Linear GD00Z-X Garage Door Opener
Re: Linear GD00Z-X Garage Door Opener
I excluded the device and re-included it, same result.
What is autocompletion?. I did upgrade the device database the day before.pofs wrote:Okay, nailed it. Autocompletion is not always a good thing.
Fix will be included in the next release.
I mean code autocompletion in Xcode. Didn't notice when it substituted the wrong variable name, and reading the incorrect address crashes z-way-server process.RottenMutt wrote:What is autocompletion?. I did upgrade the device database the day before.pofs wrote:Okay, nailed it. Autocompletion is not always a good thing.
http://razberry.z-wave.me/install/v2.0.1-rc14a or could be 15. Not available yet
Check here http://razberry.z-wave.me/z-way-server/ for all released versions
Was hoping for an update since the error has been discovered.
I'm sure it'll be in rc15 RottenMutt. This fix and many others. You can't expect a release for a single simple fix, specially when this feature is new.
I'm sure there are several other issues being resolved. for instance, the issue where the device record doesn't show up in the device list for this even though its in the pepper1 db. so even if this would interview properly, we can't select the device description yet. github issue #38
i was thinking pofs would want to know if his code works, sometimes it is easier to debug when it is fresh in your mind; but then in a month, you might say what the heck was i thinking...
2.0.1-rc15 is now out and available. Installing and rebooting right now.
Quick notes so far:
Interview of the BarrierOperator worked fine. My linear device, which was already included and I just did a re-interview, continually failed to complete the Version command class. All others passed.
The device descriptor still does not show up in the list despite being in the ZDDX directory. I ran the UpdateXMLs.sh script and got the following output
Note that the following
Error loading Z-Wave Device Description XML 584-014f-4744-3032-03-03-67-00-15.xml: list index out of range
is the descriptor for this device. I haven't yet figured out what is causing the list index out of range error. I had previously assumed this was something that wasn't aware of the new barrier operator command class but that is only a guess.
I would suggest that z-way should correctly parse everything included in the pepper1 download. I will attempt to diagnose what the failure is.
Tomorrow I hope to start looking into the actual z-way updates around this device and see if I can manually initiate any of the barrier commands, e.g. make this device work through advanced mode.
pi@raspberrypi /opt/z-way-server/ZDDX $ ./UpdateXMLs.sh
Updating ZDD XML database
Done
Creating index file for ZDDX
Error loading Z-Wave Device Description XML 466-0109-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 620-013c-0000-0000-03-03-95-01-05.xml: list index out of range
Error loading Z-Wave Device Description XML 621-001e-0004-0001-03-03-99-01-03.xml: list index out of range
Error loading Z-Wave Device Description XML 547-0109-2001-0105-03-03-92-05-01.xml: list index out of range
Error loading Z-Wave Device Description XML 612-013c-0004-000a-03-03-95-01-08.xml: list index out of range
Error loading Z-Wave Device Description XML 550-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 626-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 575-013c-0000-0000-03-03-95-01-11.xml: list index out of range
Error loading Z-Wave Device Description XML 596-0086-0004-0050-03-03-5c-01-17.xml: list index out of range
Error loading Z-Wave Device Description XML 656-0115-0100-0201-06-04-05-00-30.xml: list index out of range
Error loading Z-Wave Device Description XML 512-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 556-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 507-0109-2005-0505-03-03-53-0e-01.xml: list index out of range
Error loading Z-Wave Device Description XML 631-0115-0100-0103-02-03-63-01-03.xml: list index out of range
Error loading Z-Wave Device Description XML 618-0086-0002-0059-03-03-5c-01-0c.xml: list index out of range
Error loading Z-Wave Device Description XML 290-0068-0000-0000-00-02-4e-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 574-0182-0001-0001-01-03-40-03-94.xml: list index out of range
Error loading Z-Wave Device Description XML 602-013c-0002-001e-03-03-95-01-13.xml: list index out of range
Error loading Z-Wave Device Description XML 537-0109-2005-0505-03-03-83-14-03.xml: list index out of range
Error loading Z-Wave Device Description XML 613-013c-0000-0000-03-03-95-01-11.xml: list index out of range
Error loading Z-Wave Device Description XML 446-0128-0128-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 649-0115-0000-0000-00-02-00-02-00.xml: list index out of range
Error loading Z-Wave Device Description XML 345-0115-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 625-0109-2002-0205-03-03-95-05-01.xml: list index out of range
Error loading Z-Wave Device Description XML 588-0109-2004-04a4-03-03-95-14-06.xml: list index out of range
Error loading Z-Wave Device Description XML 648-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 581-0109-2004-04a4-03-03-95-14-06.xml: list index out of range
Error loading Z-Wave Device Description XML 628-0000-0000-0000-06-03-67-03-00.xml: list index out of range
Error loading Z-Wave Device Description XML 409-0123-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 582-0109-2004-0404-03-03-95-14-08.xml: list index out of range
Error loading Z-Wave Device Description XML 640-0086-0002-004a-03-03-5c-01-02.xml: list index out of range
Done
Index created
