Error: Too many bindings to one dataholder
mkruse
Re: Error: Too many bindings to one dataholder
Post by mkruse »
Hi, after some days I have the same issue. But these errors are with Fibaro FGSD-002. It's started on a smoke detector and then I have it on all devices.
15:30 | vDev konnte mit den folgenden Daten nicht erstellt werden: 24-0-113: Error: Too many bindings to one dataholder
core 15:30 | vDev konnte mit den folgenden Daten nicht erstellt werden: 24-0-113: Error: Too many bindings to one dataholder
Raptor2k1
Post by Raptor2k1 »
Hi!
I have the same error with a Aeotec Multisensor6. But not always! I thought that the interval (in witch the device is sending data) is associated with the problem. But after plug the device off and back on (with same interval), i got no more error messages :? Some hours after i got the errors again and since yesterday there was no more error in z-way log :?
Z-Way 2.1.2 > Windows 7 Prof. x64
Greets
Chris
This problem means too many bindings are made to the same data holder. What are you doing specifically?
Raptor2k1
Post by Raptor2k1 »
The last time i had these errors > all vars of "aeontec multisensor 6" would be updated - but not 9.0.7.8 (tamper protection). Each time i forced this alarm i got "too many bindings to one dataholder".
But the next days, with NO config changes - the Errors are gone :? I´m actually only testing some things with Z-Way and my other smarthome system, so i often include/exclude/Service restart/...
Maybe it happens, when the time-interval between the alarms is to short?! Or the report-send-interval is to short?! Or when z-way service comes up and in the first seconds to many events came in? The "Aeontec Multisensor 6" sends 3 types of alarms, sometimes in the same microsecond > 0.7 // 0.7.3 // 0.7.8 This could case the errors too?!
Greets
Chris
coolbloke1324
Post by coolbloke1324 »
PoltoS wrote:This problem means too many bindings are made to the same data holder. What are you doing specifically?
I have an If... Then... on the sensor so if there is movement it turns on a light.
This is the only thing I have reacting to that sensor. Many others here are experiencing the same issue. I think this is much more likely to be a bug in the code than anything a user has done.
Is your code open-source? I suspect many of us are programmers and would be happy to help track down the issue.
This error message occurs only if one dataholder is binded more than 500 times (not sure about exact number, but > 100 for sure). These bindings are done in JavaScript code (it is open). I suppose some bug in JS is producing more bindings than needed. That's why I ask for specific user experience - not everyone have this. Once we get more data we can understand where to look on.
S.Kluth
Post by S.Kluth »
Today I got the first time errors like
vDev konnte mit den folgenden Daten nicht erstellt werden: 3-0-113: Error: Too many bindings to one dataholder
There are only 3 devices in my network:
Thermostat StellaZ
Thermostat Danfoss Living Connect Z
aeon labs multisensor 6
at 7:45 this morning there was also a "little bit" cold temperature reported from StellaZ
device-temperature 07:45 | Thermostat StellaZ 1 ist -620.5 °C
core 	08:35 | vDev konnte mit den folgenden Daten nicht erstellt werden: 3-0-113: Error: Too many bindings to one dataholder
device-OnOff 	08:35 | (3.0.0) Button ist on
device-temperature 	08:33 | Thermostat StellaZ 1 ist 20 °C
device-temperature 	08:20 | Aeon Labs Temperature (3.0.49.1) ist 22 °C
device-temperature 	07:51 | Thermostat StellaZ 1 ist 19.5 °C
device-humidity 	07:46 | Aeon Labs Humidity (3.0.49.5) ist 35 %
device-temperature 	07:46 | Aeon Labs Temperature (3.0.49.1) ist 22.1 °C
device-temperature 	07:40 | Aeon Labs Temperature (3.0.49.1) ist 22.2 °C
core 	07:35 | vDev konnte mit den folgenden Daten nicht erstellt werden: 3-0-113: Error: Too many bindings to one dataholder
device-OnOff 	07:35 | Aeon Labs Burglar 2 Alarm (3.0.113.7.8) ist off
device-OnOff 	07:35 | (3.0.0) Button ist off
device-temperature 	07:33 | Thermostat StellaZ 1 ist 19.5 °C
I attach a log file witch shows the system start after cleaning the previous log, as stated in qour faq.
z-way-server.log.bak2.gz
clean log
(42.12 KiB) Downloaded 923 times
The original log ist to large to upload here, even if compressed. So I cuted just a part of it that you'l find in the 2nd attachement.
z-way-server.log-cuted.gz
Long log cut
(13.94 KiB) Downloaded 858 times
I'll detach the aeon labs multisensor 6 now and may provide further log information if you'll ask for it.
