I create a sketch with one channel of type ZUNO_SWITCH_BINARY. After inclusion in Jeedom, in the 'Values' tab, I have 2 Switch values one with class / instance / index = 0x25 / 1 / 0 and one with 0x25 / 2 / 0. Both values seems to be synchronized (if we change one instance, the other is changed).
In the latest zwcfg.xml, I have:
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
<Instance index="1"/>
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False"/>
</CommandClass>Looking at a device ZMNHNDx Contact sec Z-Wave+ 1, there is only one Switch instance.
Best regards,
R.
