I'm testing the stability of a Z-wave network using the Z-way stick and multiple Aeotec Multisensor 6 devices.
For the purpose of this test, the devices are all USB powered.
I'm experiencing non consistent reports from the Expert UI.
I've made a following network topology:
C - controller
M - USB powered Multisensor
C1 - M4
M3
However, the routing table seems incorrect:
Given the routing page from above the sensors wouldn't be able to communicate with the controller however, they are.
Note:
The routing tables can't be successfully updated for the devices. My hypotheses for the above question is that if the node can confirm it's alive, all communication should be successful. Feel free to challenge/question this assumption if it could explain the above behaviour.
