Inclusion and Inteview Multisensor
opperman
Post by opperman »
Hello Forum,
I have a problem with my new sensors Philio Slim Multi-Sensor PST02-A. For test purpose I already bought one before, everything worked without problems. My latest sensors are Application Version 1.17, SDK Version 6.51.02, the old one still was Application Version 1.0, SDK version 6.02.00.
During inclusion in my z-wave network the interview does not complete totally. After several reboots of my Razberry (after some configuration changes I can't access the webinterface anymore and have to reboot the z-wave Server) the only item for which the interview stays incomplete is "AssociationGroupInformation". Even repeated complete interview and re-include did not solve the problem. Because of the missing association the sensor does not send triggering events to the Razberry.
I don't know any other solutions, maybe a Firmware-downgrade could solve the problem? Where can I download Firmware for Philio sensors?
Thanks for your help
Christian
thaui
Re: Inclusion and Inteview Multisensor
Post by thaui »
I have similar problems with a PST02-1B. I guess it is a z-way server problem. Another Vision door sensor Gen5 has the same behaviour.
pofs
Post by pofs »
Not passing AGI might mean there's something wrong with either Association or AGI itself.
Can you please show the entire data tree for your device? It can be retrieved by requesting http://ip:8083/ZWaveAPI/Run/devices[N] (where N is your device id).
opperman
Post by opperman »
Hello pofs,
I added the data tree from one of my failing sensors, I hope you can see anything helpful.
PS: Sorry for adding the whole source code here in the forum, but an upload with the extension *.json was not allowed, neither *.txt.
{"instances":{"0":{"commandClasses":{"32":{"name":"Basic","data":{"invalidateTime":1425218016,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425218016,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425218016,"updateTime":1425216691,"type":"int","value":0},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425218016,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"int","value":10},"level":{"invalidateTime":1425218016,"updateTime":1425216690,"type":"empty","value":null}},"id":32},"48":{"name":"SensorBinary","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232588,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"typemask":{"invalidateTime":1425216689,"updateTime":1425232587,"type":"int","value":5376},"8":{"invalidateTime":1425232587,"updateTime":1425322475,"type":"empty","value":null,"sensorTypeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Tamper"},"level":{"invalidateTime":1425321935,"updateTime":1425322475,"type":"bool","value":false}},"10":{"invalidateTime":1425232587,"updateTime":1425322475,"type":"empty","value":null,"sensorTypeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Door/Window"},"level":{"invalidateTime":1425321935,"updateTime":1425322475,"type":"bool","value":false}},"12":{"invalidateTime":1425232587,"updateTime":1425322475,"type":"empty","value":null,"sensorTypeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Motion"},"level":{"invalidateTime":1425321935,"updateTime":1425322475,"type":"bool","value":false}}},"id":48},"49":{"name":"SensorMultilevel","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":5},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425234285,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425234283,"type":"int","value":8},"typemask":{"invalidateTime":1425216689,"updateTime":1425234283,"type":"binary","value":[5]},"1":{"invalidateTime":1425321936,"updateTime":1425361238,"type":"empty","value":null,"sensorTypeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Temperature"},"val":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"float","value":16.1},"deviceScale":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":1},"scale":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":0},"scaleString":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"string","value":"°C"}},"3":{"invalidateTime":1425321936,"updateTime":1425361238,"type":"empty","value":null,"sensorTypeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Luminiscence"},"val":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"float","value":3},"deviceScale":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":0},"scale":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":0},"scaleString":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"string","value":"%"}}},"id":49},"89":{"name":"AssociationGroupInformation","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425246161,"type":"bool","value":false},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425246161,"type":"int","value":0},"dynamic":{"invalidateTime":1425216689,"updateTime":1425322475,"type":"bool","value":false},"1":{"invalidateTime":1425234282,"updateTime":1425234283,"type":"empty","value":null,"groupName":{"invalidateTime":1425321879,"updateTime":1425322475,"type":"string","value":"LifeLine"},"mode":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":0},"profile":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":0},"eventCode":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":0},"commands":{"invalidateTime":1425321879,"updateTime":1425234283,"type":"empty","value":null}},"2":{"invalidateTime":1425234282,"updateTime":1425234283,"type":"empty","value":null,"groupName":{"invalidateTime":1425321879,"updateTime":1425234283,"type":"empty","value":null},"mode":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":0},"profile":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":28934},"eventCode":{"invalidateTime":1425234282,"updateTime":1425322475,"type":"int","value":0},"commands":{"invalidateTime":1425321879,"updateTime":1425322475,"type":"empty","value":null,"32":{"invalidateTime":1425322474,"updateTime":1425322475,"type":"binary","value":[1]}}}},"id":89},"90":{"name":"DeviceResetLocally","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425218019,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"int","value":10},"reset":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false}},"id":90},"94":{"name":"ZWavePlusInfo","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"plusVersion":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":1},"roleType":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":6},"nodeType":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":0},"installerIcon":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":3079},"userIcon":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":3079},"roleTypeString":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"string","value":"Reporting Sleeping