I have a Raspberry Pi with Razberry. I recently bought a Fibaro FGK sensor ( http://www.domotique-store.fr/domotique ... results=22 ).
Now, on the new "smarthome" UI, I would like to trigger a HTTP curl when the door is opened / closed.
If door opened/closed
Then curl http://192.168.1.2/door?open
I can't find where I can do this in the new smarthome UI. I can watch my door sensor, but I can't find a "module" wich curl an url.
Can you help me ?
Regards,
Notification on door (Fibaro FGK sensor)
Re: Notification on door (Fibaro FGK sensor)
Please use HTTP module to query HTTP requests on ON/OFF actions. Then use Bind devices to bind this door sensor with the HTTP device
