websocket client
klaasjoerg
Re: websocket client
Post by klaasjoerg »
Hi PoltoS, I sent you a PM with some further informations...
klaasjoerg
Hi PoltoS, as already sent via PM here some further details how to reproduce the websocket protocol issue.
By the way: The login ssl problem (see viewtopic.php?f=3419&t=25251#p69852) seems to be somehow related to websocket issues too...
Step 1. Install wscat as a simple websocket service on a raspberry (e.g. https://www.npmjs.com/package/wscat)
npm install -g wscat
and start a simple websocket listener server with this command (e.g. Port 9000 and protocol type toptron-protocol, but doesn't matter actually for now):
wscat -l 9000 -p toptron-protocol
then you should see a console prompt like this:
root@raspberrypi3-jkl1:/opt# wscat -l 9000 -p toptron-protocol
listening on port 9000 (press CTRL+C to quit)
next
Step 2. setup a little JS-zwave-App as a websocket-client, with the following sample code:
// establish a new websocket connection to websocket server
var knausock = new sockets.websocket ("ws://192.168.1.61:9000","default");
// debug/pring incoming websocket messages, if available
knausock.onmessage = function (knausval) {
   var received_msg = knausval.data;
   debugPrint ("Socket-MSG-Received: ",received_msg);
zwave-ui-JS-websocket-app
ss 1.png (193 KiB) Viewed 10047 times
Step 3.
Now activate the little JS-App and you should see a successful connection in the console prompt
client connected
Step 4.
You can enter something here (e.g. MickyMouse) and should also see it as a debug output in the zwave-log too.
[2017-08-13 13:04:49.877] [I] [core] Socket-MSG-Received:  mickymouse
So far so good. No problem 'till here.
Step 5.
Now disable the JS-App in UI again and simply change the zwave-JS-App slightly by entering a different protocol type, instead of "default".
e.g.
var knausock = new sockets.websocket ("ws://192.168.1.61:9000","toptron-protocol");
zwave-ui-js-app deactivated
ss 2.png (20.11 KiB) Viewed 10047 times
Step 6. Stop wscat and start it again to have a clean starting point again.
Step 7. Now enable the JS-App in the UI again and you should see that connection is immediately being disconnected again:
client connected
disconnected
In my opinion the zwave-websocket part is disconnecting it's own connection again just becaus it's not "default"-protocol, which shouldn't happen.
(The disconnection is not being initiated by the wscat server.). If you also want to quickly test this, you could simply use wscat to connect to it's other process by entering ( e.g. wscat -c 192.168.1.61:9000 and playing around a bit).
Additionally, if you logout now from UI and try to immediately login again, you will see the login issue effect as written in the other thread:
No login possible anymore until you restart zway again.
Hope this helps solving the two issues? Would be great!
Joerg
hm.. tested on v2.3.5-rc17-internal and everything worked. According to git there is no difference in modules/socket...
klaasjoerg
I installed a complete new, fresh re-installation unter newest jessie raspian and zwave 2.3.5. with the same behaviour.
Additionally I noticed, that if websocket connections disconnect after some time, that the "re-login issue" (see other thread) is occuring....
So currently I simply have to restart zwave everytime I want to login (if a websocket disconnect happened earlier)...
