- I see the automation/modules/HomeKitGate/index.js, and can understand what's going on there. But I also see modules/modhomekit.so, which is an ELF library, and clearly didn't come from any JavaScript...what is the relationship between these two, and does modhomekit.so do anything at all? Is it a plugin for z-way or the HTTP server you're using? Is the source code for this available? Do I need it?
- If I edit the HomeKitGate/index.js file, what should I do to have the changes loaded? Will z-way server notice the change, or do I need to restart it or do something else?
What I'd like to add is thermostat support and improved temperature sensor support, and possibly look into RGB support.
