I have a recessed door sensor and a multi sensor. I have got the expert UI running but the sensors are not responding. I am using the razberry board.
Thank you
MC
Sensors not responding
Re: Sensors not responding
Anything interesting in /var/log/z-way-server.log about them?
Did you set them up to send unsolicited reports about things?
Do they update if you force them to in the interface (whenever they wake up, if they are battery powered)?
s.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:09:21.865] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:09:21.865] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:09:21.866] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:09:30.533] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 84 07 76 )
[2015-02-08 00:09:30.534] [D] [zway] SENT ACK
[2015-02-08 00:09:30.534] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:09:30.534] [I] [zway] Node 4:0 CC Wakeup: Wakeup notification
[2015-02-08 00:09:30.534] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastWakeup = 1423354170 (0x54d6a93a)
[2015-02-08 00:09:30.535] [D] [zway] SETDATA devices.4.data.isAwake = True
[2015-02-08 00:09:30.535] [D] [zway] SETDATA devices.4.data.lastSend = 4612615 (0x00466207)
[2015-02-08 00:09:30.535] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4611615 (0x00465e1f)
[2015-02-08 00:09:30.535] [D] [zway] Running wakeup handler for node 4
[2015-02-08 00:09:30.535] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354170 (0x54d6a93a)
[2015-02-08 00:09:30.535] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:09:30.536] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:09:30.556] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2015-02-08 00:09:30.557] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:09:30.557] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-02-08 00:09:30.557] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:09:30.557] [I] [zway] Adding job: Nonce Get
[2015-02-08 00:09:30.558] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354170 (0x54d6a93a)
[2015-02-08 00:09:30.558] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:09:30.558] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:09:30.559] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4612616 (0x00466208)
[2015-02-08 00:09:30.610] [D] [zway] SENDING (cb 0x5c): ( 01 09 00 13 04 02 98 40 05 5C 62 )
[2015-02-08 00:09:30.612] [D] [zway] RECEIVED ACK
[2015-02-08 00:09:30.615] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:09:30.615] [D] [zway] SENT ACK
[2015-02-08 00:09:30.615] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:09:30.631] [D] [zway] RECEIVED: ( 01 05 00 13 5C 00 B5 )
[2015-02-08 00:09:30.631] [D] [zway] SENT ACK
[2015-02-08 00:09:30.631] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2015-02-08 00:09:30.631] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:09:30.631] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-02-08 00:09:30.632] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-02-08 00:09:30.632] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:09:30.632] [D] [zway] SendData Response with callback 0x5c received: received by recipient
[2015-02-08 00:09:30.633] [D] [zway] SETDATA devices.4.data.lastSend = 4612623 (0x0046620f)
[2015-02-08 00:09:30.633] [D] [zway] Job 0x13 (Nonce Get): success
[2015-02-08 00:09:30.633] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:09:30.633] [I] [zway] Removing job: Nonce Get
[2015-02-08 00:09:30.643] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 86 2F 42 EC BE 75 D3 77 95 )
[2015-02-08 00:09:30.643] [D] [zway] SENT ACK
[2015-02-08 00:09:30.644] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:09:30.644] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2015-02-08 00:09:30.644] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2015-02-08 00:09:30.644] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:09:30.644] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2015-02-08 00:09:30.644] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Wakeup Sleep
[2015-02-08 00:09:30.645] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2015-02-08 00:09:30.645] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2015-02-08 00:09:30.645] [I] [zway] Adding job: Security, Wakeup Sleep
[2015-02-08 00:09:30.717] [D] [zway] SENDING (cb 0x5d): ( 01 1D 00 13 04 16 98 81 C9 37 5B 2F 1A 41 5F 71 1F FF 0B 86 76 0A D7 72 1F E6 24 B5 05 5D 81 )
[2015-02-08 00:09:30.721] [D] [zway] RECEIVED ACK
[2015-02-08 00:09:30.724] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:09:30.724] [D] [zway] SENT ACK
[2015-02-08 00:09:30.724] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Response received - transfered to encapsulated jobs
[2015-02-08 00:09:30.724] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:09:30.725] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:09:30.744] [D] [zway] RECEIVED: ( 01 05 00 13 5D 00 B4 )
[2015-02-08 00:09:30.744] [D] [zway] SENT ACK
