v 2.2.2 and OpenRemote
mcfanda
Post by mcfanda »
Hi
I have Z-way and OpenRemote coexisting since more than 3 years. OR connects with Z-way-server via http protocol. After updating z-way to 2.2.2 version, OR cannot connect via http any more. Z-way log says
Can not make request: Not Found
any help?
mcfanda
Re: v 2.2.2 and OpenRemote
Post by mcfanda »
I should add that calling the Zway API with the browser works just fine
pz1
Post by pz1 »
There is a problem with HTTP authentication
A work around is to create a user anonymous Assign all rooms to this user.
(I have made one room Devices, and assigned all devices to that room)
mcfanda
Post by mcfanda »
I did this, it is not the problem. In fact, I can send request to z-way-server from curls or browser without username and password. The problem is that 2.2.2 does not understand encoded urls. I downgraded to 2.1.1, same set up, and works just fine. Is there a workaround for 2.2.2 to understand encoded ulrs?
pz1
Post by pz1 »
What is the command you send? How do you encode?
mcfanda
Post by mcfanda »
Hi (thanks for the replies).
I'm sending (for instance):
And I get a "Internal Server Error" in OR. Then I sniff tcp traffic going from OpenRemote (OR) to z-way-server and I see the same command sent as:
Thus the request is encoded by OR, and I cannot change it. Please note that by downgrading Z-Way to 2.1.1 everything works, meaning that the encoded request is well accepted by 2.1.1 but not by 2.2.2. Am I correct?
pz1
Post by pz1 »
Did you enable Zwave API in the Zwave App?
Not desirable from a security point of view, but I learned to live with it
pz1
Post by pz1 »
mcfanda wrote:Hi (thanks for the replies).
http://10.0.0.3:8083/ZWaveAPI/Run/devic ... evel.value
I do not have this switchMultiLevel, so I can't try unfortunately
What brand and type of switchMultiLevel do you have?
mcfanda
Post by mcfanda »
I'm afraid id does not matter. I have fibaro dimmers but they work fine with Z-Way server. The problem I mentioned above occurs for any kind of command that Openremote sends to Z-way-server. It does that for all http requests, no matter the z-wave hardware one uses (I have dozen of them of different brands).
I've done different tests, the problem is on the encoding-decoding of the urls between Openremote and z-way-server. I'm afraid I should wait and hope a newer version of z-way-server will work with OpenRemote.
But really thanks for the help
silverhack
Post by silverhack »
mcfanda wrote: I'm sending (for instance):
Are you able to do this HTTP request in your web browser on your computer? You should be able to login at http://10.0.0.3:8083/ and then after logging in, you can copy/paste the API command and it should work. If it works on your browser, but not in OR, then my guess is that OR is either not logging in correctly, or there is an issue with the encoding of the URL in OR. But I would test it with your browser first.
