Dear all,
I hope this is the right forum to find a solution for my newbie issue.. If not, I would highly appreciate directions.
I have recently started with z-wave and bought: a raspberry pi, razberry board and a z-wave.me flush dimmer. I installed Domoticz and included the dimmer. It was recognised properly, but does not respond to switch on and off commands nor dimming commands. The log shows an openzwave unhandled class error and many timeouts.. Do you have any clue what is going wrong? Please find the log below.
Thank you in advance,
Jasper
2016-01-14 18:47:55.570 OpenZWave: using config in: /home/pi/domoticz/Config/
2016-01-14 18:47:56.235 OpenZWave: Driver Ready
2016-01-14 18:47:56.235 OpenZWave: New Node added. HomeID: 3855452629, NodeID: 1 (0x01)
2016-01-14 18:47:56.237 OpenZWave: New Node added. HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-14 18:47:56.331 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-01-14 18:47:56.332 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-01-14 18:47:56.332 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2016-01-14 18:47:56.388 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: INDICATOR, Label: Indicator, Instance: 1
2016-01-14 18:47:56.388 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 2 (0x02), Index: 0, Instance: 1
2016-01-14 18:47:57.435 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:52:13.865 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:52:14.365 Sunrise: 08:38:00 SunSet:16:56:00
2016-01-15 10:52:14.365 EventSystem: reset all events...
2016-01-15 10:52:14.879 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:52:15.881 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:52:23.902 OpenZWave: All Nodes queried
2016-01-15 10:52:25.368 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:52:57.992 Incoming connection from: 192.168.1.28
2016-01-15 10:53:26.377 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:53:47.764 User: Admin initiated a switch command
2016-01-15 10:53:47.765 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 2 (0x02)
2016-01-15 10:53:47.766 (RaZberry) Lighting 2 (Dimmer1)
2016-01-15 10:53:48.767 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:53:49.769 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
2016-01-15 10:53:55.645 User: Admin initiated a switch command
2016-01-15 10:53:55.645 OpenZWave: Domoticz has send a Switch command!, Level: 71, NodeID: 2 (0x02)
2016-01-15 10:53:55.647 (RaZberry) Lighting 2 (Dimmer1)
2016-01-15 10:53:56.648 OpenZWave: Received timeout notification from HomeID: 3855452629, NodeID: 2 (0x02)
