It is clear that you have at least two versions of Z-Way running.
Second, your output is ok, since the remaining goes into the log.
Starting HTTP server on port xxxx...
magadheera
Re: Starting HTTP server on port xxxx...
Output is ok, can please give me more info on this please. Actually i am running with only one version of Z-way, if there is a way to check how many versions are running?
On console give command top to see the processes.magadheera wrote: if there is a way to check how many versions are running?
