Hello everybody.
I need your help as i am new to z-wave. I will move into a flat which has a lot of the type of switches which you can see on the picture below. I want to replace them with z-wave switches.
- left row of switches is for light. Each rocker can switch and dimm
- right row of witches is somfy motor roller shutters. I think they are very old, as I cannot find pictures and information.
Can you recommend me z-wave products to replace them without loosing functionality?
many thanks in advance for your advice
alexx
Which z-wave switches do I need as replacement?
- switches to be replaced
- Screenshot .png (365.55 KiB) Viewed 9571 times
Re: Which z-wave switches do I need as replacement?
You haven't said what country you're in. The availability of Z-Wave devices varies by country.
I live in Germany: 868 MHz - 220V