[2015-02-08 00:09:30.745] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Callback received - transfered to encapsulated jobs
[2015-02-08 00:09:30.745] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-02-08 00:09:30.745] [D] [zway] SendData Response with callback 0x5d received: received by recipient
[2015-02-08 00:09:30.745] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Delivered
[2015-02-08 00:09:30.745] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:09:30.745] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 25 (0x00000019)
[2015-02-08 00:09:30.746] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2015-02-08 00:09:30.746] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:09:30.746] [D] [zway] SendData Response with callback 0x5d received: received by recipient
[2015-02-08 00:09:30.746] [D] [zway] SETDATA devices.4.data.lastSend = 4612631 (0x00466217)
[2015-02-08 00:09:30.747] [D] [zway] Job 0x13 (Security, Wakeup Sleep): success
[2015-02-08 00:09:30.747] [I] [zway] Removing job: Security, Wakeup Sleep
[2015-02-08 00:09:50.707] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:09:50.768] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:09:50.851] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:09:50.861] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:11:19.302] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 FF 25 )
[2015-02-08 00:11:19.302] [D] [zway] SENT ACK
[2015-02-08 00:11:19.302] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:11:19.302] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:11:19.303] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:11:19.303] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:11:19.303] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:11:19.303] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:11:19.309] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 FF 2D )
[2015-02-08 00:11:19.309] [D] [zway] SENT ACK
[2015-02-08 00:11:19.310] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:11:19.310] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:11:19.310] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:11:19.310] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:11:19.310] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:11:19.311] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:11:43.326] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 00 DA )
[2015-02-08 00:11:43.327] [D] [zway] SENT ACK
[2015-02-08 00:11:43.327] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:11:43.327] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:11:43.327] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:11:43.327] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:11:43.328] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:11:43.328] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:11:43.334] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 00 D2 )
[2015-02-08 00:11:43.334] [D] [zway] SENT ACK
[2015-02-08 00:11:43.334] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:11:43.335] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:11:43.335] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:11:43.335] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:11:43.335] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:11:43.335] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:13:30.882] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 84 07 76 )
[2015-02-08 00:13:30.882] [D] [zway] SENT ACK
[2015-02-08 00:13:30.882] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:13:30.882] [I] [zway] Node 4:0 CC Wakeup: Wakeup notification
[2015-02-08 00:13:30.883] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastWakeup = 1423354410 (0x54d6aa2a)
[2015-02-08 00:13:30.883] [D] [zway] SETDATA devices.4.data.isAwake = True
[2015-02-08 00:13:30.883] [D] [zway] SETDATA devices.4.data.lastSend = 4636087 (0x0046bdb7)
[2015-02-08 00:13:30.883] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4635087 (0x0046b9cf)
[2015-02-08 00:13:30.883] [D] [zway] Running wakeup handler for node 4
[2015-02-08 00:13:30.883] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354410 (0x54d6aa2a)
[2015-02-08 00:13:30.884] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:13:30.884] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:13:30.905] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2015-02-08 00:13:30.905] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:13:30.905] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-02-08 00:13:30.905] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:13:30.905] [I] [zway] Adding job: Nonce Get
[2015-02-08 00:13:30.906] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354410 (0x54d6aa2a)
[2015-02-08 00:13:30.906] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:13:30.906] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:13:30.906] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4636088 (0x0046bdb8)
