Log In issue
Black Cat
Log In issue
Post by Black Cat »
I am revisiting the use of a Razberry that I had setup 2 years ago and have a login issue.
Simple, I am not able to login, attempting to use the forgot password link returns an error.
This was a Popp unit if it's any help.
RaZ error.jpg (7 KiB) Viewed 12692 times
I'm going in circles and need expert help.
Black Cat
Re: Log In issue
Post by Black Cat »
Here we go again, no one can help me.
I have a registered and paid for HAS that can't be accessed.
Looks like the ZWave.me HA gets consigned to the bin and I look to another alternative.
Re: Log In issue
What is your version? Have you upgraded to the latest? Try to remove the /opt/z-way-server folder and install again
Black Cat
Re: Log In issue
Post by Black Cat »
I can't upgrade as I cannot access any UI, likewise I cannot access the unit by SSH, password is not recognised.
I am reluctant to re-flash as it was a paid for version and fear that I will need to buy another licence.
This is the message I get when I try to access through port 8084.
This one is from port 8083
RaZ error.jpg (7 KiB) Viewed 12626 times
Re: Log In issue
Have you changed the default password? Should be "raspberry".
Black Cat
Re: Log In issue
Post by Black Cat »
Tried using default-No Go.
I found this method to Upgrade and ReSet but the board is different.
My RaZ looks like this.
