Philips Hue app?
Minux
Re: Philips Hue app?
Post by Minux »
beta version is available with this token:
ludo_beta_zway
lademeister
Post by lademeister »
is there a way to read in hue commands as well? I would like to read in the signal my TV sends to control hue bulbs as ambilight - some Phillips TVs allow not only to create backlight according to current TV picture colors by their own built-in-RGB-LEDs but also allow to let Hue lamps to change colors accordingly.
As you obviously have a lot more understanding about how Hue works, maybe you could have an answer to this :-)
bse4792
Post by bse4792 »
Minux wrote:beta version is available with this token:
ludo_beta_zway
dont seam to be able to be visibel with that token
Kind Regards bse4792
pz1
Post by pz1 »
No problem for me after I entered the code in Smarthome:
bse4792
Post by bse4792 »
maybe its firmversion problem, what are you using, just updated to v2.2.5
and how to find it in appstore?
sorry totally new to zway/zwave
pz1
Post by pz1 »
I do run v2.3.0-rc1 (the next beta; not recommended for general use!)
Via the smarthome interface, I clicked the little "tool" icon in the top right corner. Then selected Management from the dropdown menu. Then under App store access you can enter the token as pointed out in my previous post.
lademeister
How does hue work, could I sniff HUE commands from my Phillips TV (which sends them for ambilight control of hue bulbs) to control e.g. RGB code device within Z-Way?
nordstern
Post by nordstern »
hi
i think it's not necessary to sniff your network.
the hue api is well documented.
take a look here...
https://www.developers.meethue.com/docu ... ng-started
Mit freundlichen Grüßen / with kinds regards
Raspberry Pi 3 / raZberry 2 (3.0.6)
Raspberry Pi 3 B / UZB1 (3.0.6)
phischmi
Post by phischmi »
Now there also seems to be an *official* app available on the app store.
But when i add my hue bridge's ip and api, there are no controls created :|
Anyone experiencing the same problems?
bse4792
Post by bse4792 »
now i've found it and got it to work, but i'm missing sensor and dimmer options, is it possible to add this?
