My Fibaro Motion Sensor FGMS-001 is not correctly recognized.
The picture is not shown.
No configuration is available.
Any idea?
Fibaro Motion Sensor FGMS-001 not regonized correctly
Re: Fibaro Motion Sensor FGMS-001 not regonized correctly
Same problem here, I tested with Version 2.1.1 and 2.0.1
The device seems to be unknown and you cannot manually select a device configuration.
The sensors work so far, but no product image and no configuration visible.
Try to update your local device description as done in this post: viewtopic.php?f=3422&t=21884&p=57522&hi ... MLs#p57517praes wrote:Same problem here, I tested with Version 2.1.1 and 2.0.1
The do appear some errors. You can ignore those.
ZWay v2.1.1 does have a record for FGMS-001 that you can select manually if not automatically selected
ok maybe i confused a bit, the sensor is available in the device selection list but after selecting the device this setting is not applied and the device is shown again as unknown device, i mean you can select the sensor in the dropdownlist but it changes nothing...
Hi, I'm getting the same error. This happened after upgrading to 2.0.1.
None of my Fibaro Motion sensors are showing any configuration.
They do work, but as said earlier, I cannot change the device description and I cannot change any configuration.
