Zway automation disabled and error on log
diapolon
Post by diapolon »
Hi at all,
i don't use zway automation and i have disabled it because i use only JSON API.
Why on zway-server.log i have many this error?
[2015-11-25 15:14:56.063] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2015-11-25 15:14:56.082] [I] [core] Notification: error (core): Failed to load module because dependency was not instanciated: [DEP]::[MODUL] = Cron :: SensorsPollingLogging
[2015-11-25 15:14:57.559] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2015-11-25 15:14:57.561] [I] [core] Notification: error (core): Failed to load module because dependency was not instanciated: [DEP]::[MODUL] = Cron :: BatteryPolling
[2015-11-25 15:14:56.350] [I] [core] Notification: error (core): Failed to load module because dependency was not instanciated: [DEP]::[MODUL] = Cron :: DeviceHistory
Re: Zway automation disabled and error on log
You disable Cron module. Remove others too from the list of active apps.
diapolon
Post by diapolon »
Hi Poltos, on active apps i have only Z-Wave Network Access!
Just ignore these messages, they dont harm you
