Hello!
I have now been struggling with my Razberry for 10 hours. I cannot get it to work and I have tried all sorts of things.
So now I have replace the HW and still have the same problems. So I planned to take it step by step.
First I have severe problems getting into the :8084 page. After creation of a "timeout" file I get in. I set "allow remote access". I change the password and save.
I now reboot.
I follow the attached instructions and go to the find.z-wave.me page. I after a couple of tries I figure what I should use to login. I get new problems with the next page failing to load. I read somewhere that I should use FF instead of Raspbian browser. I download and use FF. Now I get to a login page on port :8083. It says "Welcome to Your Smart Home 88595". It asks for a "Login" and "Password". I try everything I got. Nothing works. What should I to login?
// Robert
PS. I am using the latest version of Raspbian and 2.2.1 of Razberry.
Not possible to login
Re: Not possible to login
Hello again!
Looks like I miss one step that I read about in another thread. It seems that we I click the link to my IP on the find.z-wave.me page I never get to a page that asks me to create an admin password. This should apparently happen.
Really strange. I have started from scratch five times with two different Razberries and two different PI's (2 & 3). Same result every time; I do not get the chance to create a admin password.
Any ideas?
// Robert
Any ideas?
// Robert
I started all over again:
- Loaded the latest version of Raspbian.
- Checked for latest updates and installed.
- Installed Firefox.
- Shutdown the PI.
- Installed Razbian HW.
- Started the PI and installed the Razberry SW (wget -q -O ......).
- Opened Firefox and went to localhost:8083. I did not get a question about changing the admin password. All logins failed. I final found information about a "local" user and was able to login. Now I set Name and change the password for this local user. I have no idea where I change the data for the admin user.
- The webpage now looks like attached, saying that there are no devices installed. Now I want to install them.
How do I install devices? All menus are empty.
// Robert
- Shutdown the PI.
// Robert
- desktop
- DSC_0070.JPG (76.87 KiB) Viewed 24774 times
Hello!
In the user documentation a list of user interfaces are mentioned and listed in a picture (see attached). I have never seen this page. How do I get to it? Not by using localhost:8083, Not in my case any way.
// Robert
// Robert
- UI in documentation
- UIdoc.JPG (24.95 KiB) Viewed 24773 times
Hello!
My start page when typing localhost:8083 looks like attached. Obviously not correct?
And, I can only login using user "local". With admin I get "User not found"
Any ideas on how to get this fixed?
// Robert
// Robert
- DSC_0071.JPG (92.32 KiB) Viewed 24773 times
Hello again!
Now I tried the Razberry image referred to on the Razberry home page as a last resort:
http://razberry.z-wave.me/z-way-server/razberry.img.zip.
Running the installation in my PI 3 ends up in just a colorful screen with nothing else than a square with different colors. Took the SD card at fired up my PI 2. Here I can see how it start up and I can see the booting log. So the image does not work on PI 3? Strange.
Anyway, on my Pi 2, the installation stops with a prompt.... I reboot and I end up with a prompt again. According to the instructions on the razberry web page I should after the installation open a web browser. I assume this is not from the prompt, or?
How do I get into the GUI?
I tried to change via raspi-config and I was told to install lightdm. I did and I got a GUI. But I could not login... Tried with pi/raspberry and it looks like the credentials are correct, but the GUI comes back and asks for user/password over and over again.
I cannot understand how you get your stuff working. For me it is completely impossible. Do you have some trick I have missed?
// Robert
// Robert
Hello Robert,
Unfortunately, I am a newbie too so my suggestions might not get you very far. I didn't have much luck with the image file either. What I used and got working on a raz 3 was the install with a working OS. If you can get back to that login page you have in your screen shot, I would try admin and click on forgot password at the bottom. I'm guessing you might have created an admin password and that's why it is messing you up. Also, A lot of web sites will lock your account if you have too many failed attempts.
As for logging in and not seeing anything as a user, after I got in (thanks to you!) I created a user login and tried it and it only shows a very limited options. I think once I add devices on the admin side I will see more as a user. I think your almost there. Good luck! And I hope what I wrote here can help you.
Best,
Jim W.
Best,
Jim W.
Hi Robert,
I have the exact same problems as you describe and have no idea why I can´t get it to work. I have been trying first with a Pi 3 and now switched to a Pi 2b with a new image without any change. Today at least I discovered how to get access to the expert UI localhost:8083/expert but there I get Error handling data from server so I´m not sure if I have a connection to the RaZberry.
I have the same issue on RPI3. I can't log into it.
Is there a way to find the login on the RPI ? or to reset login and password ?
Thank you
Thank you
Found the solution :
- go to /opt/z-way-server/automation/storage/configjson-xxxx
- search for the word login
Then I saw my password in uppercase instead of lowercase.
The login is admin
The login is admin
