenName = Empty
[2014-12-22 16:05:19.899] [D] [zway] SETDATA devices.19.data.lastPacketInfo = Empty
[2014-12-22 16:05:19.900] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = Empty
[2014-12-22 16:05:19.901] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = Empty
[2014-12-22 16:05:19.903] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = Empty
[2014-12-22 16:05:19.903] [D] [zway] SETDATA devices.19.data.basicType = 0 (0x00000000)
[2014-12-22 16:05:19.904] [D] [zway] SETDATA devices.19.data.genericType = 0 (0x00000000)
[2014-12-22 16:05:19.905] [D] [zway] SETDATA devices.19.data.specificType = 0 (0x00000000)
[2014-12-22 16:05:19.906] [D] [zway] SETDATA devices.19.data.infoProtocolSpecific = 0 (0x00000000)
[2014-12-22 16:05:19.907] [D] [zway] SETDATA devices.19.data.deviceTypeString = ""
[2014-12-22 16:05:19.907] [D] [zway] SETDATA devices.19.data.isVirtual = False
[2014-12-22 16:05:19.908] [D] [zway] SETDATA devices.19.data.isListening = True
[2014-12-22 16:05:19.908] [D] [zway] SETDATA devices.19.data.isRouting = False
[2014-12-22 16:05:19.909] [D] [zway] SETDATA devices.19.data.isAwake = False
[2014-12-22 16:05:19.910] [D] [zway] SETDATA devices.19.data.optional = False
[2014-12-22 16:05:19.911] [D] [zway] SETDATA devices.19.data.isFailed = False
[2014-12-22 16:05:19.912] [D] [zway] SETDATA devices.19.data.beam = False
[2014-12-22 16:05:19.913] [D] [zway] SETDATA devices.19.data.sensor250 = False
[2014-12-22 16:05:19.915] [D] [zway] SETDATA devices.19.data.sensor1000 = False
[2014-12-22 16:05:19.915] [D] [zway] SETDATA devices.19.data.neighbours = Empty
[2014-12-22 16:05:19.916] [D] [zway] SETDATA devices.19.data.manufacturerId = 0 (0x00000000)
[2014-12-22 16:05:19.917] [D] [zway] SETDATA devices.19.data.manufacturerProductType = 0 (0x00000000)
[2014-12-22 16:05:19.917] [D] [zway] SETDATA devices.19.data.manufacturerProductId = 0 (0x00000000)
[2014-12-22 16:05:19.919] [D] [zway] SETDATA devices.19.data.applicationMajor = 0 (0x00000000)
[2014-12-22 16:05:19.920] [D] [zway] SETDATA devices.19.data.applicationMinor = 0 (0x00000000)
[2014-12-22 16:05:19.921] [D] [zway] SETDATA devices.19.data.ZWProtocolMajor = 0 (0x00000000)
[2014-12-22 16:05:19.921] [D] [zway] SETDATA devices.19.data.ZWProtocolMinor = 0 (0x00000000)
[2014-12-22 16:05:19.922] [D] [zway] SETDATA devices.19.data.ZWLib = 0 (0x00000000)
[2014-12-22 16:05:19.924] [D] [zway] SETDATA devices.19.data.SDK = ""
[2014-12-22 16:05:19.924] [D] [zway] SETDATA devices.19.data.vendorString = ""
[2014-12-22 16:05:19.925] [D] [zway] SETDATA devices.19.data.nodeInfoFrame = Empty
[2014-12-22 16:05:19.926] [D] [zway] SETDATA devices.19.data.ZDDXMLFile = ""
[2014-12-22 16:05:19.927] [D] [zway] SETDATA devices.19.data.keepAwake = False
[2014-12-22 16:05:19.931] [D] [zway] SETDATA devices.19.data.countSuccess = 0 (0x00000000)
[2014-12-22 16:05:19.933] [D] [zway] SETDATA devices.19.data.countFailed = 0 (0x00000000)
[2014-12-22 16:05:19.934] [D] [zway] SETDATA devices.19.data.queueLength = 0 (0x00000000)
[2014-12-22 16:05:19.936] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:19.937] [D] [zway] SETDATA devices.19.data.lastSend = 0 (0x00000000)
[2014-12-22 16:05:19.938] [D] [zway] SETDATA devices.19.data.failureCount = 0 (0x00000000)
[2014-12-22 16:05:19.939] [D] [zway] SETDATA devices.19.data.givenName = ""
[2014-12-22 16:05:19.940] [I] [zway] Adding job: Get node protocol information
[2014-12-22 16:05:19.941] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.942] [I] [zway] Adding job: Check if node is failed
[2014-12-22 16:05:19.944] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.951] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.952] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.953] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.955] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.957] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.958] [I] [zway] Adding job: Get routing table line
[2014-12-22 16:05:19.959] [D] [zway] Job 0x80 (Get routing table line): removing duplicate
[2014-12-22 16:05:19.961] [D] [zway] SETDATA devices.19.data.basicType = 4 (0x00000004)
[2014-12-22 16:05:19.962] [D] [zway] SETDATA devices.19.data.genericType = 32 (0x00000020)
[2014-12-22 16:05:19.964] [D] [zway] SETDATA devices.19.instances.0.data.genericType = 32 (0x00000020)
[2014-12-22 16:05:19.965] [D] [zway] SETDATA devices.19.data.specificType = 1 (0x00000001)
[2014-12-22 16:05:19.966] [D] [zway] SETDATA devices.19.instances.0.data.specificType = 1 (0x00000001)
[2014-12-22 16:05:19.971] [D] [zway] SETDATA devices.19.data.deviceTypeString = "Routing Binary Sensor"
[2014-12-22 16:05:19.972] [D] [zway] SETDATA devices.19.data.nodeInfoFrame = byte[12]
[2014-12-22 16:05:19.973] [D] [zway]   ( 30 31 85 9B 70 84 80 72 86 EF 20 60 )
[2014-12-22 16:05:19.982] [D] [zway] SENDING: ( 01 04 00 62 13 8A )
[2014-12-22 16:05:19.987] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:19.988] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2014-12-22 16:05:19.990] [D] [zway] SENT ACK
[2014-12-22 16:05:19.991] [D] [zway] SETDATA devices.19.data.isFailed = False
[2014-12-22 16:05:19.997] [I] [zway] Job 0x62 (Check if node is failed): Node 19 is operating
[2014-12-22 16:05:19.998] [D] [zway] Job 0x62 (Check if node is failed): success
[2014-12-22 16:05:20.000] [I] [zway] Removing job: Check if node is failed
[2014-12-22 16:05:20.580] [D] [zway] RECEIVED: ( 01 07 00 4A 0F 05 13 00 AB )
[2014-12-22 16:05:20.581] [D] [zway] SENT ACK
[2014-12-22 16:05:20.581] [D] [zway] SETDATA controller.data.controllerState = 4 (0x00000004)
[2014-12-22 16:05:20.581] [I] [zway] Job 0x4a (Add/re-include node to network): Protocol done
[2014-12-22 16:05:20.581] [I] [zway] Loading Command Classes for device 19
[2014-12-22 16:05:20.581] [I] [zway] Node 19:0 supports CC Basic
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data = Empty
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.supported = Empty
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.supported = True
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.version = Empty
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.582] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.security = Empty
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.security = False
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewDone = Empty
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewCounter = Empty
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewDone = False
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.level = Empty
[2014-12-22 16:05:20.584] [I] [zway] Node 19:0 supports CC SensorBinary
[2014-12-22 16:05:20.584] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data = Empty
[2014-12-22 16:05:20.584] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.supported = Empty
[2014-12-22 16:05:20.584] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.supported = True
[2014-12-22 16:05:20.585] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.version = Empty
[2014-12-22 16:05:20.585] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.585] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.security = Empty
[2014-12-22 16:05:20.585] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.security = False
[2014-12-22 16:05:20.585] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewDone = Empty
[2014-12-22 16:05:20.586] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewCounter = Empty
[2014-12-22 16:05:20.586] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewDone = False
[2014-12-22 16:05:20.586] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.586] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.typemask = Empty
[2014-12-22 16:05:20.586] [I] [zway] Node 19:0 supports CC SensorMultilevel
[2014-12-22 16:05:20.593] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data = Empty
[2014-12-22 16:05:20.595] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.supported = Empty
[2014-12-22 16:05:20.596] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.supported = True
[2014-12-22 16:05:20.597] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.version = Empty
[2014-12-22 16:05:20.598] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.604] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.security = Empty
[2014-12-22 16:05:20.605] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.security = False
[2014-12-22 16:05:20.606] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewDone = Empty
[2014-12-22 16:05:20.607] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewCounter = Empty
[2014-12-22 16:05:20.609] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewDone = False
[2014-12-22 16:05:20.610] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.610] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.typemask = Empty
[2014-12-22 16:05:20.612] [I] [zway] Node 19:0 supports CC Configuration
[2014-12-22 16:05:20.613] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data = Empty
[2014-12-22 16:05:20.614] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.supported = Empty
[2014-12-22 16:05:20.614] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.supported = True
[2014-12-22 16:05:20.615] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.version = Empty
[2014-12-22 16:05:20.616] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.617] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.security = Empty
[2014-12-22 16:05:20.618] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.security = False
[2014-12-22 16:05:20.619] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewDone = Empty
[2014-12-22 16:05:20.620] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewCounter = Empty
[2014-12-22 16:05:20.621] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewDone = False
[2014-12-22 16:05:20.621] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.622] [I] [zway] Node 19:0 supports CC ManufacturerSpecific
[2014-12-22 16:05:20.623] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data = Empty
[2014-12-22 16:05:20.624] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.supported = Empty
[2014-12-22 16:05:20.625] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.supported = True
[2014-12-22 16:05:20.626] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.version = Empty
[2014-12-22 16:05:20.626] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.630] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.security = Empty
[2014-12-22 16:05:20.631] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.security = False
[2014-12-22 16:05:20.632] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewDone = Empty
[2014-12-22 16:05:20.633] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewCounter = Empty
[2014-12-22 16:05:20.634] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewDone = False
[2014-12-22 16:05:20.636] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.638] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.vendorId = Empty
[2014-12-22 16:05:20.639] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.vendor = Empty
[2014-12-22 16:05:20.640] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.productId = Empty
[2014-12-22 16:05:20.641] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.productType = Empty
[2014-12-22 16:05:20.641] [I] [zway] Node 19:0 supports CC Battery
[2014-12-22 16:05:20.643] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data = Empty
[2014-12-22 16:05:20.644] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.supported = Empty
[2014-12-22 16:05:20.645] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.supported = True
[2014-12-22 16:05:20.646] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.version = Empty
[2014-12-22 16:05:20.647] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.648] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.security = Empty
[2014-12-22 16:05:20.648] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.security = False
[2014-12-22 16:05:20.650] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewDone = Empty
[2014-12-22 16:05:20.651] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewCounter = Empty
[2014-12-22 16:05:20.652] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewDone = False
[2014-12-22 16:05:20.652] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.653] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.lastChange = Empty
[2014-12-22 16:05:20.654] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.history = Empty
[2014-12-22 16:05:20.656] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.last = Empty
[2014-12-22 16:05:20.656] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.last = 0 (0x00000000)
[2014-12-22 16:05:20.658] [I] [zway] Node 19:0 supports CC Wakeup
[2014-12-22 16:05:20.658] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data = Empty
[2014-12-22 16:05:20.663] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.supported = Empty
[2014-12-22 16:05:20.665] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.supported = True
[2014-12-22 16:05:20.666] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.version = Empty
[2014-12-22 16:05:20.666] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.667] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.security = Empty
[2014-12-22 16:05:20.668] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.security = False
[2014-12-22 16:05:20.669] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewDone = Empty
[2014-12-22 16:05:20.670] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewCounter = Empty
[2014-12-22 16:05:20.670] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewDone = False
[2014-12-22 16:05:20.671] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.672] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interval = Empty
[2014-12-22 16:05:20.673] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.nodeId = Empty
[2014-12-22 16:05:20.674] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.min = Empty
[2014-12-22 16:05:20.675] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.max = Empty
[2014-12-22 16:05:20.675] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.default = Empty
[2014-12-22 16:05:20.677] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.step = Empty
[2014-12-22 16:05:20.678] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.lastWakeup = Empty
