Voltage Control
Black Cat
Voltage Control
Post by Black Cat »
Is there any example of a TRAIC (or other) hardware solution for Z-UNO, both in Hardware and Sketch?
I have a application where I need to control the Line Voltage 240VAC to 0-240VAC.
Black Cat
Re: Voltage Control
Post by Black Cat »
Anyone?
or is there no support for incandescent dimming?
Re: Voltage Control
You need to use standard TRIAC modules like with Arduino. we have such h a module
In brief you should trap zero cross interrupt, wait a bit depending on the dim level, turn on the TRIAC control PIN and the turn it off
