v2.2.3 issue
timb
v2.2.3 issue
Post by timb »
Hi
I upgraded to v.2.2.3 a week ago.
Since then I have two issues:
1. Expert - I can no longer see Network->Timing Info - the webpage comes back with an error: "Error handling data from the server". I find this Timing Info page quite useful as I have a couple of devices that are quite far apart and it lets me see what the quality of their response is.
2. Pi CPU - is now permanently running at around 28%. This is not a problem in itself, just a marked changed from v2.2.2
Does anyone else see the same issues?
Tim
timb
Re: v2.2.3 issue
Post by timb »
So now I read that the Network->Timing issue is a known issue - OK
However, CPU high usage remains an issue and the UI/Expert interface is generally sluggish.
Anyone else?
Re: v2.2.3 issue
Please re-install Z-Way (same version) or just manyally disable readKey service. There was a bug in our script and you certainly don't need it.
timb
Re: v2.2.3 issue
Post by timb »
Thank you for the reply. Yes that sorted it.
enbemokel
Re: v2.2.3 issue
Post by enbemokel »
Hi Forum,
sorry to step in, but can you specify which problem was solved?
As I have the same problem with the Timing Info page. But i never saw it ;-(
cause i started a week ago.
All other pages are working.
Best regards
Nico
Re: v2.2.3 issue
That was about readKey.
For timing please try our 2.2.4-rc4 - this is a release candidate, but timing info is enabled back
enbemokel
Re: v2.2.3 issue
Post by enbemokel »
Hi Polto,
thanks for answer, but now I have a grey "Reorganisation" and "Timing Info" :-(
Reorganisation wasn´t useful as I think it doesn´t work, but the Timing Info is still interesting for me.
Any idea?
Nico
Also, i included a D-Link Siren, worked in 2.2.3. now i can see the device, but no voide while switching.......
Re: v2.2.3 issue
It was temporarily disabled. In next version it will come back. Soon