[2015-02-08 00:13:30.957] [D] [zway] SENDING (cb 0x5e): ( 01 09 00 13 04 02 98 40 05 5E 60 )
[2015-02-08 00:13:30.960] [D] [zway] RECEIVED ACK
[2015-02-08 00:13:30.962] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:13:30.963] [D] [zway] SENT ACK
[2015-02-08 00:13:30.963] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:13:30.978] [D] [zway] RECEIVED: ( 01 05 00 13 5E 00 B7 )
[2015-02-08 00:13:30.978] [D] [zway] SENT ACK
[2015-02-08 00:13:30.979] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2015-02-08 00:13:30.979] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:13:30.979] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-02-08 00:13:30.979] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-02-08 00:13:30.980] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:13:30.980] [D] [zway] SendData Response with callback 0x5e received: received by recipient
[2015-02-08 00:13:30.980] [D] [zway] SETDATA devices.4.data.lastSend = 4636095 (0x0046bdbf)
[2015-02-08 00:13:30.980] [D] [zway] Job 0x13 (Nonce Get): success
[2015-02-08 00:13:30.980] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:13:30.981] [I] [zway] Removing job: Nonce Get
[2015-02-08 00:13:30.990] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 79 06 F0 89 88 E3 EA F5 8F )
[2015-02-08 00:13:30.991] [D] [zway] SENT ACK
[2015-02-08 00:13:30.991] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:13:30.991] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2015-02-08 00:13:30.991] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2015-02-08 00:13:30.991] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:13:30.992] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2015-02-08 00:13:30.992] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Wakeup Sleep
[2015-02-08 00:13:30.992] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2015-02-08 00:13:30.993] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2015-02-08 00:13:30.993] [I] [zway] Adding job: Security, Wakeup Sleep
[2015-02-08 00:13:31.066] [D] [zway] SENDING (cb 0x5f): ( 01 1D 00 13 04 16 98 81 AA 2D E0 5C AD B3 0D C7 38 63 AD 79 7C AB CD CD 1D 91 23 32 05 5F 8A )
[2015-02-08 00:13:31.069] [D] [zway] RECEIVED ACK
[2015-02-08 00:13:31.072] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:13:31.073] [D] [zway] SENT ACK
[2015-02-08 00:13:31.073] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Response received - transfered to encapsulated jobs
[2015-02-08 00:13:31.073] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:13:31.092] [D] [zway] RECEIVED: ( 01 05 00 13 5F 00 B6 )
[2015-02-08 00:13:31.092] [D] [zway] SENT ACK
[2015-02-08 00:13:31.093] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Callback received - transfered to encapsulated jobs
[2015-02-08 00:13:31.093] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-02-08 00:13:31.093] [D] [zway] SendData Response with callback 0x5f received: received by recipient
[2015-02-08 00:13:31.093] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Delivered
[2015-02-08 00:13:31.093] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:13:31.094] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 25 (0x00000019)
[2015-02-08 00:13:31.094] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2015-02-08 00:13:31.094] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:13:31.094] [D] [zway] SendData Response with callback 0x5f received: received by recipient
[2015-02-08 00:13:31.095] [D] [zway] SETDATA devices.4.data.lastSend = 4636103 (0x0046bdc7)
[2015-02-08 00:13:31.095] [D] [zway] Job 0x13 (Security, Wakeup Sleep): success
[2015-02-08 00:13:31.095] [I] [zway] Removing job: Security, Wakeup Sleep
[2015-02-08 00:13:45.989] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 FF 25 )
[2015-02-08 00:13:45.989] [D] [zway] SENT ACK
[2015-02-08 00:13:45.990] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:13:45.990] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:13:45.990] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:13:45.991] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:13:45.991] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:13:45.991] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:13:45.997] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 FF 2D )
[2015-02-08 00:13:45.997] [D] [zway] SENT ACK
[2015-02-08 00:13:45.997] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:13:45.997] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:13:45.997] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:13:45.998] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:13:45.998] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:13:45.998] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:13:51.058] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:13:51.116] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:13:51.208] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:13:51.219] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:14:19.030] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 00 DA )
