i'm quite new to the RaZberry but yet very impressed by it's capabilities
I switched from Homee as i wanted to reduce my smart home devices to a minimum.
I'm running the RaZberry with the newest Z-Way Software (2.2.5).
My question now is, how it is possible to make a simple http(s) request to address e.g. a switch in Z-Way?
Background is, that i have an Android app called EgiGeoZone to send a http(s) request when entering or leaving a defined zone. Those requests can be secured using basic authentification or SSL.
Is it possible to use such requests with the RaZberry / Z-Way?
For requests from HA-Bridge i'm using sth. like
http://192.168.1.116:8083/ZAutomation/api/v1/devices/ZWayVDev_zway_5-0-37/command/on
This works great for HA-Bridge but is not possible to implement in EgiGeoZone.
Is there an alternative using basic auth, SSL certificates or even no auth?
I know there are many topics on this on the board, but i couldn't manage to find a solution working with an actual version of Z-Way :/
Thank you very much!
Regards
Philipp
