We can dig in it. Please provide us a very detailed example how to reproduce it:
- sketch
- environment (included in controller? what config were changes? association made?...)
- whta are sypthoms?
Reboot board
Re: Reboot board
btw, about
relay switches connected 19, 20, 21, 22 pins.
relay default states - "HIGH" mean "OFF" / "LOW" mean "ON"
when Z-UNO start - (my guess) Z-UNO send on their pins "LOW" signal (sic!) what mean - please "ON"
so, issue still here.
btw, if I remove Z-WAVE defines (declaration of Z-DEVICES) sketch work properly!
2.0.8.PoltoS wrote:Yes, it is a known one. Located and solved in our lab. The fix will be available in 2.0.8 pretty soon
Re: Reboot board
Try it, pretty strange. Z-uno starts with all pins to input with pull-ups.
Re: Reboot board
when I connect the relay to 11 12 13 14 - it solves my issue.p0lyg0n1 wrote:Try it, pretty strange. Z-uno starts with all pins to input with pull-ups.
btw, I have read somewhere (I can't remember) that some Z-UNO pins (like 19-22) used for internal transfers for z-wave protocol)...
Re: Reboot board
Don't worry I will check it this Monday. I know how to reproduce this issue and the reason of it...
Re: Reboot board
I found it. The problem involved with access to external NVM memory(it uses some of pins for it). We patched the code of it and forgot to move it during release. Fixed it.
10der, thank you once more!
Re: Reboot board
tnx!
