UZB1 Max number of devices reached - get the Licence ?
scherrier
Post by scherrier »
i have a UZB1 stick, and i have the same problem than https://forum.z-wave.me/viewtopic.php?t=21983&p=57998
I think i need a licence, but i don't know how to get it ? The seller's site says that the licence is in the product, so there is no need for downloading. Where did you get this licence ?
Re: UZB1 Max number of devices reached - get the Licence ?
Usually it is included in a small paper by the seller in the box. And you need to enter it in the UI
scherrier
Post by scherrier »
29 Jul 2017 13:15
Okay Thanks !
I don't remember any paper, but i may be wrong :-/
Do you know the procedure to buy a new licence ?
Thank you very much !
It can be bought online in a many internet shops. Called Z-Way license.
scherrier
Post by scherrier »
I bought a licence... but it still does not work. I have tried with several s-way-server version.. with the latest (3.0) on my debian stretch, i can enter my licence key, verification, is okay... but Unable to upgrade capabilities ! (sometimes nothing happens on the usb stick, sometimes the led switches on, then starts to blink and never stop....
And in the log file :
[2017-08-09 15:32:22.682] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Failed
[2017-08-09 15:32:22.682] [D] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): fail
[2017-08-09 15:32:22.682] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
What can i do ?
Thx
Are you on 5.2x or on 5.0x fw of your UZB?
scherrier
Post by scherrier »
SDK Version: 6.71.01
Serial API Version: 05.22
scherrier
Post by scherrier »
Hi PoltoS, thanks for your answer.
I think i'm not far from the solution, but it still does not work.
I use a debian 9.1, with z-way-server 2.3.1 :
i run it this way : LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/root/z-way-server/libs ./z-way-server
My licence key is verified, but i'm "Unable to upgrade capabilities"
I think the UZB device is okay, the led switches on when i connect it to the PC. When i try to enter my licence key, the led of the key switches on (during one or two seconds), but then starts to blink very quickly, and i get the error message.
the log are:
[2017-08-10 17:07:09.010] [zway] Adding job: Get or set Z-Wave.Me firmware capabilities
[2017-08-10 17:07:09.017] [D] [zway] SENDING (cb 0x02): ( 01 34 00 F5 A7 5D 13 60 49 FE E1 88 38 1D D2 DF FA BD 70 EA 6C F7 C5 17 DB 15 4B DE 4E A4 A7 2C 2C 38 95 D9 1B A8 67 5B 33 62 23 64 70 AC 70 6F 1A 43 9D 72 02 59 )
[2017-08-10 17:07:09.023] [D] [zway] RECEIVED ACK
[2017-08-10 17:07:09.023] [D] [zway] RECEIVED: ( 01 04 01 F5 CE C1 )
[2017-08-10 17:07:09.023] [D] [zway] SENT ACK
[2017-08-10 17:07:09.023] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2017-08-10 17:07:12.147] [zway] Adding job: Get background noise level
[2017-08-10 17:07:18.173] [D] [zway] RECEIVED: ( 01 05 00 F5 02 FA F7 )
[2017-08-10 17:07:18.173] [D] [zway] SENT ACK
[2017-08-10 17:07:18.173] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Failed
[2017-08-10 17:07:18.173] [D] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): fail
[2017-08-10 17:07:18.173] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
Can you help me, please ? Is there a problem with my kernel module ? (i'm using the standard debian kernel 4.9, and i have also tried on a Ubuntu, with z-way-server 3.0rc2.. Same problem) ? May the USB is too quick ? I seems that it starts the update, but crashes during it...
i also have this message in the log :
[2017-08-10 17:07:18.178] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: too low, Ch#2: too low, Ch#3: invalid
[2017-08-10 17:07:18.178] [D] [zway] Job 0x3b (Get background noise level): success
But, there's a success at the end, so...
When the server starts, i have this in the log file, so i think it works all right :
[2017-08-10 17:04:11.828] [D] [zway] Opened device: /dev/ttyACM0
[2017-08-10 17:04:11.829] [D] [zway] Worker thread successfully created
[2017-08-10 17:04:11.829] [D] [zway] Worker thread entry point
[2017-08-10 17:04:11.830] [zway] Adding job: Get controller info and supported function classes
[2017-08-10 17:04:11.839] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2017-08-10 17:04:11.841] [D] [zway] RECEIVED ACK
[2017-08-10 17:04:11.849] [D] [zway] RECEIVED: ( 01 2B 01 07 05 16 01 15 04 00 00 01 FE 85 7F 88 CF 3F C0 47 FB DF FD E0 67 00 80 80 00 80 86 00 00
00 E8 73 00 80 0F 00 00 60 1A 00 1D )
[2017-08-10 17:04:11.849] [D] [zway] SENT ACK
[2017-08-10 17:04:11.849] [D] [zway] SETDATA controller.data.APIVersion = "05.22"
[2017-08-10 17:04:11.849] [D] [zway] SETDATA controller.data.manufacturerId = 277 (0x00000115)
[2017-08-10 17:04:11.849] [D] [zway] SETDATA controller.data.manufacturerProductType = 1024 (0x00000400)
[2017-08-10 17:04:11.849] [D] [zway] SETDATA controller.data.manufacturerProductId = 1 (0x00000001)
[2017-08-10 17:04:11.850] [D] [zway] SETDATA controller.data.vendor = "Z-Wave.Me"
Even, at the beginning, the access to the firmware capabilities seems ok :
[2017-08-10 17:04:11.860] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2017-08-10 17:04:11.870] [D] [zway] RECEIVED: ( 01 25 00 F5 01 DA 6F D1 81 D7 7E CF 49 C1 49 67 AF 6E 2A 3B DE D2 00 00 FF 05 00 00 00 00 00 00 00 00 00 00 00 00 2D )
[2017-08-10 17:04:11.870] [D] [zway] SENT ACK
[2017-08-10 17:04:11.870] [D] [zway] SETDATA controller.data.uuid = "6fd181d77ecf49c14967af6e2a3bded2"
[2017-08-10 17:04:11.870] [D] [zway] SETDATA controller.data.caps = byte[4]
[2017-08-10 17:04:11.870] [D] [zway] ( 00 00 FF 05 )
[2017-08-10 17:04:11.870] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Done
[2017-08-10 17:04:11.870] [D] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): success
[2017-08-10 17:04:11.870] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
It crashes only when i try to set my licence key (but i really need it, because i can't control any device without it)
Thanks if you can help me !
The new 5.2x is not supported yet. Will be soon. Meanwhile I'll support you individually in PM.