[2014-12-22 16:05:20.679] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.lastSleep = Empty
[2014-12-22 16:05:20.679] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interval = 0 (0x00000000)
[2014-12-22 16:05:20.681] [I] [zway] Node 19:0 supports CC Association
[2014-12-22 16:05:20.681] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data = Empty
[2014-12-22 16:05:20.683] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.supported = Empty
[2014-12-22 16:05:20.683] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.supported = True
[2014-12-22 16:05:20.683] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.version = Empty
[2014-12-22 16:05:20.684] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.686] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.security = Empty
[2014-12-22 16:05:20.687] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.security = False
[2014-12-22 16:05:20.688] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewDone = Empty
[2014-12-22 16:05:20.689] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewCounter = Empty
[2014-12-22 16:05:20.690] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewDone = False
[2014-12-22 16:05:20.690] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.692] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.groups = Empty
[2014-12-22 16:05:20.692] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.specificGroup = Empty
[2014-12-22 16:05:20.694] [I] [zway] Node 19:0 supports CC Version
[2014-12-22 16:05:20.694] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data = Empty
[2014-12-22 16:05:20.695] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.supported = Empty
[2014-12-22 16:05:20.696] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.supported = True
[2014-12-22 16:05:20.696] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.version = Empty
[2014-12-22 16:05:20.697] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-12-22 16:05:20.699] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.security = Empty
[2014-12-22 16:05:20.699] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.security = False
[2014-12-22 16:05:20.701] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewDone = Empty
[2014-12-22 16:05:20.701] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewCounter = Empty
[2014-12-22 16:05:20.702] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewDone = False
[2014-12-22 16:05:20.703] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2014-12-22 16:05:20.704] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWLib = Empty
[2014-12-22 16:05:20.705] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2014-12-22 16:05:20.705] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2014-12-22 16:05:20.706] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.SDK = Empty
[2014-12-22 16:05:20.708] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.applicationMajor = Empty
[2014-12-22 16:05:20.709] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.applicationMinor = Empty
[2014-12-22 16:05:20.710] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-12-22 16:05:20.710] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.firmwareCount = Empty
[2014-12-22 16:05:20.711] [D] [zway] Node 19:0 supports CC UNKNOWN 0x9b
[2014-12-22 16:05:20.712] [D] [zway] SETDATA devices.19.data.lastSend = 338088 (0x000528a8)
[2014-12-22 16:05:20.713] [D] [zway] SETDATA devices.19.data.isAwake = True
[2014-12-22 16:05:20.714] [D] [zway] SETDATA devices.19.data.lastSend = 337988 (0x00052844)
[2014-12-22 16:05:20.714] [D] [zway] SETDATA devices.19.data.lastNonceGet = 336988 (0x0005245c)
[2014-12-22 16:05:20.716] [I] [zway] Interview step 1 skipped due to absence of Security CC
[2014-12-22 16:05:20.718] [I] [zway] Interview step 2
[2014-12-22 16:05:20.719] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewDone = False
[2014-12-22 16:05:20.719] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:20.720] [I] [zway] Node 19:0 CC Version Interview started
[2014-12-22 16:05:20.722] [I] [zway] Adding job: Basic Version Get
[2014-12-22 16:05:20.723] [I] [zway] Adding job: SensorBinary Version Get
[2014-12-22 16:05:20.724] [I] [zway] Adding job: SensorMultilevel Version Get
[2014-12-22 16:05:20.725] [I] [zway] Adding job: Configuration Version Get
[2014-12-22 16:05:20.727] [I] [zway] Adding job: ManufacturerSpecific Version Get
[2014-12-22 16:05:20.729] [I] [zway] Adding job: Battery Version Get
[2014-12-22 16:05:20.730] [I] [zway] Adding job: Wakeup Version Get
[2014-12-22 16:05:20.732] [I] [zway] Adding job: Association Version Get
[2014-12-22 16:05:20.733] [I] [zway] Adding job: Version Version Get
[2014-12-22 16:05:20.735] [D] [zway] Running wakeup handler for node 19
[2014-12-22 16:05:20.736] [I] [zway] Adding job: Add/re-include node to network
[2014-12-22 16:05:20.743] [D] [zway] SENDING: ( 01 04 00 4A 05 B4 )
[2014-12-22 16:05:20.745] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.746] [I] [zway] Removing job: Add/re-include node to network
[2014-12-22 16:05:20.795] [D] [zway] RECEIVED: ( 01 07 00 4A 0F 06 13 00 A8 )
[2014-12-22 16:05:20.796] [D] [zway] SENT ACK
[2014-12-22 16:05:20.798] [I] [zway] Job 0x4a (Add/re-include node to network): Done
[2014-12-22 16:05:20.799] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2014-12-22 16:05:20.800] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-22 16:05:20.801] [I] [zway] Removing job: Add/re-include node to network
[2014-12-22 16:05:20.802] [D] [zway] SENDING: ( 01 04 00 41 13 A9 )
[2014-12-22 16:05:20.805] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.807] [D] [zway] RECEIVED: ( 01 09 01 41 53 9C 00 04 20 01 5C )
[2014-12-22 16:05:20.808] [D] [zway] SENT ACK
[2014-12-22 16:05:20.809] [D] [zway] SETDATA devices.19.data.basicType = 4 (0x00000004)
[2014-12-22 16:05:20.811] [D] [zway] SETDATA devices.19.data.genericType = 32 (0x00000020)
[2014-12-22 16:05:20.816] [D] [zway] SETDATA devices.19.data.specificType = 1 (0x00000001)
[2014-12-22 16:05:20.820] [D] [zway] SETDATA devices.19.data.deviceTypeString = "Routing Binary Sensor"
[2014-12-22 16:05:20.824] [D] [zway] SETDATA devices.19.data.isRouting = True
[2014-12-22 16:05:20.825] [D] [zway] SETDATA devices.19.data.isListening = False
[2014-12-22 16:05:20.827] [D] [zway] SETDATA devices.19.data.optional = True
[2014-12-22 16:05:20.828] [D] [zway] SETDATA devices.19.data.sensor1000 = False
[2014-12-22 16:05:20.829] [D] [zway] SETDATA devices.19.data.sensor250 = False
[2014-12-22 16:05:20.831] [D] [zway] SETDATA devices.19.data.infoProtocolSpecific = 5479424 (0x00539c00)
[2014-12-22 16:05:20.832] [D] [zway] Job 0x41 (Get node protocol information): success
[2014-12-22 16:05:20.833] [I] [zway] Removing job: Get node protocol information
[2014-12-22 16:05:20.849] [D] [zway] SENDING: ( 01 06 00 80 01 00 00 78 )
[2014-12-22 16:05:20.852] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.855] [D] [zway] RECEIVED: ( 01 20 01 80 00 14 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E )
[2014-12-22 16:05:20.856] [D] [zway] SENT ACK
[2014-12-22 16:05:20.858] [D] [zway] SETDATA devices.1.data.neighbours = byte[3]
[2014-12-22 16:05:20.860] [D] [zway]   ( 0B 0D 13 )
[2014-12-22 16:05:20.861] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ 0b 0d 13 ]
[2014-12-22 16:05:20.862] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.863] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.865] [D] [zway] SENDING: ( 01 06 00 80 0B 00 00 72 )
[2014-12-22 16:05:20.868] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.871] [D] [zway] RECEIVED: ( 01 20 01 80 01 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F )
[2014-12-22 16:05:20.873] [D] [zway] SENT ACK
[2014-12-22 16:05:20.878] [D] [zway] SETDATA devices.11.data.neighbours = byte[2]
[2014-12-22 16:05:20.880] [D] [zway]   ( 01 0D )
[2014-12-22 16:05:20.881] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 11: [ 01 0d ]
[2014-12-22 16:05:20.883] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.884] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.889] [D] [zway] SENDING: ( 01 06 00 80 0D 00 00 74 )
[2014-12-22 16:05:20.892] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.896] [D] [zway] RECEIVED: ( 01 20 01 80 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5B )
[2014-12-22 16:05:20.898] [D] [zway] SENT ACK
[2014-12-22 16:05:20.899] [D] [zway] SETDATA devices.13.data.neighbours = byte[2]
[2014-12-22 16:05:20.900] [D] [zway]   ( 01 0B )
[2014-12-22 16:05:20.902] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 13: [ 01 0b ]
[2014-12-22 16:05:20.903] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.904] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.906] [D] [zway] SENDING: ( 01 06 00 80 0F 00 00 76 )
[2014-12-22 16:05:20.909] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.912] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-22 16:05:20.914] [D] [zway] SENT ACK
[2014-12-22 16:05:20.915] [D] [zway] SETDATA devices.15.data.neighbours = byte[0]
[2014-12-22 16:05:20.917] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:05:20.918] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 15: [ ]
[2014-12-22 16:05:20.920] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.922] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.926] [D] [zway] SENDING: ( 01 06 00 80 10 00 00 69 )
[2014-12-22 16:05:20.928] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.934] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-22 16:05:20.935] [D] [zway] SENT ACK
[2014-12-22 16:05:20.936] [D] [zway] SETDATA devices.16.data.neighbours = byte[0]
[2014-12-22 16:05:20.938] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:05:20.942] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 16: [ ]
[2014-12-22 16:05:20.945] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.946] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.958] [D] [zway] SENDING: ( 01 06 00 80 11 00 00 68 )
[2014-12-22 16:05:20.961] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.964] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-22 16:05:20.965] [D] [zway] SENT ACK
[2014-12-22 16:05:20.967] [D] [zway] SETDATA devices.17.data.neighbours = byte[0]
[2014-12-22 16:05:20.968] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:05:20.969] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 17: [ ]
[2014-12-22 16:05:20.970] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.972] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.973] [D] [zway] SENDING: ( 01 06 00 80 12 00 00 6B )
[2014-12-22 16:05:20.976] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:20.979] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-22 16:05:20.981] [D] [zway] SENT ACK
[2014-12-22 16:05:20.982] [D] [zway] SETDATA devices.18.data.neighbours = byte[0]
[2014-12-22 16:05:20.988] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:05:20.993] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 18: [ ]
[2014-12-22 16:05:20.994] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:20.995] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:20.997] [D] [zway] SENDING: ( 01 06 00 80 13 00 00 6A )
[2014-12-22 16:05:21.000] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.003] [D] [zway] RECEIVED: ( 01 20 01 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F )
[2014-12-22 16:05:21.005] [D] [zway] SENT ACK
[2014-12-22 16:05:21.006] [D] [zway] SETDATA devices.19.data.neighbours = byte[1]
[2014-12-22 16:05:21.007] [D] [zway]   ( 01 )
[2014-12-22 16:05:21.008] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 19: [ 01 ]
[2014-12-22 16:05:21.011] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-22 16:05:21.012] [I] [zway] Removing job: Get routing table line
[2014-12-22 16:05:21.014] [D] [zway] SENDING (cb 0x10): ( 01 0A 00 13 13 03 86 13 20 25 10 76 )
[2014-12-22 16:05:21.018] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.021] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.022] [D] [zway] SENT ACK
[2014-12-22 16:05:21.023] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.034] [D] [zway] RECEIVED: ( 01 05 00 13 10 00 F9 )
[2014-12-22 16:05:21.034] [D] [zway] SENT ACK
[2014-12-22 16:05:21.034] [I] [zway] Job 0x13 (Basic Version Get): Delivered
[2014-12-22 16:05:21.035] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.035] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.035] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:05:21.035] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.036] [D] [zway] SendData Response with callback 0x10 received: received by recipient
[2014-12-22 16:05:21.036] [D] [zway] SETDATA devices.19.data.lastSend = 338020 (0x00052864)
[2014-12-22 16:05:21.036] [D] [zway] Job 0x13 (Basic Version Get): success
[2014-12-22 16:05:21.036] [I] [zway] Removing job: Basic Version Get
[2014-12-22 16:05:21.042] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 20 01 55 )
[2014-12-22 16:05:21.047] [D] [zway] SENT ACK
[2014-12-22 16:05:21.048] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.049] [I] [zway] Node 19:0 CC Version: Basic is v1
[2014-12-22 16:05:21.051] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2014-12-22 16:05:21.104] [D] [zway] SENDING (cb 0x11): ( 01 0A 00 13 13 03 86 13 30 25 11 67 )
[2014-12-22 16:05:21.107] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.110] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.111] [D] [zway] SENT ACK
[2014-12-22 16:05:21.112] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.123] [D] [zway] RECEIVED: ( 01 05 00 13 11 00 F8 )
[2014-12-22 16:05:21.126] [D] [zway] SENT ACK
[2014-12-22 16:05:21.127] [I] [zway] Job 0x13 (SensorBinary Version Get): Delivered
[2014-12-22 16:05:21.129] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.130] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.132] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2014-12-22 16:05:21.133] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.134] [D] [zway] SendData Response with callback 0x11 received: received by recipient
[2014-12-22 16:05:21.135] [D] [zway] SETDATA devices.19.data.lastSend = 338027 (0x0005286b)
[2014-12-22 16:05:21.138] [D] [zway] Job 0x13 (SensorBinary Version Get): success
[2014-12-22 16:05:21.139] [I] [zway] Removing job: SensorBinary Version Get
[2014-12-22 16:05:21.142] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 30 02 46 )
