[closed] 2.0.5 and 2.0.6. CRC doesn't match
ronaldsnoeck
Post by ronaldsnoeck »
I am using Windows 10.
I have installed Arduino IDE 1.6.5 as described.
When I install Z-Uno 2.0.5 or 2.0.6 then the error "CRC doesn't match..." occurs.
Is there a sollution?
michap
Contact:
Re: 2.0.5 and 2.0.6. CRC doesn't match
Post by michap »
What is your current (installed) version - and what Update URL you are using?
Michael
A.Harrenberg
Post by A.Harrenberg »
I had the same issue... I just de-installed Arduino and made a new, clean installation (with the update-URL http://z-uno.z-wave.me/files/z-uno/pack ... index.json URL as described here). Then I was able to install 2.0.6 without that error. It seems that as soon as you try to switch between 2.0.5 and 2.0.6 there is miscalculation of the CRC...
Regards,
Andreas.
fhem.de - ZWave development support
ronaldsnoeck
I switched off the virus scanner.
I un installed all and even deleted all data in "C:\Users\Ronald\AppData\".
I followed http://z-uno.z-wave.me/install
Still no success.
I have another error see att
Regards,
Ronald
A.Harrenberg
that is strange, in the current error message the path contains "//" which is probably the cause of the error, but I have no idea wheres this would come from...
I can try it on my laptop to verify that it still works on my end, but I can't do it before tommorrow evening.
Regards,
Andreas.
ronaldsnoeck
Hi Andreas,
at home I repeated the whole procedure again. Now with the target (zuno) connected.
Now it works.
thanks,
Ronald