Slave"}},"id":94},"112":{"name":"Configuration","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"2":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":255},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"3":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":70},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"4":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":99},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"5":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":0},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"6":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":4},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"8":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":3},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"9":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":4},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"10":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":12},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"11":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":12},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"12":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":12},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}},"13":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"val":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":12},"size":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1}}},"id":112},"113":{"name":"Alarm","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":4},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232588,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"V1supported":{"invalidateTime":1425216689,"updateTime":1425232587,"type":"bool","value":false},"typeMask":{"invalidateTime":1425216689,"updateTime":1425232587,"type":"int","value":192},"V1event":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"alarmType":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null},"level":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null}},"6":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"empty","value":null,"typeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Access Control"},"status":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":255},"eventMask":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"int","value":3},"event":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"int","value":23},"eventString":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"string","value":null},"eventParameters":{"invalidateTime":1425232587,"updateTime":1425361238,"type":"binary","value":[]},"eventSequence":{"invalidateTime":1425258828,"updateTime":1425258829,"type":"empty","value":null}},"7":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"empty","value":null,"typeString":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"string","value":"Burglar"},"status":{"invalidateTime":1425232587,"updateTime":1425329944,"type":"int","value":255},"eventMask":{"invalidateTime":1425232587,"updateTime":1425232588,"type":"int","value":2050},"event":{"invalidateTime":1425232587,"updateTime":1425329944,"type":"int","value":8},"eventString":{"invalidateTime":1425232587,"updateTime":1425329944,"type":"string","value":null},"eventParameters":{"invalidateTime":1425232587,"updateTime":1425329944,"type":"binary","value":[]},"eventSequence":{"invalidateTime":1425248851,"updateTime":1425248852,"type":"empty","value":null}}},"id":113},"114":{"name":"ManufacturerSpecific","data":{"invalidateTime":1425216692,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216692,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216692,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425216692,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425216692,"type":"int","value":9},"vendorId":{"invalidateTime":1425216691,"updateTime":1425216692,"type":"int","value":316},"vendor":{"invalidateTime":1425216691,"updateTime":1425216692,"type":"string","value":null},"productId":{"invalidateTime":1425216691,"updateTime":1425216692,"type":"int","value":12},"productType":{"invalidateTime":1425216691,"updateTime":1425216692,"type":"int","value":2}},"id":114},"115":{"name":"PowerLevel","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"level":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":0},"timeout":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":0}},"id":115},"122":{"name":"FirmwareUpdate","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"manufacturerId":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":316},"firmwareId":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":524},"checksum":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":59682},"upgradeable":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"bool","value":true},"fragmentSize":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":32},"firmwareCount":{"invalidateTime":1425232585,"updateTime":1425232586,"type":"int","value":0},"updateStatus":{"invalidateTime":1425245219,"updateTime":1425245220,"type":"empty","value":null},"waitTime":{"invalidateTime":1425245219,"updateTime":1425245220,"type":"empty","value":null}},"id":122},"128":{"name":"Battery","data":{"invalidateTime":1425232586,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425232586,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425232586,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232587,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9},"lastChange":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"int","value":1425232587},"history":{"invalidateTime":1425232586,"updateTime":1425232587,"type":"empty","value":null,"100":{"invalidateTime":1425232586,"updateTime":1425361238,"type":"int","value":1425361238}},"last":{"invalidateTime":1425232586,"updateTime":1425361238,"type":"int","value":100}},"id":128},"132":{"name":"Wakeup","data":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"empty","value":null,"supported":{"invalidateTime":1425234284,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425234284,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425234284,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425234283,"type":"int","value":8},"interval":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"int","value":1800},"nodeId":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"int","value":1},"min":{"invalidateTime":1425234284,"updateTime":1425234282,"type":"int","value":1800},"max":{"invalidateTime":1425234284,"updateTime":1425234282,"type":"int","value":432000},"default":{"invalidateTime":1425234284,"updateTime":1425234282,"type":"int","value":86400},"step":{"invalidateTime":1425234284,"updateTime":1425234282,"type":"int","value":1800},"lastWakeup":{"invalidateTime":1425234284,"updateTime":1425364810,"type":"int","value":1425364810},"lastSleep":{"invalidateTime":1425234284,"updateTime":1425364810,"type":"int","value":1425364810}},"id":132},"133":{"name":"Association","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425234284,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425234283,"type":"int","value":8},"groups":{"invalidateTime":1425234282,"updateTime":1425234283,"type":"int","value":2},"specificGroup":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null},"1":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"empty","value":null,"max":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"int","value":8},"nodes":{"invalidateTime":1425234284,"updateTime":1425234285,"type":"binary","value":[1]}},"2":{"invalidateTime":1425234283,"updateTime":1425234284,"type":"empty","value