Sparkacus
Post by Sparkacus »
I'm getting this issue non-stop now.
All my Aeon sensor does at that moment is update z-way with temp, lux, humidity etc, it doesn't action anything based on specific results.
2016-01-13 08:30:53.330] [I] [core] Notification: error (core): Cannot create vDev based on: 14-0-113: Error: Too many bindings to one dataholder
[2016-01-13 08:30:53.349] [I] [core] Error: Too many bindings to one dataholder
    at Error (native)
    at ZWave.dataBind (automation/modules/ZWave/index.js:1081:18)
    at automation/modules/ZWave/index.js:2217:12
    at Array.forEach (native)
    at ZWave.parseAddCommandClass (automation/modules/ZWave/index.js:2120:25)
    at ZDataHolder.<anonymous> (automation/modules/ZWave/index.js:2297:12)
[2016-01-13 08:30:53.607] [I] [core] Notification: error (core): Cannot create vDev based on: 14-0-113: Error: Too many bindings to one dataholder
[2016-01-13 08:30:53.621] [I] [core] Error: Too many bindings to one dataholder
    at Error (native)
[2016-01-13 08:30:53.634] [I] [core] Notification: error (core): Cannot create vDev based on: 14-0-113: Error: Too many bindings to one dataholder
[2016-01-13 08:30:53.647] [I] [core] Error: Too many bindings to one dataholder
    at Error (native)
[2016-01-13 08:30:53.660] [I] [core] Notification: error (core): Cannot create vDev based on: 14-0-113: Error: Too many bindings to one dataholder
[2016-01-13 08:30:53.673] [I] [core] Error: Too many bindings to one dataholder
    at Error (native)
[2016-01-13 08:30:53.732] [I] [core] Notification: device-info (device-OnOff): {"dev":"Aeon Labs Motion (14.0.113.7.8) Alarm","l":"off"}
[2016-01-13 08:30:53.766] [I] [core] Notification: error (core): Cannot create vDev based on: 14-0-113: Error: Too many bindings to one dataholder
[2016-01-13 08:30:53.779] [I] [core] Error: Too many bindings to one dataholder
    at Error (native)
[2016-01-13 08:31:06.808] [D] [zway] Job 0x13: deleted from queue
Screenshot 2016-01-13 10.30.29.png (208.41 KiB) Viewed 20704 times
ridewithstyle
Post by ridewithstyle »
Hi there,
I have the same error with v2.2.1 RC3 and a Devolo Thermostat. :-(
Regards, rws
mrnmukkas
Post by mrnmukkas »
I also have this problem with v2.2.1-rc3. I have three Fibaro Dimmer 2 (FGD-212) and they all create a bunch of these warnings. I've been able to alleviate it for a few hours by restarting the server.
I thought I had fixed it yesterday by changing the Device Description in Expert UI, but after a few hours it came back again.
I've noticed that the number of errors match the number of alarms (or every x-0-113-... id) on the device, ten in my case:
  • Alarm Heat 10-0-113-4-2 Fibar Group
  • Alarm Power Management 10-0-113-8-4 Fibar Group
  • Alarm Power Management 10-0-113-8-5 Fibar Group
  • Alarm Power Management 10-0-113-8-6 Fibar Group
  • Alarm Power Management 10-0-113-8-8 Fibar Group
  • Alarm Power Management 10-0-113-8-9 Fibar Group
  • Alarm System 10-0-113-9-1 Fibar Group
  • Fibar Group Heat Alarm (10.0.113.4.254)
  • Fibar Group Power Management Alarm (10.0.113.8.254)
  • Fibar Group System Alarm (10.0.113.9.254)
I know that the FGD-212 have some issues, but this is new in 2.2.1-rc3.
