Command class
Chiquitoloco
Command class
Post by Chiquitoloco »
I'd like do a thermostat for my home.
I had a look on the command class and i didn't see the thermostat_endpoint
Do yoi think to implement that?
Do yoi have a roadmap?
I found the abose list on the micasaverde wiki
http://wiki.micasaverde.com/index.php/Z ... nd_Classes
COMMAND_CLASS_THERMOSTAT_HEATING 0x38 56
COMMAND_CLASS_THERMOSTAT_MODE 0x40 64
COMMAND_CLASS_THERMOSTAT_OPERATING_STATE 0x42 66
COMMAND_CLASS_THERMOSTAT_SETPOINT 0x43 67
COMMAND_CLASS_THERMOSTAT_FAN_MODE 0x44 68
COMMAND_CLASS_THERMOSTAT_FAN_STATE 0x45 69
COMMAND_CLASS_CLIMATE_CONTROL_SCHEDULE 0x46 70
COMMAND_CLASS_THERMOSTAT_SETBACK 0x47 71
Re: Command class
We will certainly implement Thermostat Mode and ThrrmostatSetPoint. But only around November.
Other CCs are not used in most cases. May be FanMode, but next year only
olalid
Re: Command class
Post by olalid »
I too would very much like to have thermostat support.
Please let us know if this is planned.
Re: Command class
What kind of Thermostat support do you need? It is implemented.
olalid
Re: Command class
Post by olalid »
I just need thermostat setpoint I think.
But then I probably just need some help finding documentation for it, because I have been searching the online documentation and I have found nothing related to thermostat at all.
Re: Command class
Thermostat setpoint is supported
Black Cat
Re: Command class
Post by Black Cat »
Is there a setpoint example?
Re: Command class
olalid wrote:
18 Aug 2017 02:32
Black Cat wrote:
21 Aug 2017 01:43
Excuse, I missed the forum. In Z-Uno it is not implemented yet. I thought about RaZberry.
Currently you can only "implement" it via Switch On/Off(Binary Switch) or as a Dimmer (Switch Multilevel). And then transform this value into temperature.
olalid
Re: Command class
Post by olalid »
Ok, but the statement that it is planned for implementation is still valid?
Any idea when we can expect it to be released?
Re: Command class
We will certainly do it within half a year, but non promises
