External antenna
paaland
External antenna
Post by paaland »
I wan't to remove the built-in and add an external antenna. But I find the instructions unclear.
Normally an antenna has two leads, one for the core and one for ground. According to instructions I can either use point 4: open hole for pig tail, or point 5 for uFL connector. But point 5 has three soildering points.
What is the correct way to add external antenna?
petergebruers
Re: External antenna
Post by petergebruers »
An ufl socket has three pins, you have to solder the socket to those pins.. Two pads are ground. Use ufl if you already have an antenna with ufl connector crimped on. Ufl looks like a tiny coaxial connector.
Or just connect a wire to 4. It should be 86 mm (for 868 MHz) or 82 (for 908/915 used in US).
Don't forget to remove the resistance connecting to the PCBA antenna to disable it
e-rook
Post by e-rook »
I did this exercise recently with piece of wire and helped with range and responsivity
http://e-rook.org/2017/10/17/razberry2- ... extension/
aus_fas
Post by aus_fas »
Which part or where should I break the PCB, any pictures please ?
