Thank you, no it works as expected.
Is there a website where the current RCs and nighly builds are listed?
Mirko
Light Scene Regression Bug - Dimmer Level
RottenMutt
Re: Light Scene Regression Bug - Dimmer Level
Smarthome now accepts "zero" in scenes and shuts off the dimmer switch when the scene is activated. thank you all for fixing this one issue...nybble wrote:Using the example above will give you the RC 1 update but not the one that fixes the issue. Use the string below in the same manner:
v2.0.2-rc1-12-g8364373
