I bought a Razberry Z wave daughter board from online (India) and they issues the EU frequency (2 years back approx). Its a 5th gen board. Now I see there is a specific frequency allocated for IN.
I also noticed that now the Country can be changed via the admin UI . I want to confirm that the country can be changed via UI. Is that possible or allowed? If i do that will I be able to use the IN specific devices with this board?
When i try to change the country, nothing happens, it just stays in the same page and i see the current frequency as "Unknown". Please let me know what step i am missing.
Really appreciate the support,
Best Regards,
Vijay
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 1
Z-Wave Chip: ZW0500
Software Information
Version number: v2.2.5
Compile-ID: d58b7617c4f553beca4c6f41705b48fa5a4cf56c
Compile-Date: 2016-11-15 11:42:15 +0300
Firmware
SDK Version: 6.51.03
Serial API Version: 05.00
Changing the country frequency
- Z-Wave Support
Re: Changing the country frequency
please Update your Bootloader about Expert UI (First Bootloader, then Firmeware).
Best regards
Z-Wave Support
Best regards
Z-Wave Support
Sorry to ask this, how to update Bootloader? Will just "wget -q -O - razberry.z-wave.me/install | sudo bash" update boot loader also? If that is the case i already did that. But Firmwire update is not going through.
Regards, Vijay
Regards, Vijay
In the Expert UI i do not get an option to update the bootloader. The firmwire update is not going through from this page.
- Z-Wave Support
you can update your Bootloader in http://IP:8083/expert/#/network/controller.
good luck
regards
good luck
regards
- Menu in Expert UI
- Firmware raz 2.PNG (66.04 KiB) Viewed 11148 times
- Update Button
- Firmware raz 1.PNG (24.66 KiB) Viewed 11148 times
- Firmeware button
- Firmware raz 0.PNG (30.01 KiB) Viewed 11148 times
It did not help, for this URL i am getting a message "Could not retrieve data from remote server.". What might be the issue?
Regards, Vijay
Regards, Vijay
Finally solved it via below step.
Downgraded to 2.2.2, did a fresh install to a new SD card. Used the browser in incognito mode (Very Important), i was able to see the options. Did upgrade of bootloader and firmwire. Then did reboot everything was ok.
Did a shutdown and swap of SD card, back to normal.
Thanks for the help,
Regards, Vijay
Regards, Vijay
