Fibaro Flood Sensor
enco.josh
Fibaro Flood Sensor
Post by enco.josh »
At times, my Fibaro flood sensors are reporting the temperature to be in the 1000C or above. I never seemed to have this problem in v1.72, but in v2.0.1-rc23 the problem is much more common. Anyone else seeing these issues?
pz1
Re: Fibaro Flood Sensor
Post by pz1 »
I do observe the same with Fibaro Universal sensors. Don't know if yours has the same sensor, but I would not be surprised if it had.
For me it occurs very irregularly. I can't say id it was better with earlier version because I did not log the dat at that time.
enco.josh
Post by enco.josh »
[2015-08-06 12:51:20.886] RECEIVED: ( 01 12 00 04 00 08 0C 60 0D 02 02 31 05 01 44 00 00 A8 E3 BA )
[2015-08-06 12:51:20.887] SENT ACK
[2015-08-06 12:51:20.888] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2015-08-06 12:51:20.888] SETDATA devices.8.instances.2.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2015-08-06 12:51:20.889] SETDATA devices.8.instances.2.commandClasses.49.data.1.scale = 0 (0x00000000)
[2015-08-06 12:51:20.890] SETDATA devices.8.instances.2.commandClasses.49.data.1.val = 432.350006
[2015-08-06 12:51:20.893] SETDATA devices.8.instances.2.commandClasses.49.data.1.scaleString = "°C"
[2015-08-06 12:51:20.894] SETDATA devices.8.instances.2.commandClasses.49.data.1 = Empty
I don't know the protocol, but did the device send 432.35 or was it misinterpreted?
enco.josh
Post by enco.josh »
Bump
Looks like CRC error. Know problem of 3rd gen devices