[2014-12-22 16:05:21.143] [D] [zway] SENT ACK
[2014-12-22 16:05:21.144] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.146] [I] [zway] Node 19:0 CC Version: SensorBinary is v2
[2014-12-22 16:05:21.147] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.version = 2 (0x00000002)
[2014-12-22 16:05:21.204] [D] [zway] SENDING (cb 0x12): ( 01 0A 00 13 13 03 86 13 31 25 12 65 )
[2014-12-22 16:05:21.207] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.210] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.212] [D] [zway] SENT ACK
[2014-12-22 16:05:21.213] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.223] [D] [zway] RECEIVED: ( 01 05 00 13 12 00 FB )
[2014-12-22 16:05:21.225] [D] [zway] SENT ACK
[2014-12-22 16:05:21.226] [I] [zway] Job 0x13 (SensorMultilevel Version Get): Delivered
[2014-12-22 16:05:21.227] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.229] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.230] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:05:21.232] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.238] [D] [zway] SendData Response with callback 0x12 received: received by recipient
[2014-12-22 16:05:21.239] [D] [zway] SETDATA devices.19.data.lastSend = 338034 (0x00052872)
[2014-12-22 16:05:21.242] [D] [zway] Job 0x13 (SensorMultilevel Version Get): success
[2014-12-22 16:05:21.244] [I] [zway] Removing job: SensorMultilevel Version Get
[2014-12-22 16:05:21.245] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 31 05 40 )
[2014-12-22 16:05:21.247] [D] [zway] SENT ACK
[2014-12-22 16:05:21.249] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.251] [I] [zway] Node 19:0 CC Version: SensorMultilevel is v5
[2014-12-22 16:05:21.252] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.version = 5 (0x00000005)
[2014-12-22 16:05:21.288] [D] [zway] SENDING (cb 0x13): ( 01 0A 00 13 13 03 86 13 70 25 13 25 )
[2014-12-22 16:05:21.291] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.295] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.296] [D] [zway] SENT ACK
[2014-12-22 16:05:21.298] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.309] [D] [zway] RECEIVED: ( 01 05 00 13 13 00 FA )
[2014-12-22 16:05:21.311] [D] [zway] SENT ACK
[2014-12-22 16:05:21.312] [I] [zway] Job 0x13 (Configuration Version Get): Delivered
[2014-12-22 16:05:21.314] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.316] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.319] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2014-12-22 16:05:21.321] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.323] [D] [zway] SendData Response with callback 0x13 received: received by recipient
[2014-12-22 16:05:21.324] [D] [zway] SETDATA devices.19.data.lastSend = 338041 (0x00052879)
[2014-12-22 16:05:21.325] [D] [zway] Job 0x13 (Configuration Version Get): success
[2014-12-22 16:05:21.327] [I] [zway] Removing job: Configuration Version Get
[2014-12-22 16:05:21.328] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 70 01 05 )
[2014-12-22 16:05:21.330] [D] [zway] SENT ACK
[2014-12-22 16:05:21.331] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.333] [I] [zway] Node 19:0 CC Version: Configuration is v1
[2014-12-22 16:05:21.334] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-12-22 16:05:21.392] [D] [zway] SENDING (cb 0x14): ( 01 0A 00 13 13 03 86 13 72 25 14 20 )
[2014-12-22 16:05:21.395] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.399] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.400] [D] [zway] SENT ACK
[2014-12-22 16:05:21.401] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.411] [D] [zway] RECEIVED: ( 01 05 00 13 14 00 FD )
[2014-12-22 16:05:21.412] [D] [zway] SENT ACK
[2014-12-22 16:05:21.413] [I] [zway] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2014-12-22 16:05:21.415] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.416] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.418] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:21.419] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.424] [D] [zway] SendData Response with callback 0x14 received: received by recipient
[2014-12-22 16:05:21.429] [D] [zway] SETDATA devices.19.data.lastSend = 338048 (0x00052880)
[2014-12-22 16:05:21.431] [D] [zway] Job 0x13 (ManufacturerSpecific Version Get): success
[2014-12-22 16:05:21.433] [I] [zway] Removing job: ManufacturerSpecific Version Get
[2014-12-22 16:05:21.436] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 72 01 07 )
[2014-12-22 16:05:21.437] [D] [zway] SENT ACK
[2014-12-22 16:05:21.439] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.440] [I] [zway] Node 19:0 CC Version: ManufacturerSpecific is v1
[2014-12-22 16:05:21.446] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-12-22 16:05:21.680] [D] [zway] SENDING (cb 0x15): ( 01 0A 00 13 13 03 86 13 80 25 15 D3 )
[2014-12-22 16:05:21.683] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.686] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.688] [D] [zway] SENT ACK
[2014-12-22 16:05:21.689] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.699] [D] [zway] RECEIVED: ( 01 05 00 13 15 00 FC )
[2014-12-22 16:05:21.704] [D] [zway] SENT ACK
[2014-12-22 16:05:21.706] [I] [zway] Job 0x13 (Battery Version Get): Delivered
[2014-12-22 16:05:21.707] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.709] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.711] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 16 (0x00000010)
[2014-12-22 16:05:21.713] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.715] [D] [zway] SendData Response with callback 0x15 received: received by recipient
[2014-12-22 16:05:21.719] [D] [zway] SETDATA devices.19.data.lastSend = 338075 (0x0005289b)
[2014-12-22 16:05:21.721] [D] [zway] Job 0x13 (Battery Version Get): success
[2014-12-22 16:05:21.722] [I] [zway] Removing job: Battery Version Get
[2014-12-22 16:05:21.723] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 80 01 F5 )
[2014-12-22 16:05:21.727] [D] [zway] SENT ACK
Tiptop
Re: EZMotion PIR detector - any success?
Post by Tiptop »
Here is part 2 of 2 of the inclusion:
[2014-12-22 16:05:21.729] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.731] [I] [zway] Node 19:0 CC Version: Battery is v1
[2014-12-22 16:05:21.733] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2014-12-22 16:05:21.769] [D] [zway] SENDING (cb 0x16): ( 01 0A 00 13 13 03 86 13 84 25 16 D4 )
[2014-12-22 16:05:21.773] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.775] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.777] [D] [zway] SENT ACK
[2014-12-22 16:05:21.778] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.788] [D] [zway] RECEIVED: ( 01 05 00 13 16 00 FF )
[2014-12-22 16:05:21.790] [D] [zway] SENT ACK
[2014-12-22 16:05:21.792] [I] [zway] Job 0x13 (Wakeup Version Get): Delivered
[2014-12-22 16:05:21.793] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.795] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.796] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:05:21.797] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.799] [D] [zway] SendData Response with callback 0x16 received: received by recipient
[2014-12-22 16:05:21.804] [D] [zway] SETDATA devices.19.data.lastSend = 338082 (0x000528a2)
[2014-12-22 16:05:21.805] [D] [zway] Job 0x13 (Wakeup Version Get): success
[2014-12-22 16:05:21.809] [I] [zway] Removing job: Wakeup Version Get
[2014-12-22 16:05:21.812] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 84 02 F2 )
[2014-12-22 16:05:21.813] [D] [zway] SENT ACK
[2014-12-22 16:05:21.814] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.819] [I] [zway] Node 19:0 CC Version: Wakeup is v2
[2014-12-22 16:05:21.821] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.version = 2 (0x00000002)
[2014-12-22 16:05:21.859] [D] [zway] SENDING (cb 0x17): ( 01 0A 00 13 13 03 86 13 85 25 17 D4 )
[2014-12-22 16:05:21.863] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.871] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.872] [D] [zway] SENT ACK
[2014-12-22 16:05:21.874] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.879] [D] [zway] RECEIVED: ( 01 05 00 13 17 00 FE )
[2014-12-22 16:05:21.881] [D] [zway] SENT ACK
[2014-12-22 16:05:21.883] [I] [zway] Job 0x13 (Association Version Get): Delivered
[2014-12-22 16:05:21.884] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.885] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.888] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 7 (0x00000007)
[2014-12-22 16:05:21.889] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.891] [D] [zway] SendData Response with callback 0x17 received: received by recipient
[2014-12-22 16:05:21.893] [D] [zway] SETDATA devices.19.data.lastSend = 338090 (0x000528aa)
[2014-12-22 16:05:21.895] [D] [zway] Job 0x13 (Association Version Get): success
[2014-12-22 16:05:21.897] [I] [zway] Removing job: Association Version Get
[2014-12-22 16:05:21.900] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 85 02 F3 )
[2014-12-22 16:05:21.901] [D] [zway] SENT ACK
[2014-12-22 16:05:21.902] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:21.908] [I] [zway] Node 19:0 CC Version: Association is v2
[2014-12-22 16:05:21.916] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.version = 2 (0x00000002)
[2014-12-22 16:05:21.965] [D] [zway] SENDING (cb 0x18): ( 01 0A 00 13 13 03 86 13 86 25 18 D8 )
[2014-12-22 16:05:21.971] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:21.974] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:21.975] [D] [zway] SENT ACK
[2014-12-22 16:05:21.977] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:21.986] [D] [zway] RECEIVED: ( 01 05 00 13 18 00 F1 )
[2014-12-22 16:05:21.988] [D] [zway] SENT ACK
[2014-12-22 16:05:21.989] [I] [zway] Job 0x13 (Version Version Get): Delivered
[2014-12-22 16:05:21.990] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:21.991] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:21.992] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-12-22 16:05:21.994] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:21.999] [D] [zway] SendData Response with callback 0x18 received: received by recipient
[2014-12-22 16:05:22.002] [D] [zway] SETDATA devices.19.data.lastSend = 338097 (0x000528b1)
[2014-12-22 16:05:22.003] [D] [zway] Job 0x13 (Version Version Get): success
[2014-12-22 16:05:22.004] [I] [zway] Removing job: Version Version Get
[2014-12-22 16:05:22.005] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 86 14 86 01 F3 )
[2014-12-22 16:05:22.007] [D] [zway] SENT ACK
[2014-12-22 16:05:22.008] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:22.010] [I] [zway] Node 19:0 CC Version: Version is v1
[2014-12-22 16:05:22.011] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-12-22 16:05:22.012] [I] [zway] Adding job: Version Get
[2014-12-22 16:05:22.015] [D] [zway] SETDATA devices.19.data.givenName = "Routing Binary Sensor_19"
[2014-12-22 16:05:22.061] [D] [zway] SENDING (cb 0x19): ( 01 09 00 13 13 02 86 11 05 19 7F )
[2014-12-22 16:05:22.064] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:22.067] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:22.068] [D] [zway] SENT ACK
[2014-12-22 16:05:22.069] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:22.080] [D] [zway] RECEIVED: ( 01 05 00 13 19 00 F0 )
[2014-12-22 16:05:22.081] [D] [zway] SENT ACK
[2014-12-22 16:05:22.083] [I] [zway] Job 0x13 (Version Get): Delivered
[2014-12-22 16:05:22.084] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:22.085] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:22.087] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:22.089] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:22.090] [D] [zway] SendData Response with callback 0x19 received: received by recipient
[2014-12-22 16:05:22.092] [D] [zway] SETDATA devices.19.data.lastSend = 338104 (0x000528b8)
[2014-12-22 16:05:22.093] [D] [zway] Job 0x13 (Version Get): success
[2014-12-22 16:05:22.095] [I] [zway] Removing job: Version Get
[2014-12-22 16:05:22.098] [D] [zway] RECEIVED: ( 01 0D 00 04 00 13 07 86 12 06 03 28 03 03 5B )
[2014-12-22 16:05:22.099] [D] [zway] SENT ACK
[2014-12-22 16:05:22.101] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:22.103] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data = Empty
[2014-12-22 16:05:22.104] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWLib = 6 (0x00000006)
[2014-12-22 16:05:22.105] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWProtocolMajor = 3 (0x00000003)
[2014-12-22 16:05:22.107] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.ZWProtocolMinor = 40 (0x00000028)
[2014-12-22 16:05:22.112] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.SDK = "4.54.00"
[2014-12-22 16:05:22.113] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.applicationMajor = 3 (0x00000003)
[2014-12-22 16:05:22.114] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.applicationMinor = 3 (0x00000003)
[2014-12-22 16:05:22.115] [D] [zway] SETDATA devices.19.data.ZWLib = 6 (0x00000006)
[2014-12-22 16:05:22.117] [D] [zway] SETDATA devices.19.data.ZWProtocolMajor = 3 (0x00000003)
[2014-12-22 16:05:22.118] [D] [zway] SETDATA devices.19.data.ZWProtocolMinor = 40 (0x00000028)
[2014-12-22 16:05:22.122] [D] [zway] SETDATA devices.19.data.SDK = "4.54.00"
[2014-12-22 16:05:22.123] [D] [zway] SETDATA devices.19.data.applicationMajor = 3 (0x00000003)
[2014-12-22 16:05:22.125] [D] [zway] SETDATA devices.19.data.applicationMinor = 3 (0x00000003)
[2014-12-22 16:05:22.126] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-12-22 16:05:22.128] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.firmwareCount = 0 (0x00000000)
[2014-12-22 16:05:22.130] [D] [zway] SETDATA devices.19.instances.0.commandClasses.134.data.interviewDone = True
[2014-12-22 16:05:22.131] [I] [zway] Node 19:0 CC Version Interview done
[2014-12-22 16:05:22.133] [I] [zway] Saving configuration data to config/zddx/cc64a4d0-DevicesData.xml
[2014-12-22 16:05:22.789] [I] [zway] Interview step 3
[2014-12-22 16:05:22.790] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewDone = False
[2014-12-22 16:05:22.791] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:22.792] [I] [zway] Node 19:0 CC ManufacturerSpecific Interview started
[2014-12-22 16:05:22.793] [I] [zway] Adding job: ManufacturerSpecific Get
[2014-12-22 16:05:22.813] [D] [zway] SENDING (cb 0x1a): ( 01 09 00 13 13 02 72 04 05 1A 9D )
