i had some problems with Z-Way-Server v2.0. I have several razberrys in the field, and almost simultanously they all stopped working.
In the process of debugging i realized that the z-wave binding module did not load. It was completely deleted and i had to manually re-add it. (IP:8083 -> "Z-Way Home Automation UI" -> Preferences -> Modules -> Peripherals -> ZWave and then enter dev/ttyAMA0)
Is there a way to do this remotely? Where is the information of the modules stored? If it is just some file i can add a routine to crontab, that checks the file regularly and if not present copies a backup to get it working again.
Somehow Z-Way seems to delete configuration files by random, i had some issues with lost interview results, where no soultion was found yet.
Thanks in advance!
Z-Wave binding automation module lost - storage location?
Re: Z-Wave binding automation module lost - storage location
Should be possible to setup remote access with RaZberry Configuration Interfacedschonac wrote:Is there a way to do this remotely?
http://raspberrypi_IP:8084/cgi-bin/main.cgi
I've never done that myself though
