Hi folks,
somebody use netatmo weather with ZWay 2.2.0? Is this possible?
If it is possible, can i take e.g. temperature for thermostat regulation?
ZWay 2.2.0 with Netatmo?!
Re: ZWay 2.2.0 with Netatmo?!
Hi!
I've written a module to work with NetAtmo, but it's not finished yet, so not submitted to official repo.
You can try it on your own risk, without any warranties.
It will generate Multilevel Sensors for each of your NetAtmo available sensors.
To make it work, you need a special token from https://dev.netatmo.com/
There you need to create an app and grab a token from there.
Best Regards.
Best Regards.
- NetAtmo.zip
- No warranties at all
- (75.65 KiB) Downloaded 645 times
we fixed two issues in /opt/z-way-server/automation/userModules/NetAtmo/index.js (marked in the file with //fixed)
1)used variable self instead of this in callback of refreshToken()
2) For function refreshToken() we had to use the same app_id and app_secret as in authenticate() so we dropped the constant app_id/app_secret from the code and used the data inserted in z-wave UI. We generated following keys on the NetAtmo developer site.
app_id: 5606631e485a88a63592a39f
app_secret: KOSdQrSKoIXCIYrnZUJTf1wlhH52
It runs since three days stable.... enjoy
Hi!
I am trying to connect to netatmo v.2.2.2
silence.
Username / password that should be administered?
I work remotely, can this problem?
Пытаюсь подключить netatmo к v.2.2.2
тишина.
Логин/пароль что вводить надо?
Работаю удаленно, может в этом проблема?
silence.
тишина.
These are login and password to your netatmo account
Hello!PoltoS wrote:These are login and password to your netatmo account
i have a problem with neatmo module in z-way. I've added it and it's working but only for three hours then there messages like "Error updating device nord weather Pressure".
Unfirtunatelly I've no Netatmo to test it. Sure you have good connection to Netatmo server / Internet?
May be if you send us your credentials for Netatmo, I can have a look (change password before)
I've sent you info about netatmo account on email - support@z-wave.mePoltoS wrote:Unfirtunatelly I've no Netatmo to test it. Sure you have good connection to Netatmo server / Internet?
Netatmo app succesfully added sensors from Main module, External module, WindGauge and RainGauge but no additional indoor modules. Any idea for a workaround?