[2014-12-22 16:05:22.816] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:22.819] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:22.820] [D] [zway] SENT ACK
[2014-12-22 16:05:22.821] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:22.831] [D] [zway] RECEIVED: ( 01 05 00 13 1A 00 F3 )
[2014-12-22 16:05:22.833] [D] [zway] SENT ACK
[2014-12-22 16:05:22.834] [I] [zway] Job 0x13 (ManufacturerSpecific Get): Delivered
[2014-12-22 16:05:22.835] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:22.837] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:22.838] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:05:22.840] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:22.847] [D] [zway] SendData Response with callback 0x1a received: received by recipient
[2014-12-22 16:05:22.849] [D] [zway] SETDATA devices.19.data.lastSend = 338177 (0x00052901)
[2014-12-22 16:05:22.850] [D] [zway] Job 0x13 (ManufacturerSpecific Get): success
[2014-12-22 16:05:22.851] [I] [zway] Removing job: ManufacturerSpecific Get
[2014-12-22 16:05:22.852] [D] [zway] RECEIVED: ( 01 0E 00 04 00 13 08 72 05 00 1E 00 02 00 02 87 )
[2014-12-22 16:05:22.857] [D] [zway] SENT ACK
[2014-12-22 16:05:22.860] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:22.861] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.vendorId = 30 (0x0000001e)
[2014-12-22 16:05:22.914] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.vendor = "Express Controls"
[2014-12-22 16:05:22.915] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.productType = 2 (0x00000002)
[2014-12-22 16:05:22.918] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.productId = 2 (0x00000002)
[2014-12-22 16:05:22.920] [D] [zway] SETDATA devices.19.data.manufacturerId = 30 (0x0000001e)
[2014-12-22 16:05:22.924] [D] [zway] SETDATA devices.19.data.manufacturerProductType = 2 (0x00000002)
[2014-12-22 16:05:22.925] [D] [zway] SETDATA devices.19.data.manufacturerProductId = 2 (0x00000002)
[2014-12-22 16:05:22.933] [D] [zway] SETDATA devices.19.data.vendorString = "Express Controls"
[2014-12-22 16:05:22.935] [D] [zway] SETDATA devices.19.instances.0.commandClasses.114.data.interviewDone = True
[2014-12-22 16:05:22.936] [I] [zway] Node 19:0 CC ManufacturerSpecific Interview done
[2014-12-22 16:05:22.942] [I] [zway] Saving configuration data to config/zddx/cc64a4d0-DevicesData.xml
[2014-12-22 16:05:23.533] [I] [zway] Loading ZDDX index from ZDDX/ZDDX.indxml
[2014-12-22 16:05:23.825] [I] [zway] Found one full match: Express Control EZMotion (355-001e-0002-0002-06-03-28-03-03.xml)
[2014-12-22 16:05:23.827] [D] [zway] SETDATA devices.19.data.ZDDXMLFile = "355-001e-0002-0002-06-03-28-03-03.xml"
[2014-12-22 16:05:23.828] [I] [zway] Saving configuration data to config/zddx/cc64a4d0-DevicesData.xml
[2014-12-22 16:05:24.419] [I] [zway] Interview step 4 skipped due to absence of MultiInstance CC
[2014-12-22 16:05:24.456] [I] [zway] Interview step 5
[2014-12-22 16:05:24.465] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewDone = False
[2014-12-22 16:05:24.469] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.470] [I] [zway] Node 19:0 CC Basic Interview started
[2014-12-22 16:05:24.471] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.interviewDone = True
[2014-12-22 16:05:24.473] [I] [zway] Node 19:0 CC Basic Interview done
[2014-12-22 16:05:24.475] [I] [zway] Adding job: Basic Get
[2014-12-22 16:05:24.477] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewDone = False
[2014-12-22 16:05:24.479] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.480] [I] [zway] Node 19:0 CC SensorBinary Interview started
[2014-12-22 16:05:24.482] [I] [zway] Adding job: SensorBinary Supported Sensor Get
[2014-12-22 16:05:24.483] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewDone = False
[2014-12-22 16:05:24.485] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.487] [I] [zway] Node 19:0 CC SensorMultilevel Interview started
[2014-12-22 16:05:24.488] [I] [zway] Adding job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:05:24.490] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewDone = False
[2014-12-22 16:05:24.491] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.492] [I] [zway] Node 19:0 CC Configuration Interview started
[2014-12-22 16:05:24.493] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.interviewDone = True
[2014-12-22 16:05:24.494] [I] [zway] Node 19:0 CC Configuration Interview done
[2014-12-22 16:05:24.496] [I] [zway] Loading ZDDX data from ZDDX/355-001e-0002-0002-06-03-28-03-03.xml
[2014-12-22 16:05:24.518] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1 = Empty
[2014-12-22 16:05:24.519] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.val = Empty
[2014-12-22 16:05:24.520] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.size = Empty
[2014-12-22 16:05:24.521] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.523] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2 = Empty
[2014-12-22 16:05:24.524] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.val = Empty
[2014-12-22 16:05:24.525] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.size = Empty
[2014-12-22 16:05:24.528] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.529] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3 = Empty
[2014-12-22 16:05:24.530] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.val = Empty
[2014-12-22 16:05:24.532] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.size = Empty
[2014-12-22 16:05:24.533] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.535] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4 = Empty
[2014-12-22 16:05:24.537] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.val = Empty
[2014-12-22 16:05:24.538] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.size = Empty
[2014-12-22 16:05:24.540] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.541] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5 = Empty
[2014-12-22 16:05:24.542] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.val = Empty
[2014-12-22 16:05:24.543] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.size = Empty
[2014-12-22 16:05:24.545] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.546] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6 = Empty
[2014-12-22 16:05:24.548] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.val = Empty
[2014-12-22 16:05:24.549] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.size = Empty
[2014-12-22 16:05:24.550] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.551] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7 = Empty
[2014-12-22 16:05:24.552] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.val = Empty
[2014-12-22 16:05:24.554] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.size = Empty
[2014-12-22 16:05:24.555] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:05:24.558] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewDone = False
[2014-12-22 16:05:24.560] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.561] [I] [zway] Node 19:0 CC Battery Interview started
[2014-12-22 16:05:24.562] [I] [zway] Adding job: Battery Get
[2014-12-22 16:05:24.564] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewDone = False
[2014-12-22 16:05:24.566] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.572] [I] [zway] Node 19:0 CC Wakeup Interview started
[2014-12-22 16:05:24.573] [I] [zway] Adding job: Wakeup Capabilities Get
[2014-12-22 16:05:24.575] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewDone = False
[2014-12-22 16:05:24.576] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewCounter = 9 (0x00000009)
[2014-12-22 16:05:24.578] [I] [zway] Node 19:0 CC Association Interview started
[2014-12-22 16:05:24.580] [I] [zway] Adding job: Association Groupings Get
[2014-12-22 16:05:24.603] [D] [zway] SENDING (cb 0x1b): ( 01 09 00 13 13 02 20 02 05 1B C8 )
[2014-12-22 16:05:24.606] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:24.609] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:24.610] [D] [zway] SENT ACK
[2014-12-22 16:05:24.612] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:24.621] [D] [zway] RECEIVED: ( 01 05 00 13 1B 00 F2 )
[2014-12-22 16:05:24.622] [D] [zway] SENT ACK
[2014-12-22 16:05:24.623] [I] [zway] Job 0x13 (Basic Get): Delivered
[2014-12-22 16:05:24.625] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:24.626] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:24.630] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-12-22 16:05:24.631] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:24.633] [D] [zway] SendData Response with callback 0x1b received: received by recipient
[2014-12-22 16:05:24.635] [D] [zway] SETDATA devices.19.data.lastSend = 338354 (0x000529b2)
[2014-12-22 16:05:24.636] [D] [zway] Job 0x13 (Basic Get): success
[2014-12-22 16:05:24.638] [I] [zway] Removing job: Basic Get
[2014-12-22 16:05:24.639] [D] [zway] RECEIVED: ( 01 09 00 04 00 13 03 20 03 FF 3E )
[2014-12-22 16:05:24.641] [D] [zway] SENT ACK
[2014-12-22 16:05:24.642] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:24.644] [D] [zway] SETDATA devices.19.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2014-12-22 16:05:24.696] [D] [zway] SENDING (cb 0x1c): ( 01 09 00 13 13 02 30 01 05 1C DC )
[2014-12-22 16:05:24.699] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:24.702] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:24.704] [D] [zway] SENT ACK
[2014-12-22 16:05:24.705] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:24.715] [D] [zway] RECEIVED: ( 01 05 00 13 1C 00 F5 )
[2014-12-22 16:05:24.716] [D] [zway] SENT ACK
[2014-12-22 16:05:24.718] [I] [zway] Job 0x13 (SensorBinary Supported Sensor Get): Delivered
[2014-12-22 16:05:24.719] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:24.720] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:24.722] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:24.724] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:24.725] [D] [zway] SendData Response with callback 0x1c received: received by recipient
[2014-12-22 16:05:24.726] [D] [zway] SETDATA devices.19.data.lastSend = 338361 (0x000529b9)
[2014-12-22 16:05:24.727] [D] [zway] Job 0x13 (SensorBinary Supported Sensor Get): success
[2014-12-22 16:05:24.729] [I] [zway] Removing job: SensorBinary Supported Sensor Get
[2014-12-22 16:05:24.730] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 30 04 00 10 C2 )
[2014-12-22 16:05:24.732] [D] [zway] SENT ACK
[2014-12-22 16:05:24.734] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:24.735] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.typemask = 4096 (0x00001000)
[2014-12-22 16:05:24.737] [I] [zway] Adding job: SensorBinary Get v2
[2014-12-22 16:05:24.792] [D] [zway] SENDING (cb 0x1d): ( 01 09 00 13 13 02 31 01 05 1D DC )
[2014-12-22 16:05:24.795] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:24.798] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:24.799] [D] [zway] SENT ACK
[2014-12-22 16:05:24.800] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:24.811] [D] [zway] RECEIVED: ( 01 05 00 13 1D 00 F4 )
[2014-12-22 16:05:24.812] [D] [zway] SENT ACK
[2014-12-22 16:05:24.813] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Get): Delivered
[2014-12-22 16:05:24.814] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:24.816] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:24.818] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:24.819] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:24.821] [D] [zway] SendData Response with callback 0x1d received: received by recipient
[2014-12-22 16:05:24.822] [D] [zway] SETDATA devices.19.data.lastSend = 338368 (0x000529c0)
[2014-12-22 16:05:24.823] [D] [zway] Job 0x13 (SensorMultilevel Supported Sensor Get): success
[2014-12-22 16:05:24.825] [I] [zway] Removing job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:05:24.828] [D] [zway] RECEIVED: ( 01 09 00 04 00 13 03 31 02 05 D4 )
[2014-12-22 16:05:24.830] [D] [zway] SENT ACK
[2014-12-22 16:05:24.831] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:24.833] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.typemask = byte[1]
[2014-12-22 16:05:24.834] [D] [zway]   ( 05 )
[2014-12-22 16:05:24.835] [I] [zway] Adding job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:05:24.837] [I] [zway] Adding job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:05:24.881] [D] [zway] SENDING (cb 0x1e): ( 01 0A 00 13 13 03 70 05 01 05 1E 99 )
[2014-12-22 16:05:24.884] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:24.887] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:24.888] [D] [zway] SENT ACK
[2014-12-22 16:05:24.888] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:24.900] [D] [zway] RECEIVED: ( 01 05 00 13 1E 00 F7 )
[2014-12-22 16:05:24.901] [D] [zway] SENT ACK
[2014-12-22 16:05:24.901] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:24.901] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:24.901] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:24.902] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:05:24.904] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:24.905] [D] [zway] SendData Response with callback 0x1e received: received by recipient
[2014-12-22 16:05:24.907] [D] [zway] SETDATA devices.19.data.lastSend = 338376 (0x000529c8)
[2014-12-22 16:05:24.909] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:24.910] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:24.912] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 01 01 C8 58 )
[2014-12-22 16:05:24.914] [D] [zway] SENT ACK
[2014-12-22 16:05:24.917] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:24.918] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.size = 1 (0x00000001)
[2014-12-22 16:05:24.924] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.val = 200 (0x000000c8)
[2014-12-22 16:05:24.925] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1 = Empty
[2014-12-22 16:05:24.926] [I] [zway] Node 19:0 CC Configuration: Parameter 0x01 = 200 (size = 1)
[2014-12-22 16:05:24.980] [D] [zway] SENDING (cb 0x1f): ( 01 0A 00 13 13 03 70 05 02 05 1F 9B )
[2014-12-22 16:05:24.983] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:24.986] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:24.987] [D] [zway] SENT ACK
[2014-12-22 16:05:24.989] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:24.999] [D] [zway] RECEIVED: ( 01 05 00 13 1F 00 F6 )
