In the *.xml, you can specify paths for ZDDX, htdocs, automation etc. but it seem's there are issue's in the folder structure that are rectified with the use of symlinks.
It appears that the htdocs folder is dependant on the presence of the the config, translations and ZDDX folder, even when these are specified in the config.xml file.
config.xml and its paths
Using BMSLink https://linode.bmslink.co.uk with z-way-server. http://linode.bmslink.co.uk:4567
Re: config.xml and its paths
There's no such things in config.xml anymore. We've removed them in 2.0.
Ah ok... i'll make do whilst I'm forced to remain on 1.7.x
Looking forward to v2.x
