Push-Me (Pushover) sends doublets of all notifications
benis
Post by benis »
Hello!
I got Pushover to work with Push-Me and my Fibaro door/window sensor - very happy with that. But, for everything it sends two identical notifications. I only got one "If -> That" rule, one sensor, etc. I can see under the activity log on my Razberry that it is only one event (see attached picture) when the sensor goes to "on" which is what the "If -> That" rule is set to.
Any tips how to solve it?
Big thanks in advance!
Screen Shot 2017-02-21 at 19.49.46.png (18.99 KiB) Viewed 17683 times
Z-Wave Support
Re: Push-Me (Pushover) sends doublets of all notifications
Post by Z-Wave Support »
you can deactivate the "Trap events from Remotes and Sensors" App in active Apps, then you is deactivate the button and the event.
Best regars
Z-Wave Support
benis
Post by benis »
Alright! I have made the change with a random switch and I only got one notification - I will try it with my door as soon as I am home as well. Thanks a lot!
benis
Post by benis »
Tried at home now but still getting two notifications. The thing you mentioned is de-activated. What else can trigger so it sends two notifications instead of one? (Attached some pictures)
The activity log.
The activity log.
Screen Shot 2017-02-22 at 17.14.44.png (16.98 KiB) Viewed 17665 times
The thing disabled.
The thing disabled.
Screen Shot 2017-02-22 at 17.16.28.png (16.27 KiB) Viewed 17665 times
benis
Post by benis »
And a screenshot of my phone.
Z-Wave Support
why send your Sensor a on and a off in the same time? Send you a push, if it open and close or only by open the door?
Best regards
Z-Wave Support
benis
Post by benis »
It's me opening and closing the door. Here you can se someone opening the door - then turning on the light in the hallway and then closing the door. So it's one activity for opening the door (Door: On) and one for closing the door (Door: Off). I only have an If -> Then when Door sensor is On.
Example
Example
Screen Shot 2017-02-23 at 09.37.52.png (38.75 KiB) Viewed 17654 times
Z-Wave Support
have you checked, if you have twice the scene ?
Best regards
Z-Wave Support
benis
Post by benis »
I have not that many apps installed and not a single scene as far as I know. Should I look somewhere else that here?
All installed apps
All installed apps
Screen Shot 2017-02-24 at 09.29.22.png (139.22 KiB) Viewed 17635 times
Z-Wave Support
hello,
i have tesed it and have not this problem.
Have you reinstall the app?
Best regards
Z-Wave Support