":null,"max":{"invalidateTime":1425234283,"updateTime":1425234284,"type":"int","value":8},"nodes":{"invalidateTime":1425234283,"updateTime":1425234284,"type":"binary","value":[1]}}},"id":133},"134":{"name":"Version","data":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":2},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425216691,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425216691,"type":"int","value":9},"ZWLib":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":3},"ZWProtocolMajor":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":3},"ZWProtocolMinor":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":95},"SDK":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"string","value":"6.51.02"},"applicationMajor":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"applicationMinor":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":17},"hardwareVersion":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"firmwareCount":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"firmware1":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"empty","value":null,"major":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"minor":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":15}}},"id":134},"143":{"name":"MultiCmd","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425232586,"type":"int","value":9}},"id":143},"152":{"name":"Security","data":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"empty","value":null,"supported":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"version":{"invalidateTime":1425216690,"updateTime":1425216691,"type":"int","value":1},"security":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewDone":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"int","value":9},"scheme":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"int","value":0},"secureNodeInfoFrame":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"binary","value":[128,113,133,112,48,49,132,239]},"securityAbandoned":{"invalidateTime":1425216689,"updateTime":1425216690,"type":"bool","value":false},"toFollow":{"invalidateTime":1425245219,"updateTime":1425364810,"type":"bool","value":false}},"id":152}},"data":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"empty","value":null,"dynamic":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"bool","value":false},"genericType":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"int","value":7},"specificType":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"int","value":1}},"id":0}},"data":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"empty","value":null,"basicType":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"int","value":4},"genericType":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"int","value":7},"specificType":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"int","value":1},"infoProtocolSpecific":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"int","value":5479425},"deviceTypeString":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"string","value":null},"isVirtual":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"bool","value":false},"isListening":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"bool","value":false},"isRouting":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"bool","value":true},"isAwake":{"invalidateTime":1423915135,"updateTime":1425364810,"type":"bool","value":true},"optional":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"bool","value":true},"isFailed":{"invalidateTime":1423915135,"updateTime":1425245220,"type":"bool","value":false},"beam":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"bool","value":false},"sensor250":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"bool","value":false},"sensor1000":{"invalidateTime":1423915135,"updateTime":1425245221,"type":"bool","value":false},"neighbours":{"invalidateTime":1424097862,"updateTime":1425245221,"type":"binary","value":[1,2,3]},"manufacturerId":{"invalidateTime":1423915135,"updateTime":1425216692,"type":"int","value":316},"vendorString":{"invalidateTime":1423915135,"updateTime":1425216692,"type":"string","value":null},"manufacturerProductType":{"invalidateTime":1423915135,"updateTime":1425216692,"type":"int","value":2},"manufacturerProductId":{"invalidateTime":1423915135,"updateTime":1425216692,"type":"int","value":12},"ZWLib":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"int","value":3},"ZWProtocolMajor":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"int","value":3},"ZWProtocolMinor":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"int","value":95},"SDK":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"string","value":"6.51.02"},"applicationMajor":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"int","value":1},"applicationMinor":{"invalidateTime":1423915135,"updateTime":1425216691,"type":"int","value":17},"nodeInfoFrame":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"binary","value":[94,128,113,133,112,114,134,48,49,132,89,115,90,143,152,122,239,32]},"ZDDXMLFile":{"invalidateTime":1423915135,"updateTime":1425218285,"type":"string","value":"585-013c-0002-0002-06-03-5c-01-00.xml"},"lastSend":{"invalidateTime":1425245217,"updateTime":1425364810,"type":"int","value":11655633},"lastNonceGet":{"invalidateTime":1425245217,"updateTime":1425364810,"type":"empty","value":null},"lastReceived":{"invalidateTime":1423915135,"updateTime":1425364810,"type":"int","value":0},"failureCount":{"invalidateTime":1425245217,"updateTime":1425245218,"type":"int","value":0},"keepAwake":{"invalidateTime":1423915135,"updateTime":1425245219,"type":"bool","value":false},"countSuccess":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"int","value":0},"countFailed":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"int","value":0},"queueLength":{"invalidateTime":1423915135,"updateTime":1423915136,"type":"int","value":0},"givenName":{"invalidateTime":1423915135,"updateTime":1423941962,"type":"string","value":"4in1 Sensor Schlafzimmer"},"secureChannelEstablished":{"invalidateTime":1423915135,"updateTime":1423915138,"type":"bool","value":true}},"id":7}
moderator changed quote tag to code to make post display shorter
pofs
Post by pofs »
Wow!
It seems your device supports ZWave+ (and is required to have only one association group "LifeLine"), but it actually has TWO. And for the second one it doesn't report group name (but successfully reports the other things, like supported commands), so AGI interview never finishes.
I'm currently not sure what z-way-server should actually do in this case. It is clearly a device misbehavior, but it shouldn't affect normal operation.
opperman
Post by opperman »
Thanks for your answer.
I have seen the information about ZWave+, but my problem is that in my network it doesn't send the triggered events like motion or door contact to the ZWave server. My old Philio device, and other Vision devices, work perfectly, but with the new ZWave+ devices I don't get this information via LifeLine to my ZWave server.
Is there any solution to solve it? Can I downgrade to a firmware without Wave+? Where can I download firmware for my device?