[2014-12-22 16:05:25.001] [D] [zway] SENT ACK
[2014-12-22 16:05:25.002] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.003] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.004] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.005] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:05:25.007] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.008] [D] [zway] SendData Response with callback 0x1f received: received by recipient
[2014-12-22 16:05:25.010] [D] [zway] SETDATA devices.19.data.lastSend = 338383 (0x000529cf)
[2014-12-22 16:05:25.011] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.013] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.016] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 02 01 14 87 )
[2014-12-22 16:05:25.018] [D] [zway] SENT ACK
[2014-12-22 16:05:25.019] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.020] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.size = 1 (0x00000001)
[2014-12-22 16:05:25.021] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.val = 20 (0x00000014)
[2014-12-22 16:05:25.022] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2 = Empty
[2014-12-22 16:05:25.022] [I] [zway] Node 19:0 CC Configuration: Parameter 0x02 = 20 (size = 1)
[2014-12-22 16:05:25.075] [D] [zway] SENDING (cb 0x20): ( 01 0A 00 13 13 03 70 05 03 05 20 A5 )
[2014-12-22 16:05:25.078] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.081] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.082] [D] [zway] SENT ACK
[2014-12-22 16:05:25.083] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.094] [D] [zway] RECEIVED: ( 01 05 00 13 20 00 C9 )
[2014-12-22 16:05:25.099] [D] [zway] SENT ACK
[2014-12-22 16:05:25.100] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.102] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.104] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.107] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 16 (0x00000010)
[2014-12-22 16:05:25.108] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.110] [D] [zway] SendData Response with callback 0x20 received: received by recipient
[2014-12-22 16:05:25.111] [D] [zway] SETDATA devices.19.data.lastSend = 338390 (0x000529d6)
[2014-12-22 16:05:25.113] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.114] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.116] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 03 01 FF 6D )
[2014-12-22 16:05:25.127] [D] [zway] SENT ACK
[2014-12-22 16:05:25.128] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.129] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.size = 1 (0x00000001)
[2014-12-22 16:05:25.130] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.val = 255 (0x000000ff)
[2014-12-22 16:05:25.131] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3 = Empty
[2014-12-22 16:05:25.132] [I] [zway] Node 19:0 CC Configuration: Parameter 0x03 = 255 (size = 1)
[2014-12-22 16:05:25.170] [D] [zway] SENDING (cb 0x21): ( 01 0A 00 13 13 03 70 05 04 05 21 A3 )
[2014-12-22 16:05:25.173] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.177] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.178] [D] [zway] SENT ACK
[2014-12-22 16:05:25.180] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.189] [D] [zway] RECEIVED: ( 01 05 00 13 21 00 C8 )
[2014-12-22 16:05:25.191] [D] [zway] SENT ACK
[2014-12-22 16:05:25.192] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.194] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.195] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.196] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:25.198] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.199] [D] [zway] SendData Response with callback 0x21 received: received by recipient
[2014-12-22 16:05:25.201] [D] [zway] SETDATA devices.19.data.lastSend = 338397 (0x000529dd)
[2014-12-22 16:05:25.202] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.203] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.206] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 04 01 64 F1 )
[2014-12-22 16:05:25.208] [D] [zway] SENT ACK
[2014-12-22 16:05:25.209] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.210] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.size = 1 (0x00000001)
[2014-12-22 16:05:25.212] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.val = 100 (0x00000064)
[2014-12-22 16:05:25.213] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4 = Empty
[2014-12-22 16:05:25.214] [I] [zway] Node 19:0 CC Configuration: Parameter 0x04 = 100 (size = 1)
[2014-12-22 16:05:25.274] [D] [zway] SENDING (cb 0x22): ( 01 0A 00 13 13 03 70 05 05 05 22 A1 )
[2014-12-22 16:05:25.278] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.280] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.282] [D] [zway] SENT ACK
[2014-12-22 16:05:25.283] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.293] [D] [zway] RECEIVED: ( 01 05 00 13 22 00 CB )
[2014-12-22 16:05:25.294] [D] [zway] SENT ACK
[2014-12-22 16:05:25.295] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.297] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.298] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.300] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:25.301] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.303] [D] [zway] SendData Response with callback 0x22 received: received by recipient
[2014-12-22 16:05:25.305] [D] [zway] SETDATA devices.19.data.lastSend = 338404 (0x000529e4)
[2014-12-22 16:05:25.306] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.308] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.310] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 05 01 00 94 )
[2014-12-22 16:05:25.312] [D] [zway] SENT ACK
[2014-12-22 16:05:25.318] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.320] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.size = 1 (0x00000001)
[2014-12-22 16:05:25.321] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.val = 0 (0x00000000)
[2014-12-22 16:05:25.324] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5 = Empty
[2014-12-22 16:05:25.325] [I] [zway] Node 19:0 CC Configuration: Parameter 0x05 = 0 (size = 1)
[2014-12-22 16:05:25.369] [D] [zway] SENDING (cb 0x23): ( 01 0A 00 13 13 03 70 05 06 05 23 A3 )
[2014-12-22 16:05:25.371] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.374] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.374] [D] [zway] SENT ACK
[2014-12-22 16:05:25.374] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.386] [D] [zway] RECEIVED: ( 01 05 00 13 23 00 CA )
[2014-12-22 16:05:25.387] [D] [zway] SENT ACK
[2014-12-22 16:05:25.387] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.387] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.387] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.388] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:05:25.388] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.388] [D] [zway] SendData Response with callback 0x23 received: received by recipient
[2014-12-22 16:05:25.388] [D] [zway] SETDATA devices.19.data.lastSend = 338412 (0x000529ec)
[2014-12-22 16:05:25.389] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.389] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.395] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 06 01 FF 68 )
[2014-12-22 16:05:25.397] [D] [zway] SENT ACK
[2014-12-22 16:05:25.398] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.399] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.size = 1 (0x00000001)
[2014-12-22 16:05:25.400] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.val = 255 (0x000000ff)
[2014-12-22 16:05:25.402] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6 = Empty
[2014-12-22 16:05:25.403] [I] [zway] Node 19:0 CC Configuration: Parameter 0x06 = 255 (size = 1)
[2014-12-22 16:05:25.466] [D] [zway] SENDING (cb 0x24): ( 01 0A 00 13 13 03 70 05 07 05 24 A5 )
[2014-12-22 16:05:25.470] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.473] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.474] [D] [zway] SENT ACK
[2014-12-22 16:05:25.475] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.485] [D] [zway] RECEIVED: ( 01 05 00 13 24 00 CD )
[2014-12-22 16:05:25.486] [D] [zway] SENT ACK
[2014-12-22 16:05:25.486] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:05:25.486] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.488] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:05:25.489] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:05:25.490] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.492] [D] [zway] SendData Response with callback 0x24 received: received by recipient
[2014-12-22 16:05:25.494] [D] [zway] SETDATA devices.19.data.lastSend = 338419 (0x000529f3)
[2014-12-22 16:05:25.496] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:05:25.497] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:05:25.498] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 07 01 00 96 )
[2014-12-22 16:05:25.500] [D] [zway] SENT ACK
[2014-12-22 16:05:25.502] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.503] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.size = 1 (0x00000001)
[2014-12-22 16:05:25.507] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.val = 0 (0x00000000)
[2014-12-22 16:05:25.509] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7 = Empty
[2014-12-22 16:05:25.509] [I] [zway] Node 19:0 CC Configuration: Parameter 0x07 = 0 (size = 1)
[2014-12-22 16:05:25.561] [D] [zway] SENDING (cb 0x25): ( 01 09 00 13 13 02 80 02 05 25 56 )
[2014-12-22 16:05:25.564] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.567] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.568] [D] [zway] SENT ACK
[2014-12-22 16:05:25.569] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.579] [D] [zway] RECEIVED: ( 01 05 00 13 25 00 CC )
[2014-12-22 16:05:25.581] [D] [zway] SENT ACK
[2014-12-22 16:05:25.582] [I] [zway] Job 0x13 (Battery Get): Delivered
[2014-12-22 16:05:25.586] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:05:25.587] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:25.591] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2014-12-22 16:05:25.592] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.594] [D] [zway] SendData Response with callback 0x25 received: received by recipient
[2014-12-22 16:05:25.596] [D] [zway] SETDATA devices.19.data.lastSend = 338426 (0x000529fa)
[2014-12-22 16:05:25.598] [D] [zway] Job 0x13 (Battery Get): success
[2014-12-22 16:05:25.599] [I] [zway] Removing job: Battery Get
[2014-12-22 16:05:25.600] [D] [zway] RECEIVED: ( 01 09 00 04 00 13 03 80 03 FF 9E )
[2014-12-22 16:05:25.602] [D] [zway] SENT ACK
[2014-12-22 16:05:25.603] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:05:25.607] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.history.0 = Empty
[2014-12-22 16:05:25.607] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.history.0 = 1419260725 (0x54983335)
[2014-12-22 16:05:25.608] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.last = 0 (0x00000000)
[2014-12-22 16:05:25.608] [D] [zway] SETDATA devices.19.instances.0.commandClasses.128.data.interviewDone = True
[2014-12-22 16:05:25.609] [I] [zway] Node 19:0 CC Battery Interview done
[2014-12-22 16:05:25.635] [I] [core] Creating device battery ZWayVDev_zway_19-0-128
[2014-12-22 16:05:25.658] [D] [zway] SENDING (cb 0x26): ( 01 09 00 13 13 02 84 09 05 26 5A )
[2014-12-22 16:05:25.661] [D] [zway] RECEIVED ACK
[2014-12-22 16:05:25.664] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:05:25.665] [D] [zway] SENT ACK
[2014-12-22 16:05:25.666] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:05:25.939] [D] [zway] RECEIVED: ( 01 05 00 13 26 01 CE )
[2014-12-22 16:05:25.939] [D] [zway] SENT ACK
[2014-12-22 16:05:25.939] [I] [zway] Job 0x13 (Wakeup Capabilities Get): Not delivered to recipient
[2014-12-22 16:05:25.940] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = False
[2014-12-22 16:05:25.940] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:05:25.940] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 271 (0x0000010f)
[2014-12-22 16:05:25.940] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:05:25.941] [D] [zway] SETDATA devices.19.data.isAwake = False
[2014-12-22 16:05:25.941] [D] [zway] Sending the queue for node 19 into sleep
[2014-12-22 16:05:43.710] [D] [zway] Job 0x62: deleted from queue
[2014-12-22 16:05:44.453] [D] [zway] Job 0x4a: deleted from queue
[2014-12-22 16:05:44.496] [D] [zway] Job 0x4a: deleted from queue
[2014-12-22 16:05:44.496] [D] [zway] Job 0x41: deleted from queue
[2014-12-22 16:05:44.517] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.528] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.540] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.551] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.574] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.585] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.596] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.617] [D] [zway] Job 0x80: deleted from queue
[2014-12-22 16:05:44.627] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:44.679] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:44.732] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:44.763] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:44.816] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.053] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.085] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.121] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.159] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.200] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.212] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.234] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.276] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.330] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.382] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.434] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.486] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.517] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.579] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.631] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.693] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:05:45.735] [D] [zway] Job 0x13: deleted from queue
Tiptop
Post by Tiptop »
