[Moderator remark] Similar complaints here
i have update to the new 2.2.2 webserver version.
Now i have a new device fibaro double relais. Connecting was ok.
But when i configure this device and want to select the device description i always got the same error.
See attachment...
Can you help me?
Erro selecting device
- FIbaro error message
- fibaro.JPG (16.81 KiB) Viewed 11510 times
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
Fibaro Multi Sensor
Re: Erro selecting device
There are several serious problems with the v2.2.2 releases.
v2.2.1 is not ideal for everybody but works fine for me
Maybe we should merge this thread with the one in https://forum.z-wave.me/viewtopic.php?f ... ror#p62373?
Seems to have the same issue.
Thanks for the notification. Sensible suggestion, but because posts were made in different fora (RaZberry and Discussions in English) I fear some users may get confused. So I decided not to merge. I'll make a cross linkCrazyFin wrote:Maybe we should merge this thread with the one in https://forum.z-wave.me/viewtopic.php?f ... ror#p62373?
i'am back to the old 2.2.2 without new webserver and the problem with the device ist gone.
I think it is a bug in the new 2.2.2 version.
Fibaro Multi Sensor
Fibaro Multi Sensor
The bug has been reported as Github issue #190kandalf wrote:I think it is a bug in the new 2.2.2 version.
