I have defined a camera as device from the generic Webcam template. The camera is a IPC-100 AC by the way, it is a cheap camera from Medion available here in Germany. I have found the HTTP API commands and I can see the video stream incoming in the z-wave UI. However I can not control the PTZ position of the camera. I have added the correct URLs (I checked these manually). But the Z-Wave is logging me following error: ReferenceError: http is not defined
2016-07-11 12:31:49.258] [I] [core] Notification: error (module): Error during perform command execution: ReferenceError: http is not defined
[2016-07-11 12:31:49.268] [I] [core] ReferenceError: http is not defined
at vDev.controller.devices.create.handler (automation/modules/Camera/index.js:102:21)
at _.extend.performCommand (automation/classes/VirtualDevice.js:289:37)
at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:328:60)
at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:2387:52)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:258:41)
at automation/WebserverRequestRouter.js:32:35
at WebServer.document_root (automation/Webserver.js:29:11)Do you have any idea?
