The Netatmo app works fine for temperature, humidity & CO2, but except for initial value wind and rain is not updated. As you can see below values for wind (speed & direction) was read once when app was added, but not updated since.
The sensors have value on netatmo native web app so I know they are supposed to be updated. Removing and re-adding the app updates the values again, but only once.
Don't know where you have the NetAtmo app code. Could not find it on github to make a pull request. So I'll just post my changes here.
The module type names for wind and rain sensors seems to have changed for the getmeasurement api call to netatmo. Simply changeing them fixed the app again.
I am using Z-Wave.me 2.3.6 on my WD My Cloud. I have installed NetAtmo app version 1.1.3 and it is great app, but I can't use it.
After a while, my whole Z-Wave.me crashes and stops running. I have to disable the app on dev.netatmo and reboot Z-Wave.me server to stop server from crashing.
Hello. Now this application does not work correctly. I use z-way 2.3.8 and the application does not show my two additional internal weather station modules netatmo.
