Device not in namespace
I hooked up a doorbell to a fibaro binary sensor. The interview does not complete, but it is working nonetheless. I want to use this device in my telegram bot, so I want it to be selectable in the sensorBinary namespace, but it is not. When I look at the device data it says: "deviceType":"sensorBinary". However when I look at the namespaces collection in the api this device is only present under the devices_all namespace, not under devices_sensorBinary. Is this because the interview does not complete? If so, is there a way to finish the interview on these universal sensors?
Re: Device not in namespace
Which part does not complete for you? The Alarms as here for my device (click or scroll)?
- Capture.PNG (16.27 KiB) Viewed 12577 times
Yup both alarms failed, can't get them forced either..
I have reported that in this post viewtopic.php?f=3422&t=20513&p=54473&hi ... sor#p54473
Do you happen to have the same device (see Under ExpertUI in configuration Expert Commands ManufacturerSpecific.
productId :4098, productType 1281 ?
I am asking this because Fibaro helpdesk denies the existance of this version.
- Capture.PNG (9.55 KiB) Viewed 12564 times
It's not a specific Fibaro device version, all my fibaro devices (door and motion sensors) are only in the devices_all namespace. When I build a module where people can select a binary sensor, these devices do not show up. I tested some other user modules, none of them have my fibaro sensors in their options because of this issue.
I tried to make a dropdown with the devices_all namespace as option list, but this gives some nasty side effects since the device id's don't seem match up. As a workaround I just offer an array of strings where users can enter literal device id's, this seems to be the only way to select fibaro sensors.. If anyone has a better workaround I'm very interested. I'd also like to know if this situation is going to be fixed since fibaro sensors are very commonly used..
There was some mess with namespaces in 2.2.0. We will fix it soon