[2015-02-08 00:14:19.031] [D] [zway] SENT ACK
[2015-02-08 00:14:19.031] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:14:19.031] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:14:19.031] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:14:19.031] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:14:19.032] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:14:19.032] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:14:19.037] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 00 D2 )
[2015-02-08 00:14:19.038] [D] [zway] SENT ACK
[2015-02-08 00:14:19.038] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:14:19.038] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:14:19.038] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:14:19.038] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:14:19.038] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:14:19.039] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:14:39.293] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 FF 25 )
[2015-02-08 00:14:39.294] [D] [zway] SENT ACK
[2015-02-08 00:14:39.294] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:14:39.294] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:14:39.294] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:14:39.294] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:14:39.295] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:14:39.295] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:14:39.300] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 FF 2D )
[2015-02-08 00:14:39.301] [D] [zway] SENT ACK
[2015-02-08 00:14:39.301] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:14:39.301] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:14:39.302] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:14:39.302] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-02-08 00:14:39.302] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2015-02-08 00:14:39.302] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:15:03.360] [D] [zway] RECEIVED: ( 01 09 00 04 08 02 03 20 01 00 DA )
[2015-02-08 00:15:03.360] [D] [zway] SENT ACK
[2015-02-08 00:15:03.360] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:15:03.360] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:15:03.361] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:15:03.361] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:15:03.361] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:15:03.361] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:15:03.367] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 20 01 00 D2 )
[2015-02-08 00:15:03.367] [D] [zway] SENT ACK
[2015-02-08 00:15:03.367] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:15:03.368] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2015-02-08 00:15:03.368] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-02-08 00:15:03.368] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-02-08 00:15:03.368] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = False
[2015-02-08 00:15:03.369] [D] [zway] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2015-02-08 00:17:31.169] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 84 07 76 )
[2015-02-08 00:17:31.169] [D] [zway] SENT ACK
[2015-02-08 00:17:31.169] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:17:31.170] [I] [zway] Node 4:0 CC Wakeup: Wakeup notification
[2015-02-08 00:17:31.170] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastWakeup = 1423354651 (0x54d6ab1b)
[2015-02-08 00:17:31.170] [D] [zway] SETDATA devices.4.data.isAwake = True
[2015-02-08 00:17:31.170] [D] [zway] SETDATA devices.4.data.lastSend = 4659544 (0x00471958)
[2015-02-08 00:17:31.170] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4658544 (0x00471570)
[2015-02-08 00:17:31.170] [D] [zway] Running wakeup handler for node 4
[2015-02-08 00:17:31.171] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354651 (0x54d6ab1b)
[2015-02-08 00:17:31.171] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:17:31.171] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:17:31.192] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2015-02-08 00:17:31.192] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:17:31.192] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-02-08 00:17:31.193] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:17:31.193] [I] [zway] Adding job: Nonce Get
[2015-02-08 00:17:31.193] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1423354651 (0x54d6ab1b)
[2015-02-08 00:17:31.193] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2015-02-08 00:17:31.193] [I] [zway] Adding job: Wakeup Sleep
[2015-02-08 00:17:31.193] [D] [zway] SETDATA devices.4.data.lastNonceGet = 4659545 (0x00471959)
[2015-02-08 00:17:31.246] [D] [zway] SENDING (cb 0x60): ( 01 09 00 13 04 02 98 40 05 60 5E )
[2015-02-08 00:17:31.248] [D] [zway] RECEIVED ACK
[2015-02-08 00:17:31.251] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:17:31.251] [D] [zway] SENT ACK