3. To finally complete the interview, I forced the re-interview of the failed command classes manually.
Here is the log:
[2014-12-22 16:06:40.049] [I] [zway] Adding job: SensorBinary Supported Sensor Get
[2014-12-22 16:06:40.818] [I] [zway] Adding job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:06:41.524] [D] [zway] Job 0x13 (Wakeup Capabilities Get): removing duplicate
[2014-12-22 16:06:42.142] [D] [zway] Job 0x13 (Association Groupings Get): removing duplicate
[2014-12-22 16:06:44.212] [D] [zway] RECEIVED: ( 01 15 00 49 84 13 0F 04 20 01 30 31 85 9B 70 84 80 72 86 EF 20 60 2E )
[2014-12-22 16:06:44.213] [D] [zway] SENT ACK
[2014-12-22 16:06:44.214] [I] [zway] Node info received: 19
[2014-12-22 16:06:44.215] [D] [zway] SETDATA devices.19.data.basicType = 4 (0x00000004)
[2014-12-22 16:06:44.217] [D] [zway] SETDATA devices.19.data.genericType = 32 (0x00000020)
[2014-12-22 16:06:44.218] [D] [zway] SETDATA devices.19.data.specificType = 1 (0x00000001)
[2014-12-22 16:06:44.223] [D] [zway] SETDATA devices.19.data.deviceTypeString = "Routing Binary Sensor"
[2014-12-22 16:06:44.224] [D] [zway] SETDATA devices.19.data.nodeInfoFrame = byte[12]
[2014-12-22 16:06:44.225] [D] [zway]   ( 30 31 85 9B 70 84 80 72 86 EF 20 60 )
[2014-12-22 16:06:44.226] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:44.228] [D] [zway] SETDATA devices.19.data.isAwake = True
[2014-12-22 16:06:44.228] [D] [zway] SETDATA devices.19.data.lastSend = 346071 (0x000547d7)
[2014-12-22 16:06:44.229] [D] [zway] SETDATA devices.19.data.lastNonceGet = 345071 (0x000543ef)
[2014-12-22 16:06:44.230] [I] [zway] Job 0x13 (SensorBinary Get v2): Cancelling job: SensorBinary Get v2
[2014-12-22 16:06:44.231] [I] [zway] Removing job: SensorBinary Get v2
[2014-12-22 16:06:44.232] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): Cancelling job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:44.233] [I] [zway] Removing job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:44.233] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): Cancelling job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:44.234] [I] [zway] Removing job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:44.235] [I] [zway] Job 0x13 (SensorBinary Supported Sensor Get): Cancelling job: SensorBinary Supported Sensor Get
[2014-12-22 16:06:44.236] [I] [zway] Removing job: SensorBinary Supported Sensor Get
[2014-12-22 16:06:44.237] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Get): Cancelling job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:06:44.238] [I] [zway] Removing job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:06:44.238] [I] [zway] Job 0x13 (Wakeup Capabilities Get): Cancelling job: Wakeup Capabilities Get
[2014-12-22 16:06:44.239] [I] [zway] Removing job: Wakeup Capabilities Get
[2014-12-22 16:06:44.240] [I] [zway] Job 0x13 (Association Groupings Get): Cancelling job: Association Groupings Get
[2014-12-22 16:06:44.243] [I] [zway] Removing job: Association Groupings Get
[2014-12-22 16:06:44.244] [I] [zway] Interview step 1 skipped due to absence of Security CC
[2014-12-22 16:06:44.247] [I] [zway] Loading ZDDX index from ZDDX/ZDDX.indxml
[2014-12-22 16:06:44.472] [I] [zway] Found one full match: Express Control EZMotion (355-001e-0002-0002-06-03-28-03-03.xml)
[2014-12-22 16:06:44.477] [D] [zway] SETDATA devices.19.data.ZDDXMLFile = "355-001e-0002-0002-06-03-28-03-03.xml"
[2014-12-22 16:06:44.479] [I] [zway] Saving configuration data to config/zddx/cc64a4d0-DevicesData.xml
[2014-12-22 16:06:45.206] [I] [zway] Loading ZDDX data from ZDDX/355-001e-0002-0002-06-03-28-03-03.xml
[2014-12-22 16:06:45.278] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.280] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.281] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.283] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.284] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.285] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.287] [I] [zway] Adding job: Configuration Get
[2014-12-22 16:06:45.291] [I] [zway] Interview step 4 skipped due to absence of MultiInstance CC
[2014-12-22 16:06:45.295] [I] [zway] Interview step 5
[2014-12-22 16:06:45.296] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewDone = False
[2014-12-22 16:06:45.298] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewCounter = 8 (0x00000008)
[2014-12-22 16:06:45.299] [I] [zway] Node 19:0 CC SensorBinary Interview started
[2014-12-22 16:06:45.301] [I] [zway] Adding job: SensorBinary Supported Sensor Get
[2014-12-22 16:06:45.302] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewDone = False
[2014-12-22 16:06:45.306] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewCounter = 8 (0x00000008)
[2014-12-22 16:06:45.307] [I] [zway] Node 19:0 CC SensorMultilevel Interview started
[2014-12-22 16:06:45.309] [I] [zway] Adding job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:06:45.310] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewDone = False
[2014-12-22 16:06:45.311] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewCounter = 8 (0x00000008)
[2014-12-22 16:06:45.313] [I] [zway] Node 19:0 CC Wakeup Interview started
[2014-12-22 16:06:45.314] [I] [zway] Adding job: Wakeup Capabilities Get
[2014-12-22 16:06:45.315] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewDone = False
[2014-12-22 16:06:45.317] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewCounter = 8 (0x00000008)
[2014-12-22 16:06:45.318] [I] [zway] Node 19:0 CC Association Interview started
[2014-12-22 16:06:45.319] [I] [zway] Adding job: Association Groupings Get
[2014-12-22 16:06:45.320] [D] [zway] Running wakeup handler for node 19
[2014-12-22 16:06:45.337] [D] [zway] SENDING (cb 0x27): ( 01 0A 00 13 13 03 70 05 01 05 27 A0 )
[2014-12-22 16:06:45.340] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.343] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.345] [D] [zway] SENT ACK
[2014-12-22 16:06:45.346] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.358] [D] [zway] RECEIVED: ( 01 05 00 13 27 00 CE )
[2014-12-22 16:06:45.359] [D] [zway] SENT ACK
[2014-12-22 16:06:45.360] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.361] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.363] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.364] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2014-12-22 16:06:45.370] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.372] [D] [zway] SendData Response with callback 0x27 received: received by recipient
[2014-12-22 16:06:45.373] [D] [zway] SETDATA devices.19.data.lastSend = 346184 (0x00054848)
[2014-12-22 16:06:45.376] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.377] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.378] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 01 01 C8 58 )
[2014-12-22 16:06:45.380] [D] [zway] SENT ACK
[2014-12-22 16:06:45.387] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.388] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.size = 1 (0x00000001)
[2014-12-22 16:06:45.389] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1.val = 200 (0x000000c8)
[2014-12-22 16:06:45.391] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.1 = Empty
[2014-12-22 16:06:45.392] [I] [zway] Node 19:0 CC Configuration: Parameter 0x01 = 200 (size = 1)
[2014-12-22 16:06:45.436] [D] [zway] SENDING (cb 0x28): ( 01 0A 00 13 13 03 70 05 02 05 28 AC )
[2014-12-22 16:06:45.438] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.441] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.442] [D] [zway] SENT ACK
[2014-12-22 16:06:45.443] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.453] [D] [zway] RECEIVED: ( 01 05 00 13 28 00 C1 )
[2014-12-22 16:06:45.455] [D] [zway] SENT ACK
[2014-12-22 16:06:45.456] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.460] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.462] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.463] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 16 (0x00000010)
[2014-12-22 16:06:45.464] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.465] [D] [zway] SendData Response with callback 0x28 received: received by recipient
[2014-12-22 16:06:45.465] [D] [zway] SETDATA devices.19.data.lastSend = 346191 (0x0005484f)
[2014-12-22 16:06:45.467] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.470] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.474] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 02 01 14 87 )
[2014-12-22 16:06:45.475] [D] [zway] SENT ACK
[2014-12-22 16:06:45.477] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.479] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.size = 1 (0x00000001)
[2014-12-22 16:06:45.481] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2.val = 20 (0x00000014)
[2014-12-22 16:06:45.482] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.2 = Empty
[2014-12-22 16:06:45.483] [I] [zway] Node 19:0 CC Configuration: Parameter 0x02 = 20 (size = 1)
[2014-12-22 16:06:45.515] [D] [zway] SENDING (cb 0x29): ( 01 0A 00 13 13 03 70 05 03 05 29 AC )
[2014-12-22 16:06:45.522] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.525] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.527] [D] [zway] SENT ACK
[2014-12-22 16:06:45.528] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.538] [D] [zway] RECEIVED: ( 01 05 00 13 29 00 C0 )
[2014-12-22 16:06:45.539] [D] [zway] SENT ACK
[2014-12-22 16:06:45.540] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.541] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.542] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.544] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-12-22 16:06:45.545] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.548] [D] [zway] SendData Response with callback 0x29 received: received by recipient
[2014-12-22 16:06:45.549] [D] [zway] SETDATA devices.19.data.lastSend = 346198 (0x00054856)
[2014-12-22 16:06:45.550] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.551] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.553] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 03 01 FF 6D )
[2014-12-22 16:06:45.554] [D] [zway] SENT ACK
[2014-12-22 16:06:45.556] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.557] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.size = 1 (0x00000001)
[2014-12-22 16:06:45.558] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3.val = 255 (0x000000ff)
[2014-12-22 16:06:45.559] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.3 = Empty
[2014-12-22 16:06:45.560] [I] [zway] Node 19:0 CC Configuration: Parameter 0x03 = 255 (size = 1)
[2014-12-22 16:06:45.614] [D] [zway] SENDING (cb 0x2a): ( 01 0A 00 13 13 03 70 05 04 05 2A A8 )
[2014-12-22 16:06:45.617] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.620] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.625] [D] [zway] SENT ACK
[2014-12-22 16:06:45.627] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.633] [D] [zway] RECEIVED: ( 01 05 00 13 2A 00 C3 )
[2014-12-22 16:06:45.634] [D] [zway] SENT ACK
[2014-12-22 16:06:45.636] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.637] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.642] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.644] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 7 (0x00000007)
[2014-12-22 16:06:45.645] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.647] [D] [zway] SendData Response with callback 0x2a received: received by recipient
[2014-12-22 16:06:45.648] [D] [zway] SETDATA devices.19.data.lastSend = 346206 (0x0005485e)
[2014-12-22 16:06:45.649] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.651] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.652] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 04 01 64 F1 )
[2014-12-22 16:06:45.653] [D] [zway] SENT ACK
[2014-12-22 16:06:45.655] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.655] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.size = 1 (0x00000001)
[2014-12-22 16:06:45.656] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4.val = 100 (0x00000064)
[2014-12-22 16:06:45.658] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.4 = Empty
[2014-12-22 16:06:45.659] [I] [zway] Node 19:0 CC Configuration: Parameter 0x04 = 100 (size = 1)
[2014-12-22 16:06:45.717] [D] [zway] SENDING (cb 0x2b): ( 01 0A 00 13 13 03 70 05 05 05 2B A8 )
[2014-12-22 16:06:45.720] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.723] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.724] [D] [zway] SENT ACK
[2014-12-22 16:06:45.725] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.736] [D] [zway] RECEIVED: ( 01 05 00 13 2B 00 C2 )
[2014-12-22 16:06:45.737] [D] [zway] SENT ACK
[2014-12-22 16:06:45.737] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.737] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.739] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.740] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-12-22 16:06:45.742] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.743] [D] [zway] SendData Response with callback 0x2b received: received by recipient
[2014-12-22 16:06:45.745] [D] [zway] SETDATA devices.19.data.lastSend = 346213 (0x00054865)
[2014-12-22 16:06:45.746] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.748] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.749] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 05 01 00 94 )
[2014-12-22 16:06:45.751] [D] [zway] SENT ACK
[2014-12-22 16:06:45.752] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.753] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.size = 1 (0x00000001)
[2014-12-22 16:06:45.755] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5.val = 0 (0x00000000)
[2014-12-22 16:06:45.755] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.5 = Empty
[2014-12-22 16:06:45.757] [I] [zway] Node 19:0 CC Configuration: Parameter 0x05 = 0 (size = 1)
[2014-12-22 16:06:45.801] [D] [zway] SENDING (cb 0x2c): ( 01 0A 00 13 13 03 70 05 06 05 2C AC )
[2014-12-22 16:06:45.805] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.807] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.809] [D] [zway] SENT ACK
[2014-12-22 16:06:45.810] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.820] [D] [zway] RECEIVED: ( 01 05 00 13 2C 00 C5 )
[2014-12-22 16:06:45.821] [D] [zway] SENT ACK
[2014-12-22 16:06:45.822] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.824] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.825] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.826] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:45.828] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.830] [D] [zway] SendData Response with callback 0x2c received: received by recipient
[2014-12-22 16:06:45.831] [D] [zway] SETDATA devices.19.data.lastSend = 346220 (0x0005486c)
[2014-12-22 16:06:45.833] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.839] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.842] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 06 01 FF 68 )
[2014-12-22 16:06:45.844] [D] [zway] SENT ACK
[2014-12-22 16:06:45.845] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.847] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.size = 1 (0x00000001)
[2014-12-22 16:06:45.848] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6.val = 255 (0x000000ff)
[2014-12-22 16:06:45.850] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.6 = Empty
[2014-12-22 16:06:45.851] [I] [zway] Node 19:0 CC Configuration: Parameter 0x06 = 255 (size = 1)
[2014-12-22 16:06:45.884] [D] [zway] SENDING (cb 0x2d): ( 01 0A 00 13 13 03 70 05 07 05 2D AC )
[2014-12-22 16:06:45.886] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.889] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.890] [D] [zway] SENT ACK
[2014-12-22 16:06:45.892] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.902] [D] [zway] RECEIVED: ( 01 05 00 13 2D 00 C4 )
[2014-12-22 16:06:45.902] [D] [zway] SENT ACK
[2014-12-22 16:06:45.902] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2014-12-22 16:06:45.902] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.903] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:45.903] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:06:45.903] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:45.903] [D] [zway] SendData Response with callback 0x2d received: received by recipient
[2014-12-22 16:06:45.904] [D] [zway] SETDATA devices.19.data.lastSend = 346227 (0x00054873)
[2014-12-22 16:06:45.904] [D] [zway] Job 0x13 (Configuration Get): success
[2014-12-22 16:06:45.904] [I] [zway] Removing job: Configuration Get
[2014-12-22 16:06:45.910] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 70 06 07 01 00 96 )
[2014-12-22 16:06:45.913] [D] [zway] SENT ACK
[2014-12-22 16:06:45.915] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:45.916] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.size = 1 (0x00000001)
[2014-12-22 16:06:45.919] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7.val = 0 (0x00000000)
[2014-12-22 16:06:45.921] [D] [zway] SETDATA devices.19.instances.0.commandClasses.112.data.7 = Empty
[2014-12-22 16:06:45.923] [I] [zway] Node 19:0 CC Configuration: Parameter 0x07 = 0 (size = 1)
[2014-12-22 16:06:45.975] [D] [zway] SENDING (cb 0x2e): ( 01 09 00 13 13 02 30 01 05 2E EE )
[2014-12-22 16:06:45.978] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:45.981] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:45.982] [D] [zway] SENT ACK
[2014-12-22 16:06:45.984] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:45.994] [D] [zway] RECEIVED: ( 01 05 00 13 2E 00 C7 )
[2014-12-22 16:06:45.995] [D] [zway] SENT ACK
[2014-12-22 16:06:45.996] [I] [zway] Job 0x13 (SensorBinary Supported Sensor Get): Delivered
[2014-12-22 16:06:45.997] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:45.999] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:46.000] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:46.001] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.003] [D] [zway] SendData Response with callback 0x2e received: received by recipient
[2014-12-22 16:06:46.007] [D] [zway] SETDATA devices.19.data.lastSend = 346234 (0x0005487a)
[2014-12-22 16:06:46.008] [D] [zway] Job 0x13 (SensorBinary Supported Sensor Get): success
[2014-12-22 16:06:46.009] [I] [zway] Removing job: SensorBinary Supported Sensor Get
[2014-12-22 16:06:46.012] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 30 04 00 10 C2 )
[2014-12-22 16:06:46.014] [D] [zway] SENT ACK
[2014-12-22 16:06:46.015] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.016] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.typemask = 4096 (0x00001000)
[2014-12-22 16:06:46.018] [I] [zway] Adding job: SensorBinary Get v2
[2014-12-22 16:06:46.071] [D] [zway] SENDING (cb 0x2f): ( 01 09 00 13 13 02 31 01 05 2F EE )
