Hi there!
This might be a stupid question: I just changed from Fibaro HCL to RaZberry. It runs with 13 Fibaro Roller Shutter 2. Additionally I use one Fibaro Double Relay Switch to trigger a Scene which opens or closes all blinds.
Problem is that Razberry UI doesn't update the status afterwards. So if I open one blind with the local switch and then close ALL blinds via scene, this blind is still displayed as open in UI.
Any ideas?
If I go to ExpertUI --> Control --> Switch and then press "Update", the status is correct (e.g. changed from "UP" to "DOWN"). So the roller shutter seems to know its status, but doesn't transfer the final position to RaZberry.
Thanks for advice!
Froschkoenig
Fibaro Roller Shutter: UI doesn't update status
Froschkoenig
Re: Fibaro Roller Shutter: UI doesn't update status
This means Z-Way is not in the LifeLine Association group (in older Fibaro devices it is third group, in newer it is furst group). Have you re-included all devices?
Froschkoenig
Thanks a lot for the fast response! Very much appreciated!
I excluded all devices with RaZberry once to disconnect from HCL and then included them again.
Parameter 3 is defined as "0 – Blind position reports sent to the main controller using Z-Wave Command Class." Is that what you mean? See picture attached.
I changed parameter 10 to "0 - Roller Blind Mode, without positioning" as I had some issues with positioning. Roller Shutter sometimes went into calibration mode on their own which was pretty annoying and I don't need a position except up/down.
I also attach a picture from ExpertUI, showing that the status is correct as soon as manually updated.
- Z-Wave Routing.jpg (487.51 KiB) Viewed 16147 times
- RollerShutter with wrong status.jpg (62.47 KiB) Viewed 16147 times
- RollerShutter after manual update.jpg (61.41 KiB) Viewed 16147 times
- Configuration RollerShutter.jpg (353.49 KiB) Viewed 16147 times
I meant Associaitons, not Configuration.
Froschkoenig
I found the following settings on associations. Strange thing ist, that there is nothing unter "Associations" in ExpertUI, but then some parameters under "Expert Commands".
Is anything missing?
- Association.jpg (288.88 KiB) Viewed 16140 times
- Association Settings.jpg (186.87 KiB) Viewed 16140 times
- Association activation.jpg (304.25 KiB) Viewed 16140 times
it has to look like this. If not you have to update from device. If after the update the conroller isn't listed in the third group add the controller manually.
- Unbenannt.jpg (221.75 KiB) Viewed 16128 times
Froschkoenig
Thanks! I made it look like attached, which seems to be comparable to your snapshot. However the status still isn't updated properly.
- Association activation.jpg (304.25 KiB) Viewed 16110 times
Froschkoenig
Sorry - wrong attachment. All 3 associations are available now for all devices. Still no update.
Any further ideas?
Any further ideas?
- Associations available.jpg (137.14 KiB) Viewed 16105 times
I guess you only have the binary switch because the configuration without positioning?
I only use the Multilevel Switch, the Binary Switch is deactivated in my UI, so I didn't notice that my binary switch isn't updating too if the Roller are opened or closed by automation.
I've tried it, but it just updating by pressing it manually in the UI. The Binary Switch don't update automatically, even not using dummy device and association app.
- Unbenannt1.jpg (29.84 KiB) Viewed 16096 times
- Active for testing
- Unbenannt.jpg (24.36 KiB) Viewed 16096 times
Froschkoenig
Thanks Benny! That answers indeed one question but also brings a new one: Only one of my Roller Shutters shows a Multilevel Switch. The others don't show this at all. See screenshots.
When I include a new device, positioning is activated, so I guess that can't be the reason.
The only difference I could find is a slightly different device firmware version (see below). But even if that's the reason: What can I do against it?
- Differences RollerShutters.jpg (37.23 KiB) Viewed 16086 times
- RollerShutter without Position.jpg (69.99 KiB) Viewed 16086 times
- RollerShutter with Position.jpg (66.04 KiB) Viewed 16086 times
