z-way apple homekit gate
yan
Re: z-way apple homekit gate
Post by yan »
Hi, Thank you for update, I have easy installed it and even recognize the door look. But I found one thing, my door lock status was reversed, even z-way is correct, when z-way unlock(the door look also unlock), the homekit shows lock. do you have any idea about that?
yan
Post by yan »
Hi, Thanks for update the app. the "reversed" problem is solved well. many thanks. and there is another problem I have fund: the apple home app effect slowly. at beginning it shows updating... and then after several time it shows the status. but when you click the icon, it effect slowly...
chan cheth
Post by chan cheth »
Thank! for priview.
yan
Post by yan »
Hi, Is there any new update of this app? in my box, it seems works not very stable, I have to restart Z-way server every two hours to make it work. Z-way server always works well.
We are not aware of any problem. Please report it
john0wingnut
Post by john0wingnut »
I have just installed this and for some reason it doesnt seem to recognise my Fibaro FGMS-001 sensor correctly.
This sensor has a PIR, Luminance, temperature and tamper sensor.
The Homekit gate is only picking up the PIR, but as a contact switch.
It also wont allow me to use the PIR in the home app automation rules.
What is causing this?
non4bidden
Post by non4bidden »
Can anyone tell me how to reset all data from HomeKit Gate installation in order to reinstall it. After I accidentally deleted my home in home app, I tried several times to search for that bridge accessory, but with no luck. Any ideas guys?
You can remove the app and then install again. Should help
Alyce
Post by Alyce »
Hi.
After upgrade Z-way to 2.3.6 this gateway doesn't work.
I remove this app then add again. But can't add to my home on iPad or iPhone.
Please fix this.
IgoriokLT
Post by IgoriokLT »
Thermostat is working, I'm using Advanced Virtual Thermostat from the app store. It can be controled with Siri and Apple Home.
