Mark battery as failed serial message
acanadasSC
Post by acanadasSC »
I'm a developer and use RaZberry board with a Raspberry Pi 3 and I communicate directly through SerialAPI without any trouble.
I'd like to use the "Mark battery as failed" functionality but I've not been able to figure out what kind of serial message I should send to the board so it performs the desired action as it appears not to be a standard zwave controller function and only specific to RaZberry.
Could anyone provide the serial message to perform the action?
Thanks!
Adrián Cañadas
Re: Mark battery as failed serial message
You can sniff it. But better use Z-Way API to call it.