[2015-02-08 00:17:31.251] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:17:31.267] [D] [zway] RECEIVED: ( 01 05 00 13 60 00 89 )
[2015-02-08 00:17:31.267] [D] [zway] SENT ACK
[2015-02-08 00:17:31.267] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2015-02-08 00:17:31.267] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:17:31.268] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-02-08 00:17:31.268] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-02-08 00:17:31.268] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:17:31.268] [D] [zway] SendData Response with callback 0x60 received: received by recipient
[2015-02-08 00:17:31.268] [D] [zway] SETDATA devices.4.data.lastSend = 4659552 (0x00471960)
[2015-02-08 00:17:31.269] [D] [zway] Job 0x13 (Nonce Get): success
[2015-02-08 00:17:31.269] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2015-02-08 00:17:31.270] [I] [zway] Removing job: Nonce Get
[2015-02-08 00:17:31.279] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 D8 E9 C9 C9 8A D8 DF D9 98 )
[2015-02-08 00:17:31.279] [D] [zway] SENT ACK
[2015-02-08 00:17:31.279] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2015-02-08 00:17:31.280] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2015-02-08 00:17:31.280] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2015-02-08 00:17:31.280] [I] [zway] Removing job: Wakeup Sleep
[2015-02-08 00:17:31.280] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2015-02-08 00:17:31.280] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Wakeup Sleep
[2015-02-08 00:17:31.281] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2015-02-08 00:17:31.281] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2015-02-08 00:17:31.281] [I] [zway] Adding job: Security, Wakeup Sleep
[2015-02-08 00:17:31.353] [D] [zway] SENDING (cb 0x61): ( 01 1D 00 13 04 16 98 81 8E 1E 91 71 8D AF 3C 59 46 8F 08 D8 51 79 47 22 0F AC 8D 9E 05 61 4D )
[2015-02-08 00:17:31.357] [D] [zway] RECEIVED ACK
[2015-02-08 00:17:31.360] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-02-08 00:17:31.360] [D] [zway] SENT ACK
[2015-02-08 00:17:31.360] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Response received - transfered to encapsulated jobs
[2015-02-08 00:17:31.361] [D] [zway] Delivered to Z-Wave stack
[2015-02-08 00:17:31.380] [D] [zway] RECEIVED: ( 01 05 00 13 61 00 88 )
[2015-02-08 00:17:31.380] [D] [zway] SENT ACK
[2015-02-08 00:17:31.380] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Callback received - transfered to encapsulated jobs
[2015-02-08 00:17:31.380] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-02-08 00:17:31.381] [D] [zway] SendData Response with callback 0x61 received: received by recipient
[2015-02-08 00:17:31.381] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Delivered
[2015-02-08 00:17:31.381] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2015-02-08 00:17:31.381] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 25 (0x00000019)
[2015-02-08 00:17:31.382] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2015-02-08 00:17:31.382] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2015-02-08 00:17:31.382] [D] [zway] SendData Response with callback 0x61 received: received by recipient
[2015-02-08 00:17:31.382] [D] [zway] SETDATA devices.4.data.lastSend = 4659560 (0x00471968)
[2015-02-08 00:17:31.382] [D] [zway] Job 0x13 (Security, Wakeup Sleep): success
[2015-02-08 00:17:31.382] [I] [zway] Removing job: Security, Wakeup Sleep
[2015-02-08 00:17:51.338] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:17:51.405] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:17:51.487] [D] [zway] Job 0x13: deleted from queue
[2015-02-08 00:17:51.498] [D] [zway] Job 0x13: deleted from queue
Thank you
MC
Is there any good guides to the initial setup? I tried the configuration page, but it doesnt respond.
Edit: Sorry thats the expert commands in the configuration page.
Thank you
MC
Thank you
MC
Does the configuration need to be set for the UI to work?
Thank you
MC
Thank you
MC
You probably should be more specific, because it would be hard to diagnose without knowing anything.
1) Which sensors (vendor, model, firmware version) do you have?
2) Which RaZberry board (3rd or 5th gen) have you got? What version of z-way-server you're running?
Also, what does "sensors are not responding" mean?
Have you managed to include them into your network, so they appear in devices list? What identifiers do they have (so we could filter only relevant entries from the log)?
Have they passed the interview? If not, which command classes are marked as failed? Does forcing re-interview help?
Does anything happen if you press Get button in the Expert UI? As mentioned before, you need to wake a battery-powered device to make enqueued commands delivered.
Looking at your log, I see triggering of Sensor Binary state for device 2, which looks pretty much like "responding" to me. For example:
Does it reflect in Expert UI? You may try the old Blue UI as well.
