Upgrdae firmware of RaZberry using Domoticz
Muckydevil
Post by Muckydevil »
I'm using Domoticz with Razberry on a serial port. Domoticz is reporting the firmware as Version: 1.3-523-gb258e9e. Is there a command line too I can use to update this firmware?
Muckydevil
Re: Upgrdae firmware of RaZberry using Domoticz
Thanks for the reply. The link below indicates that you need to install this software with its own web server? Is that the only way as I was try to avoid installing anything else except Domoticz?
pz1
Post by pz1 »
I don't know, this is not a Domoticz forum. You better ask there, probably more knowledgeable people on that topic
Muckydevil
Hi Pz1,
ok thanks was hoping there was a command line tool etc.. but worse case I guess I could flash another SD card run the upgrade from there then swap cards over :-)
pz1
Post by pz1 »
Muckydevil wrote:Hi Pz1,
Well that is the fun of using Raspberry: Swapping cards! If necessary, you just fire-up a Zway installation to use its maintenance tools for your Zwave devices :)