[2014-12-22 16:06:46.074] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.076] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.078] [D] [zway] SENT ACK
[2014-12-22 16:06:46.079] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.089] [D] [zway] RECEIVED: ( 01 05 00 13 2F 00 C6 )
[2014-12-22 16:06:46.089] [D] [zway] SENT ACK
[2014-12-22 16:06:46.089] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Get): Delivered
[2014-12-22 16:06:46.090] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.090] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:46.090] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:06:46.090] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.091] [D] [zway] SendData Response with callback 0x2f received: received by recipient
[2014-12-22 16:06:46.091] [D] [zway] SETDATA devices.19.data.lastSend = 346241 (0x00054881)
[2014-12-22 16:06:46.091] [D] [zway] Job 0x13 (SensorMultilevel Supported Sensor Get): success
[2014-12-22 16:06:46.091] [I] [zway] Removing job: SensorMultilevel Supported Sensor Get
[2014-12-22 16:06:46.096] [D] [zway] RECEIVED: ( 01 09 00 04 00 13 03 31 02 05 D4 )
[2014-12-22 16:06:46.098] [D] [zway] SENT ACK
[2014-12-22 16:06:46.099] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.100] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.typemask = byte[1]
[2014-12-22 16:06:46.102] [D] [zway]   ( 05 )
[2014-12-22 16:06:46.103] [I] [zway] Adding job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:46.104] [I] [zway] Adding job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:46.159] [D] [zway] SENDING (cb 0x30): ( 01 09 00 13 13 02 84 09 05 30 4C )
[2014-12-22 16:06:46.162] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.165] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.166] [D] [zway] SENT ACK
[2014-12-22 16:06:46.168] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.178] [D] [zway] RECEIVED: ( 01 05 00 13 30 00 D9 )
[2014-12-22 16:06:46.179] [D] [zway] SENT ACK
[2014-12-22 16:06:46.180] [I] [zway] Job 0x13 (Wakeup Capabilities Get): Delivered
[2014-12-22 16:06:46.181] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.182] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:46.184] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-12-22 16:06:46.185] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.187] [D] [zway] SendData Response with callback 0x30 received: received by recipient
[2014-12-22 16:06:46.189] [D] [zway] SETDATA devices.19.data.lastSend = 346248 (0x00054888)
[2014-12-22 16:06:46.190] [D] [zway] Job 0x13 (Wakeup Capabilities Get): success
[2014-12-22 16:06:46.191] [I] [zway] Removing job: Wakeup Capabilities Get
[2014-12-22 16:06:46.193] [D] [zway] RECEIVED: ( 01 14 00 04 00 13 0E 84 0A 00 01 68 01 5F 90 00 0E 10 00 01 68 AC )
[2014-12-22 16:06:46.195] [D] [zway] SENT ACK
[2014-12-22 16:06:46.197] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.198] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.min = 360 (0x00000168)
[2014-12-22 16:06:46.199] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.max = 90000 (0x00015f90)
[2014-12-22 16:06:46.201] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.default = 3600 (0x00000e10)
[2014-12-22 16:06:46.201] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.step = 360 (0x00000168)
[2014-12-22 16:06:46.202] [I] [zway] Adding job: Wakeup Get
[2014-12-22 16:06:46.244] [D] [zway] SENDING (cb 0x31): ( 01 09 00 13 13 02 85 05 05 31 40 )
[2014-12-22 16:06:46.247] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.250] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.251] [D] [zway] SENT ACK
[2014-12-22 16:06:46.252] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.263] [D] [zway] RECEIVED: ( 01 05 00 13 31 00 D8 )
[2014-12-22 16:06:46.264] [D] [zway] SENT ACK
[2014-12-22 16:06:46.265] [I] [zway] Job 0x13 (Association Groupings Get): Delivered
[2014-12-22 16:06:46.266] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.268] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:46.270] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:46.272] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.273] [D] [zway] SendData Response with callback 0x31 received: received by recipient
[2014-12-22 16:06:46.274] [D] [zway] SETDATA devices.19.data.lastSend = 346255 (0x0005488f)
[2014-12-22 16:06:46.276] [D] [zway] Job 0x13 (Association Groupings Get): success
[2014-12-22 16:06:46.277] [I] [zway] Removing job: Association Groupings Get
[2014-12-22 16:06:46.278] [D] [zway] RECEIVED: ( 01 09 00 04 00 13 03 85 06 01 60 )
[2014-12-22 16:06:46.280] [D] [zway] SENT ACK
[2014-12-22 16:06:46.282] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.284] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.groups = 1 (0x00000001)
[2014-12-22 16:06:46.285] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1 = Empty
[2014-12-22 16:06:46.286] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.max = Empty
[2014-12-22 16:06:46.287] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodes = Empty
[2014-12-22 16:06:46.288] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodesToFollow = Empty
[2014-12-22 16:06:46.289] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.max = 0 (0x00000000)
[2014-12-22 16:06:46.291] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodes = byte[0]
[2014-12-22 16:06:46.291] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:06:46.292] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodesToFollow = **********
[2014-12-22 16:06:46.299] [I] [zway] Adding job: Association Get
[2014-12-22 16:06:46.333] [D] [zway] SENDING (cb 0x32): ( 01 0A 00 13 13 03 30 02 0C 05 32 FF )
[2014-12-22 16:06:46.335] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.338] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.340] [D] [zway] SENT ACK
[2014-12-22 16:06:46.341] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.351] [D] [zway] RECEIVED: ( 01 05 00 13 32 00 DB )
[2014-12-22 16:06:46.353] [D] [zway] SENT ACK
[2014-12-22 16:06:46.354] [I] [zway] Job 0x13 (SensorBinary Get v2): Delivered
[2014-12-22 16:06:46.355] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.357] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:46.358] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:06:46.364] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.365] [D] [zway] SendData Response with callback 0x32 received: received by recipient
[2014-12-22 16:06:46.368] [D] [zway] SETDATA devices.19.data.lastSend = 346262 (0x00054896)
[2014-12-22 16:06:46.369] [D] [zway] Job 0x13 (SensorBinary Get v2): success
[2014-12-22 16:06:46.371] [I] [zway] Removing job: SensorBinary Get v2
[2014-12-22 16:06:46.372] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 30 03 FF 0C 26 )
[2014-12-22 16:06:46.374] [D] [zway] SENT ACK
[2014-12-22 16:06:46.375] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.376] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12 = Empty
[2014-12-22 16:06:46.378] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12.sensorTypeString = Empty
[2014-12-22 16:06:46.379] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12.level = Empty
[2014-12-22 16:06:46.381] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12.sensorTypeString = "Motion"
[2014-12-22 16:06:46.383] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12.level = True
[2014-12-22 16:06:46.384] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.12 = Empty
[2014-12-22 16:06:46.385] [D] [zway] SETDATA devices.19.instances.0.commandClasses.48.data.interviewDone = True
[2014-12-22 16:06:46.387] [I] [zway] Node 19:0 CC SensorBinary Interview done
[2014-12-22 16:06:46.420] [I] [core] Creating device sensorBinary ZWayVDev_zway_19-0-48-12
[2014-12-22 16:06:46.426] [D] [zway] SENDING (cb 0x33): ( 01 0A 00 13 13 03 31 03 01 05 33 F3 )
[2014-12-22 16:06:46.429] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.432] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.434] [D] [zway] SENT ACK
[2014-12-22 16:06:46.435] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.445] [D] [zway] RECEIVED: ( 01 05 00 13 33 00 DA )
[2014-12-22 16:06:46.446] [D] [zway] SENT ACK
[2014-12-22 16:06:46.447] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): Delivered
[2014-12-22 16:06:46.448] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.450] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:46.451] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:46.452] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.454] [D] [zway] SendData Response with callback 0x33 received: received by recipient
[2014-12-22 16:06:46.465] [D] [zway] SETDATA devices.19.data.lastSend = 346269 (0x0005489d)
[2014-12-22 16:06:46.466] [D] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): success
[2014-12-22 16:06:46.472] [I] [zway] Removing job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:46.473] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 31 06 01 02 D2 )
[2014-12-22 16:06:46.475] [D] [zway] SENT ACK
[2014-12-22 16:06:46.477] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.478] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1 = Empty
[2014-12-22 16:06:46.480] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.sensorTypeString = Empty
[2014-12-22 16:06:46.481] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.val = Empty
[2014-12-22 16:06:46.482] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.deviceScale = Empty
[2014-12-22 16:06:46.483] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.scale = Empty
[2014-12-22 16:06:46.485] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.scaleString = Empty
[2014-12-22 16:06:46.490] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.sensorTypeString = "Temperature"
[2014-12-22 16:06:46.491] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.deviceScale = 1 (0x00000001)
[2014-12-22 16:06:46.494] [I] [zway] Adding job: SensorMultilevel V5 Get
[2014-12-22 16:06:46.518] [D] [zway] SENDING (cb 0x34): ( 01 0A 00 13 13 03 31 03 03 05 34 F6 )
[2014-12-22 16:06:46.521] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.524] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.526] [D] [zway] SENT ACK
[2014-12-22 16:06:46.528] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.537] [D] [zway] RECEIVED: ( 01 05 00 13 34 00 DD )
[2014-12-22 16:06:46.539] [D] [zway] SENT ACK
[2014-12-22 16:06:46.540] [I] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): Delivered
[2014-12-22 16:06:46.541] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.542] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:46.544] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:46.545] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.550] [D] [zway] SendData Response with callback 0x34 received: received by recipient
[2014-12-22 16:06:46.552] [D] [zway] SETDATA devices.19.data.lastSend = 346276 (0x000548a4)
[2014-12-22 16:06:46.554] [D] [zway] Job 0x13 (SensorMultilevel Supported Sensor Scale Get): success
[2014-12-22 16:06:46.556] [I] [zway] Removing job: SensorMultilevel Supported Sensor Scale Get
[2014-12-22 16:06:46.558] [D] [zway] RECEIVED: ( 01 0A 00 04 00 13 04 31 06 03 01 D3 )
[2014-12-22 16:06:46.559] [D] [zway] SENT ACK
[2014-12-22 16:06:46.560] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.563] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3 = Empty
[2014-12-22 16:06:46.566] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.sensorTypeString = Empty
[2014-12-22 16:06:46.568] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.val = Empty
[2014-12-22 16:06:46.569] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.deviceScale = Empty
[2014-12-22 16:06:46.572] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.scale = Empty
[2014-12-22 16:06:46.573] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.scaleString = Empty
[2014-12-22 16:06:46.583] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.sensorTypeString = "Luminiscence"
[2014-12-22 16:06:46.587] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.deviceScale = 0 (0x00000000)
[2014-12-22 16:06:46.588] [I] [zway] Adding job: SensorMultilevel V5 Get
[2014-12-22 16:06:46.611] [D] [zway] SENDING (cb 0x35): ( 01 09 00 13 13 02 84 05 05 35 45 )
[2014-12-22 16:06:46.613] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.616] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.618] [D] [zway] SENT ACK
[2014-12-22 16:06:46.619] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.628] [D] [zway] RECEIVED: ( 01 05 00 13 35 00 DC )
[2014-12-22 16:06:46.630] [D] [zway] SENT ACK
[2014-12-22 16:06:46.631] [I] [zway] Job 0x13 (Wakeup Get): Delivered
[2014-12-22 16:06:46.632] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.633] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:46.634] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:06:46.636] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.638] [D] [zway] SendData Response with callback 0x35 received: received by recipient
[2014-12-22 16:06:46.638] [D] [zway] SETDATA devices.19.data.lastSend = 346284 (0x000548ac)
[2014-12-22 16:06:46.639] [D] [zway] Job 0x13 (Wakeup Get): success
[2014-12-22 16:06:46.640] [I] [zway] Removing job: Wakeup Get
[2014-12-22 16:06:46.641] [D] [zway] RECEIVED: ( 01 0C 00 04 00 13 06 84 06 00 0E 10 FF 81 )
[2014-12-22 16:06:46.646] [D] [zway] SENT ACK
[2014-12-22 16:06:46.647] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.649] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interval = 3600 (0x00000e10)
[2014-12-22 16:06:46.650] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.nodeId = 255 (0x000000ff)
[2014-12-22 16:06:46.652] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data = Empty
[2014-12-22 16:06:46.653] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interviewDone = True
[2014-12-22 16:06:46.654] [I] [zway] Node 19:0 CC Wakeup Interview done
[2014-12-22 16:06:46.657] [I] [zway] Node 19:0 CC Wakeup: Wakeup interval below boundaries - corrected
[2014-12-22 16:06:46.658] [I] [zway] Adding job: Wakeup interval set
[2014-12-22 16:06:46.660] [I] [zway] Adding job: Assign return route
[2014-12-22 16:06:46.661] [I] [zway] Adding job: Wakeup Get
[2014-12-22 16:06:46.662] [I] [zway] Node 19:0 CC Wakeup: Auto Configuration done
[2014-12-22 16:06:46.704] [D] [zway] SENDING (cb 0x36): ( 01 0A 00 13 13 03 85 02 01 05 36 43 )
[2014-12-22 16:06:46.707] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.709] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.710] [D] [zway] SENT ACK
[2014-12-22 16:06:46.710] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.739] [D] [zway] RECEIVED: ( 01 05 00 13 36 00 DF )
[2014-12-22 16:06:46.740] [D] [zway] SENT ACK
[2014-12-22 16:06:46.741] [I] [zway] Job 0x13 (Association Get): Delivered
[2014-12-22 16:06:46.743] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.744] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:46.747] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 32 (0x00000020)
[2014-12-22 16:06:46.748] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.752] [D] [zway] SendData Response with callback 0x36 received: received by recipient
[2014-12-22 16:06:46.755] [D] [zway] SETDATA devices.19.data.lastSend = 346291 (0x000548b3)
[2014-12-22 16:06:46.758] [D] [zway] Job 0x13 (Association Get): success
[2014-12-22 16:06:46.759] [I] [zway] Removing job: Association Get
[2014-12-22 16:06:46.772] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 85 03 01 04 00 65 )
[2014-12-22 16:06:46.773] [D] [zway] SENT ACK
[2014-12-22 16:06:46.774] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.776] [I] [zway] Node 19:0 CC Association: Group 1 report
[2014-12-22 16:06:46.778] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.max = 4 (0x00000004)
[2014-12-22 16:06:46.779] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodes = byte[0]
[2014-12-22 16:06:46.780] [D] [zway]   ( zero-length buffer )
[2014-12-22 16:06:46.782] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodesToFollow = **********
[2014-12-22 16:06:46.784] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1 = Empty
[2014-12-22 16:06:46.785] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.interviewDone = True
[2014-12-22 16:06:46.787] [I] [zway] Node 19:0 CC Association Interview done
[2014-12-22 16:06:46.789] [I] [zway] Adding job: Association Set
[2014-12-22 16:06:46.791] [D] [zway] Job 0x46 (Assign return route): removing duplicate
[2014-12-22 16:06:46.792] [I] [zway] Adding job: Association Get
[2014-12-22 16:06:46.793] [I] [zway] Node 19:0 CC Association: Auto Configuration done
[2014-12-22 16:06:46.809] [D] [zway] SENDING (cb 0x37): ( 01 0B 00 13 13 04 31 04 01 08 05 37 FE )
[2014-12-22 16:06:46.812] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:46.815] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:46.817] [D] [zway] SENT ACK
[2014-12-22 16:06:46.819] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:46.828] [D] [zway] RECEIVED: ( 01 05 00 13 37 00 DE )
[2014-12-22 16:06:46.830] [D] [zway] SENT ACK
[2014-12-22 16:06:46.831] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2014-12-22 16:06:46.832] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:46.833] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2014-12-22 16:06:46.835] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-12-22 16:06:46.836] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:46.838] [D] [zway] SendData Response with callback 0x37 received: received by recipient
[2014-12-22 16:06:46.839] [D] [zway] SETDATA devices.19.data.lastSend = 346300 (0x000548bc)
[2014-12-22 16:06:46.841] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2014-12-22 16:06:46.842] [I] [zway] Removing job: SensorMultilevel V5 Get
[2014-12-22 16:06:46.873] [D] [zway] RECEIVED: ( 01 0C 00 04 00 13 06 31 05 01 2A 02 BD 42 )
[2014-12-22 16:06:46.875] [D] [zway] SENT ACK
[2014-12-22 16:06:46.877] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:46.878] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.deviceScale = 1 (0x00000001)
[2014-12-22 16:06:46.881] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.val = 21.200001
[2014-12-22 16:06:46.883] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-12-22 16:06:46.888] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1.scaleString = "∞C"
[2014-12-22 16:06:46.889] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.1 = Empty
[2014-12-22 16:06:46.891] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.interviewDone = True
[2014-12-22 16:06:46.892] [I] [zway] Node 19:0 CC SensorMultilevel Interview done
[2014-12-22 16:06:46.895] [I] [zway] Saving configuration data to config/zddx/cc64a4d0-DevicesData.xml
[2014-12-22 16:06:47.522] [D] [zway] SETDATA devices.19.data.keepAwake = False
[2014-12-22 16:06:47.524] [I] [zway] Interview for Node #19 finished.
