Webif is switch off
Re: Webif is switch off
then if root has no write permissions just chmod it.
bogr,
I tried the code you sent... and receivde "No such file or directory" - see below...
pi@raspberrypi:~ $ ls -l /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
ls: cannot access /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json: No such file or directory
pi@raspberrypi:~ $
pi@raspberrypi:~ $
aah, the file does of course not exist, try
to see the permissions on the dir.
ls -la /opt/z-way-server/automation/storage
I have the same problem with my upgrade to 2.2.1. Upgrade halted. Installed 2.2.0 but same problem.
How do I switch webif on ?
bogr,
Please see below for list of permissions... thanks for your help
pi@raspberrypi:~ $ ls -la /opt/z-way-server/automation/storage
total 28
drwxr-xr-x 2 root root 4096 Mar 31 00:58 .
drwxrwxr-x 11 pi pi 4096 Mar 25 23:24 ..
-rw-r--r-- 1 root root 11341 Mar 31 00:58 configjson-06b2d3b23dce96e1619d2b53d6c947ec.json
-rw-r--r-- 1 root root 0 Mar 25 23:24 .keep
-rw-r--r-- 1 root root 1534 Mar 31 00:58 notifications-f37bd2f66651e7d46f6d38440f2bc5dd.json
-rw-r--r-- 1 root root 31 Mar 25 23:24 storageContent-0c40aa7c27d2121efdfa27fff03c9548.json
++++++++++++++++++++++++++++++++++++bogr wrote:aah, the file does of course not exist, try
to see the permissions on the dir.Code: Select all
total 28
ok, apparently it was not about the permissions, sorry about that. The problem is the redirection, so run it in a separate shell and it should work, like:
sudo sh -c "echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json"
bogr.... Thank you.... it worked.
Tested:
but still get "Webif is switched off. You can swithch it on from Z-Way UI of box shell" at "http://my_ip:8084/cgi-bin/main.cgi".
What else do I need to do to switch it on ?
Manged to do reinstall through "wget -q -O - http://razberry.z-wave.me/intall | sudo bash", and upgrade sucessfylly to 2.2.1. But all my previously installed devices does not show up in the expert UI.
The smarthome UI does not start at all, responding with "SmartHome UI - ERROR" and "error_load_data".
Seems I need to force a fresh installation. How do I do this ?
bogr... I'm getting the following when I try to connect... do you know what is going on?
<!doctype html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta http-equiv="refresh" content="1;url=smarthome">
<script type="text/javascript">
window.location.href = "smarthome"
</script>
<title>Page Redirection to Z-Wave Smart Home</title>
</head>
<body>
</body>
</html>
<!doctype html>
<html lang="en">
<head>
</script>
</head>
<body>
</body>
</html>
