Sketchupdate via FIRMWARE_UPDATE_MD class?
A.Harrenberg
Post by A.Harrenberg »
I did not found a description of the FIRMWARE_UPDATED_MD class, but I expect that this function will only update the core of the Z-UNO, like the ZWave-Network and application layer as well as the sketch bootloader but not the sketch itself.
Is this correct?
Is there or will there be a possibility to also update the sketch via the update class?
Thnx,
Andreas.
fhem.de - ZWave development support
Re: Sketchupdate via FIRMWARE_UPDATE_MD class?
Correct, currently only core part csn be updated. In october we plan to add this function to also alow update the sketch.