[2014-12-22 16:06:47.536] [D] [zway] SENDING (cb 0x38): ( 01 0B 00 13 13 04 31 04 03 00 05 38 FB )
[2014-12-22 16:06:47.539] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:47.542] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:47.544] [D] [zway] SENT ACK
[2014-12-22 16:06:47.545] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:47.555] [D] [zway] RECEIVED: ( 01 05 00 13 38 00 D1 )
[2014-12-22 16:06:47.557] [D] [zway] SENT ACK
[2014-12-22 16:06:47.558] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2014-12-22 16:06:47.560] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:47.561] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2014-12-22 16:06:47.562] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-12-22 16:06:47.562] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:47.563] [D] [zway] SendData Response with callback 0x38 received: received by recipient
[2014-12-22 16:06:47.564] [D] [zway] SETDATA devices.19.data.lastSend = 346371 (0x00054903)
[2014-12-22 16:06:47.565] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2014-12-22 16:06:47.566] [I] [zway] Removing job: SensorMultilevel V5 Get
[2014-12-22 16:06:47.567] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 31 05 03 01 1A CA )
[2014-12-22 16:06:47.568] [I] [core] Creating device sensorMultilevel ZWayVDev_zway_19-0-49-1
[2014-12-22 16:06:47.572] [D] [zway] SENT ACK
[2014-12-22 16:06:47.572] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:47.573] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.deviceScale = 0 (0x00000000)
[2014-12-22 16:06:47.574] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.scale = 0 (0x00000000)
[2014-12-22 16:06:47.575] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.val = 26.000000
[2014-12-22 16:06:47.617] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3.scaleString = "%"
[2014-12-22 16:06:47.618] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.3 = Empty
[2014-12-22 16:06:47.639] [D] [zway] SENDING (cb 0x39): ( 01 0D 00 13 13 06 84 04 00 01 68 01 05 39 20 )
[2014-12-22 16:06:47.642] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:47.645] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:47.650] [D] [zway] SENT ACK
[2014-12-22 16:06:47.651] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:47.658] [D] [zway] RECEIVED: ( 01 05 00 13 39 00 D0 )
[2014-12-22 16:06:47.660] [D] [zway] SENT ACK
[2014-12-22 16:06:47.661] [I] [zway] Job 0x13 (Wakeup interval set): Delivered
[2014-12-22 16:06:47.662] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:47.663] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-12-22 16:06:47.665] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 9 (0x00000009)
[2014-12-22 16:06:47.666] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:47.668] [D] [zway] SendData Response with callback 0x39 received: received by recipient
[2014-12-22 16:06:47.670] [D] [zway] SETDATA devices.19.data.lastSend = 346380 (0x0005490c)
[2014-12-22 16:06:47.671] [D] [zway] Job 0x13 (Wakeup interval set): success
[2014-12-22 16:06:47.672] [I] [zway] Removing job: Wakeup interval set
[2014-12-22 16:06:47.679] [I] [core] Creating device sensorMultilevel ZWayVDev_zway_19-0-49-3
[2014-12-22 16:06:47.728] [D] [zway] SENDING (cb 0x3a): ( 01 09 00 13 13 02 84 05 05 3A 4A )
[2014-12-22 16:06:47.731] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:47.734] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:47.740] [D] [zway] SENT ACK
[2014-12-22 16:06:47.741] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:47.747] [D] [zway] RECEIVED: ( 01 05 00 13 3A 00 D3 )
[2014-12-22 16:06:47.748] [D] [zway] SENT ACK
[2014-12-22 16:06:47.749] [I] [zway] Job 0x13 (Wakeup Get): Delivered
[2014-12-22 16:06:47.750] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:47.752] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-12-22 16:06:47.753] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 8 (0x00000008)
[2014-12-22 16:06:47.755] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:47.756] [D] [zway] SendData Response with callback 0x3a received: received by recipient
[2014-12-22 16:06:47.758] [D] [zway] SETDATA devices.19.data.lastSend = 346388 (0x00054914)
[2014-12-22 16:06:47.759] [D] [zway] Job 0x13 (Wakeup Get): success
[2014-12-22 16:06:47.761] [I] [zway] Removing job: Wakeup Get
[2014-12-22 16:06:47.762] [D] [zway] RECEIVED: ( 01 0C 00 04 00 13 06 84 06 00 01 68 01 08 )
[2014-12-22 16:06:47.764] [D] [zway] SENT ACK
[2014-12-22 16:06:47.765] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:47.767] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.interval = 360 (0x00000168)
[2014-12-22 16:06:47.768] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data.nodeId = 1 (0x00000001)
[2014-12-22 16:06:47.769] [D] [zway] SETDATA devices.19.instances.0.commandClasses.132.data = Empty
[2014-12-22 16:06:47.823] [D] [zway] SENDING (cb 0x3b): ( 01 0B 00 13 13 04 85 01 01 01 05 3B 4A )
[2014-12-22 16:06:47.826] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:47.829] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:47.831] [D] [zway] SENT ACK
[2014-12-22 16:06:47.832] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:47.842] [D] [zway] RECEIVED: ( 01 05 00 13 3B 00 D2 )
[2014-12-22 16:06:47.847] [D] [zway] SENT ACK
[2014-12-22 16:06:47.848] [I] [zway] Job 0x13 (Association Set): Delivered
[2014-12-22 16:06:47.849] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:47.852] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2014-12-22 16:06:47.853] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2014-12-22 16:06:47.856] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:47.860] [D] [zway] SendData Response with callback 0x3b received: received by recipient
[2014-12-22 16:06:47.861] [D] [zway] SETDATA devices.19.data.lastSend = 346395 (0x0005491b)
[2014-12-22 16:06:47.862] [D] [zway] Job 0x13 (Association Set): success
[2014-12-22 16:06:47.865] [I] [zway] Removing job: Association Set
[2014-12-22 16:06:47.911] [D] [zway] SENDING (cb 0x3c): ( 01 06 00 46 13 01 3C 91 )
[2014-12-22 16:06:47.913] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:47.917] [D] [zway] RECEIVED: ( 01 04 01 46 01 BD )
[2014-12-22 16:06:47.918] [D] [zway] SENT ACK
[2014-12-22 16:06:47.918] [D] [zway] Delivered to Z-Wave stack: process started
[2014-12-22 16:06:47.994] [D] [zway] RECEIVED: ( 01 05 00 46 3C 00 80 )
[2014-12-22 16:06:47.995] [D] [zway] SENT ACK
[2014-12-22 16:06:47.995] [D] [zway] AssignReturnRoute Response with callback 0x3c received: received by recipient
[2014-12-22 16:06:47.995] [D] [zway] Job 0x46 (Assign return route): success
[2014-12-22 16:06:47.995] [I] [zway] Removing job: Assign return route
[2014-12-22 16:06:48.006] [D] [zway] SENDING (cb 0x3d): ( 01 0A 00 13 13 03 85 02 01 05 3D 48 )
[2014-12-22 16:06:48.008] [D] [zway] RECEIVED ACK
[2014-12-22 16:06:48.011] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-12-22 16:06:48.011] [D] [zway] SENT ACK
[2014-12-22 16:06:48.011] [D] [zway] Delivered to Z-Wave stack
[2014-12-22 16:06:48.023] [D] [zway] RECEIVED: ( 01 05 00 13 3D 00 D4 )
[2014-12-22 16:06:48.025] [D] [zway] SENT ACK
[2014-12-22 16:06:48.026] [I] [zway] Job 0x13 (Association Get): Delivered
[2014-12-22 16:06:48.027] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2014-12-22 16:06:48.028] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-12-22 16:06:48.030] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2014-12-22 16:06:48.031] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2014-12-22 16:06:48.034] [D] [zway] SendData Response with callback 0x3d received: received by recipient
[2014-12-22 16:06:48.034] [D] [zway] SETDATA devices.19.data.lastSend = 346411 (0x0005492b)
[2014-12-22 16:06:48.035] [D] [zway] Job 0x13 (Association Get): success
[2014-12-22 16:06:48.036] [I] [zway] Removing job: Association Get
[2014-12-22 16:06:48.036] [D] [zway] RECEIVED: ( 01 0C 00 04 00 13 06 85 03 01 04 00 01 60 )
[2014-12-22 16:06:48.038] [D] [zway] SENT ACK
[2014-12-22 16:06:48.039] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2014-12-22 16:06:48.040] [I] [zway] Node 19:0 CC Association: Group 1 report
[2014-12-22 16:06:48.041] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.max = 4 (0x00000004)
[2014-12-22 16:06:48.042] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodes = byte[1]
[2014-12-22 16:06:48.042] [D] [zway]   ( 01 )
[2014-12-22 16:06:48.043] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1.nodesToFollow = **********
[2014-12-22 16:06:48.044] [D] [zway] SETDATA devices.19.instances.0.commandClasses.133.data.1 = Empty
[2014-12-22 16:07:06.112] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.113] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.115] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.116] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.117] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.118] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:06.120] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.243] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.285] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.316] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.368] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.430] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.467] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.500] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.551] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.604] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.666] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.707] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.738] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.781] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.803] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.823] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.865] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.876] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.907] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:07.959] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:08.011] [D] [zway] Job 0x13: deleted from queue
[2014-12-22 16:07:08.134] [D] [zway] Job 0x46: deleted from queue
[2014-12-22 16:07:08.155] [D] [zway] Job 0x13: deleted from queue
Tiptop
Re: EZMotion PIR detector - any success?
Post by Tiptop »
The final result of all the above operations was the following:
The device worked normally, it detected all motion but the strange thing was that it consumed 20 mA of battery power! Please note that I successfully set the wakeup interval to 3600 s - which obviously worked as the device didn't respond to Wave commands without waking it up.
The away-server also showed on the status page the correct wakeup time configuration (1 hour).
So far, so good: After about half an hour, I noticed the current consumption having reduced to less than 1 mA - I guess the device was now in power saving mode. However, it didn't detect motion, anymore. It didn't wake up, as well, anymore.
After performing a power cycle (switching the lab power supply output off and on again), the device worked like before: the (very high= 20 mA current consumption, motion detection... after several minutes it fell to the nonworking state, again.
Does anyone have an idea what is going on here?
Many thanks in advance!!
This device stays awake 10 minutes after the inclusion. So, 20mA for 10 minutes was ok. This is to let you configure it.
Then it went into sleep mode and motion detection should work. We have seen many strangeness of this device with no solution found. So can not say what to do except for sending a mail to Express Controls . ;(
