Uno\examples\dht22_test
Raw data: { 0 C8 0 F5 BD }
Temperature:24.50
Humidity:20.00
Millis:27290
DHT read result:0
Raw data: { 0 C8 0 F4 BC }
Temperature:24.40
Humidity:20.00
Millis:30322
DHT read result:0
Raw data: { 0 C7 0 F4 BB }
Temperature:24.40
Humidity:19.90
Millis:33354
DHT read result:0
Raw data: { 0 C7 0 F3 BA }
Temperature:24.30
Humidity:19.90
Millis:36386
DHT read result:0
Raw data: { 0 C6 0 F3 B9 }
Temperature:24.30
Humidity:19.80
Millis:39417
DHT read result:0
Raw data: { 0 C6 0 F2 B8 }
Temperature:24.20
Humidity:19.80
Millis:42450
DHT read result:0
Raw data: { 0 C8 0 F2 BA }
Temperature:24.20
Humidity:20.00
Millis:45482
DHT read result:0
Raw data: { 0 CA 0 F1 BB }
Temperature:24.10
Humidity:20.20
Millis:48514
DHT read result:0
Raw data: { 0 CC 0 F1 BD }
Temperature:24.10
Humidity:20.40
DHT read result:0
Raw data: { 1F 0 1D 0 3C }
Millis:12175
DHT read result:0
Temperature:29.00
Humidity:31.00
Millis:15217
DHT read result:0
Temperature:29.00
Humidity:31.00
Millis:18259
DHT read result:0
Temperature:29.00
Humidity:31.00
Millis:21301
DHT read result:0
Temperature:29.00
Humidity:31.00
Millis:24343
DHT read result:0
Temperature:29.00
Humidity:31.00
Millis:27385
DHT read result:0
Temperature:29.00
Humidity:31.00
DHT11/DHT22 Z-Uno
1 3v3
2 11
3 x (NC)
4 GND
/* DHT library
MIT license
written by Adafruit Industries
UPGRADED/Rewriten by Z-Wave>ME for project Z-Uno 2016
#include "ZUNO_DHT.h"
#define MIN_INTERVAL 2000
#define DEBUG_DHT 0
DHT::DHT(uint8_t pin, uint8_t type): _pin(pin)
_type = type;
// reading pulses from DHT sensor.
void DHT::begin(void) {
// set up the pins!
pinMode(_pin, INPUT_PULLUP);
_lastreadtime = 0;
// returns temperature in 10 th of Celsius
int DHT::readTemperatureC10(bool force)
if(read(force) > DHT_RESULT_PREVIOUS)
return BAD_DHT_VALUE;
return temperature;
// returns humidity in 10 th of percent
int DHT::readHumidityH10(bool force)
return humidity;
// Returns temperature in float in Celsius
float DHT::readTemperature(bool force)
return readTemperatureC10(force) / 10.0;
// Returns humidity in float
float DHT::readHumidity(bool force)
return readHumidityH10(force) / 10.0;
// DBG
#if DEBUG_DHT
byte dbg_timings_s[80];
#endif
byte DHT::read(bool force) {
byte time_i1, time_i2;
word wi = 0;
byte time_ref;
//s_pin tp = 12;
byte i = 0;
byte ci = 0;
byte cb =0;
//pinMode(tp, OUTPUT);
//digitalWrite(tp, 0);
// Чтобы не опрашивать сенсор слишком часто
uint32_t currenttime = millis();
if (!force && ((currenttime - _lastreadtime) < 2000)) {
return DHT_RESULT_PREVIOUS; // return last correct measurement
_lastreadtime = currenttime;
// Посылаем стартовый импульс
// 0 на 1 мс и болльше
//noInterrupts();
pinMode(_pin, OUTPUT);
digitalWrite(_pin, LOW); // Send start signal
switch(_type)
case DHT11:
delay(13); // Датчик долго думает
break;
default:
delayMicroseconds(1400); // Гораздо быстрее откликается
break;
noInterrupts();
time_i1 = 0;
while(digitalRead(_pin))//digitalRead(_pin))
wi++;
if(!wi)
interrupts();
return DHT_RESULT_ERROR_NOSYNC;
NOPS(8);
time_i1 = 0;
while(!digitalRead(_pin))
time_i1++;
if(!time_i1)
break;
time_i2 = 0;
time_i2++;
if(!time_i2)
break;
if(time_i1 < 10 || time_i2 < 10)
interrupts();
// Вычисляем опорное время для "1"
// == Половина среднего времени отклика датчика
// Вычисляется здесь т.к.
// время стартового интервала будет плавать в цикле чтения битов
// особенно это заметно на каждом 8-ом бите
time_ref = time_i1 + time_i2;
time_ref >>= 2;
while(i<80)
switch(i&0x01)
case 0:
time_i1 = 0;
while(!digitalRead(_pin)) time_i1++;
#if DEBUG_DHT
dbg_timings_s[i] = time_i1;
#endif
break;
case 1:
time_i2 = 0;
while(digitalRead(_pin)) time_i2++;
#if DEBUG_DHT
dbg_timings_s[i] = time_i2;
#endif
cb <<= 1;
cb |= (time_i2 > time_ref);
break;
i++;
if((i & 0x0F)==0)
data_ptr[ci++] = cb;
cb = 0;
interrupts();
#if DEBUG_DHT
Serial.print("TIMINGS \n");
for(i=0;i<80;i++)
Serial.print("EDGE #");
Serial.print(i);
Serial.print(" ");
Serial.println(dbg_timings_s[i]);
Serial.print("RAW ");
for(i=0;i<5;i++)
Serial.print((uint16_t)data_ptr[i], HEX);
Serial.print(" ");
Serial.println(" ");
#endif
byte sum = data_ptr[0];
sum += data_ptr[1];
sum += data_ptr[2];
sum += data_ptr[3];
if ( sum != data_ptr[4])
#if DEBUG_DHT
Serial.print(" Calculated sum: ");
Serial.print(sum, HEX);
#endif
return DHT_RESULT_ERROR_CRC;
if(_type == DHT11)
humidity = data_ptr[0];
temperature = data_ptr[2];
humidity *= 10;
temperature *= 10;
else
humidity <<= 8;
humidity += data_ptr[1];
temperature = data_ptr[2] & ~(0x80);
temperature <<= 8;
temperature += data_ptr[3];
if ( data_ptr[2] & 0x80)
temperature -= temperature;
return DHT_RESULT_OK;
