Support POPP Smoke Sensor POPE004001
The new POPP Smoke detector has no device description. Using the device library (http://www.pepper1.net/zwavedb/) I found a device description xml file. How can I include it in my zwave installation so it is avalable?
Re: Support POPP Smoke Sensor POPE004001
ref: Q&A
You can update the device description with command UpdateXMLs.sh that you can find in the ZDDX folder
You'll get quite a few error messages from corrupted xml files. Unfortunately these haven't been cleaned up yet
cd /opt/z-way-server/ZDDX
./UpdateXMLs.sh
succeeded, thankspz1 wrote:You can update the device description with command UpdateXMLs.sh that you can find in the ZDDX folder
You'll get quite a few error messages from corrupted xml files. Unfortunately these haven't been cleaned up yetCode: Select all
cd /opt/z-way-server/ZDDX ./UpdateXMLs.sh
Update: Found the device in the list after this action
is there a similar proceeding for the Smart Home Stick for WD NAS? There is no description available, though listed on pepper. (device 725).
Raimund
Raimund
does anyone know how to run command on WD-NAS? I could active SSH but cannot find a way to proceed.
Raimund
Raimund
Same, but folder is different: /mnt/HD/HD_a2/Nas_Prog/Z-Way-Server/bin/
